oppo a3s OPPO A3S CPH 1803 UNLOCK PATTON possible with riff box |
riff team sleeping.................. |
Read post Follow instruction Br, |
this working method? |
Offcource Working Br, |
oppo a5 and realme c1 dead after coneect isp hello sir i connect realme c1 as show pinout and emmc not detect in box and mobile got dead i remove clk resistor bt not solve again i connect oppo a5 and emmc not connet and mobile is dead pls help sir clean pcb no damege pls solve my problem |
First of all check the hardware Mobile cannot go to dead mode simply by connecting emmc connections You must have made some mistake...or careless handling Br, |
https://i.postimg.cc/4xFH8Fzt/20190823-113412.jpgok sir i check both pcb totly clean and no damage remove clk i read other post some user face this problem bt not solve |
Br, |
no i connect by jumper |
Come online there Br, |
where i check online support ? sir plz explain |
Br, |
I have done more than one REALME C1(RMX1811) and OPPO A3S there is no issue /cause of dead. Join Riff box Viber group for proof/ more explanation. First off all cut the metal shield very carefully. Second soldier iron may take a part of dead( use dc iron with low voltage) because over hitting may damage smd parts. For Realme C1 first remove clk resistor. After successful resurrection just make a jumper(no need to replace clk resistor). Believe me and make a try. You should get success. |
Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.51 (RIFFBOX1), JTAG Manager Version: 1.86 Selected Package: [Oppo A3s CPH1853 Reset V1.02 by <legija>, <RJ-45>, 1 Bit Bus Width (DAT0)] Connecting to the SD/eMMC Card...OK Set I/O Voltage reads as 1.79V, SD_CLK Frequency is 2.50 MHz Memory Type .......................... eMMC Manufacturer ID ...................... 0x90 OEM/Application ID ................... 0x4A Product Name ......................... "HCG8a4" Package .............................. BGA User Area Partition Size ............. 0x000E8F800000 Bytes (58.24 GB) Boot Partition Size .................. 0x000000400000 Bytes (4.00 MB) RPMB Partition Size .................. 0x000000400000 Bytes (4.00 MB) OCR Register ......................... 0xC0FF8080 (Dual Voltage, High Capacity) Write Protection Bits ................ NONE ExtCSD Register Fields ............... [177] = 0x00, [179] = 0x38, [162] = 0x01 Boot Configuration ................... Boot from User Area (Bus Width = 1 Bit) Chip Revision ........................ 10.2 Multimedia Card Revision ............. 1.8 (eMMC v5.1) Serial Number ........................ 0x4C31D266 Memory Manufacturing Date ............ August, 2018 Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.51 (RIFFBOX1), JTAG Manager Version: 1.86 Selected Package: [Oppo A3s CPH1853 Reset V1.02 by <legija>, <RJ-45>, 1 Bit Bus Width (DAT0)] Connecting to the SD/eMMC Card...OK Set I/O Voltage reads as 1.79V, SD_CLK Frequency is 2.50 MHz Detected eMMC Chip, ID: 0x90/0x4A (HCG8a4), User Area Partition = 0x000E8F800000 Bytes (58.24 GB) Analizing the FullImage File: Looking for the MBR Signature ................... ERROR ERROR: Failed to read data from the connected Device! notwork |
vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
