01-05-2015, 09:29 | #17 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: lake city
Member: 386868 Status: Offline Thanks Meter: 125 | Quote:
sanjubhai. | |
04-02-2016, 19:35 | #25 (permalink) |
Major Poster Join Date: Jun 2014 Location: india delhi
Member: 2213452 Status: Offline Thanks Meter: 7 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Nokia Lumia 520 V1.0.5149.18900] Connecting to the dead body...OK Detected dead body ID: 0x207D00E1 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 400 kHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: No response from the RIFF Box. what is problem |
11-17-2016, 15:27 | #27 (permalink) |
No Life Poster Join Date: Sep 2004 Location: South Mrorocco Age: 49
Member: 80599 Status: Offline Sonork: 1621236 Thanks Meter: 281 | Hi cant' ressurection lumia 520 rm-914 Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Nokia Lumia 520 V1.0.5149.18900] Connecting to the dead body...OK Detected dead body ID: 0x207D00E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (M8G2YC, 0x0001D2000000 Bytes = 7.28 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (M8G2YC, 0x000000400000 Bytes = 4.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 7,28GB Flashing the dead body... ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK ERROR: Stopped due to multiple communication errors. Terminating at 0x000000000000 regards |
01-31-2018, 20:46 | #28 (permalink) |
Freak Poster Join Date: Jul 2012 Location: khujand
Member: 1791645 Status: Offline Sonork: 119.01.15.66 Thanks Meter: 44 | 520 RM-915 boot repair done with ATFjtag 520 RM-915 boot repair done with ATFjtag Phone Type : Lumia 520 RM-915 CPU Type : Qualcomm MSM8227 Storage Type: eMMC 8GB Boot Package: 3056.40000.1402.0008 (BIG BOOT) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core with 100ms Delay...Retry Resetting and Exploring JTAG chain...OK Halting Core with 100ms Delay...OK Initializing Device...OK Detecting eMMC #1 ID...90014A48384732640401009DD3EAA0F9 Flash Description: Hynix H8G2d, 7.23 GiB, SN 009DD3EA, Oct 1997 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (5989 Op/Sec) Restoring MBR Data...OK Restoring GPT Data from AFP...OK Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Restoring Partition #8...OK Restoring Partition #9...ok Restoring Partition #10...OK Completed in 0h 6m 29s. Code Download Speed 445 KiB/sec. Boot Restore Done! ================================================== =========== Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure ================================================== =========== |
01-31-2018, 20:46 | #29 (permalink) |
