Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 08-27-2019, 12:30   #16 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 503
Originally Posted by SAJONDUTTA View Post
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.51 (RIFFBOX1), JTAG Manager Version: 1.86
Selected Package: [Oppo A3s CPH1853 Reset V1.02 by <legija>, <RJ-45>, 1 Bit Bus Width (DAT0)]
Connecting to the SD/eMMC Card...OK
Set I/O Voltage reads as 1.79V, SD_CLK Frequency is 2.50 MHz
Memory Type .......................... eMMC
Manufacturer ID ...................... 0x90
OEM/Application ID ................... 0x4A
Product Name ......................... "HCG8a4"
Package .............................. BGA
User Area Partition Size ............. 0x000E8F800000 Bytes (58.24 GB)
Boot Partition Size .................. 0x000000400000 Bytes (4.00 MB)
RPMB Partition Size .................. 0x000000400000 Bytes (4.00 MB)
OCR Register ......................... 0xC0FF8080 (Dual Voltage, High Capacity)
Write Protection Bits ................ NONE
ExtCSD Register Fields ............... [177] = 0x00, [179] = 0x38, [162] = 0x01
Boot Configuration ................... Boot from User Area (Bus Width = 1 Bit)
Chip Revision ........................ 10.2
Multimedia Card Revision ............. 1.8 (eMMC v5.1)
Serial Number ........................ 0x4C31D266
Memory Manufacturing Date ............ August, 2018
Detected eMMC Chip, ID: 0x90/0x4A (HCG8a4), User Area Partition = 0x000E8F800000 Bytes (58.24 GB)
Analizing the FullImage File:
Looking for the MBR Signature ................... ERROR
ERROR: Failed to read data from the connected Device!
notwork
this pin out work jitaplus but riff not work
Old 08-28-2019, 06:16   #17 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 503
Originally Posted by ~AKSingh~ View Post
Offcource
Working
Br,
vcc vccq need to connect?? or usb
Old 08-28-2019, 06:30   #18 (permalink)
~AKSingh~'s Avatar
Member: 65063
Thanks Meter: 2,411
Yes you can usb also,
Br,
Old 08-28-2019, 06:44   #19 (permalink)
SAJONDUTTA's Avatar
Member: 926902
Sonork: 100.1655575
Thanks Meter: 503
Br,
iuse usb but not work but other box work perfect
Old 09-06-2019, 10:24   #20 (permalink)
Member: 1784151
Sonork: 0
Thanks Meter: 75
sorry, i use free version to remove Oppo A3S pattern lock or password or FRP
sorry, to many dead box and dongle
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.10402 seconds with 7 queries
