06-10-2014, 11:59 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: Cambodia
Member: 1305293 Status: Offline Thanks Meter: 271 | LG LU6200 resurrector...FAILED ??? Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [LG LU6200 V1.0.5025.52349] Connecting to the dead body...OK Detected dead body ID: 0x105310E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: Wrong DCC data checksum. |
06-14-2014, 05:31 | #5 (permalink) |
Member: 1305293 Status: Offline Thanks Meter: 271 | now i use rtck Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [LG LU6200 V1.0.5025.52349] Connecting to the dead body...OK Detected dead body ID: 0x105310E1 - IGNORED! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0006/0x0000 (16, 0x0000D7800000 Bytes = 3.37 GB) Detected an Initialized FLASH2 Chip, ID: 0x0006/0x0000 (16, 0x000000200000 Bytes = 2.00 MB) Flashing the dead body... WARNING: Programming Error (0x25) at 0x000000000000 is handled as Cut Excess. ERROR: DCC Loader has reported Error Code = 0x3E (0x007FFF <> 0x020000) |
