03-09-2016, 04:02 | #1 (permalink) |
Junior Member Join Date: Sep 2014 Location: Philippines
Member: 2256382 Status: Offline Sonork: 100.1658813 Thanks Meter: 8 | Samsung SM-B350E Simlock now dead! now i flash to latest odin after clicking start hang on repartition unplug device now dead now i have a riff box team pls need help i need solution how to repair boot it is spreadtum sc6551c |
03-09-2016, 09:25 | #3 (permalink) |
Freak Poster Join Date: Aug 2012 Location: Ponkunnam, Kottayam. KERALA Age: 35
Member: 1800292 Status: Offline Sonork: 100.1668763 Thanks Meter: 122 | 1. To recover B350E use any Chinese repair box. OR 2. You can recover it by normal flashing with a flasher or by any Samsung flashing box. (NO NEED OF BOOT REPAIR BOX) But to connect you need to press boot key. Boot key is HOME/MENU key. Press and Hold the key and connect to USB to connect CHECK DEVICE MANAGER -- DRIVERS MUST BE INSTALLED (SPD DRIVERS) |
The Following 4 Users Say Thank You to pgharidas For This Useful Post: |
03-11-2016, 04:09 | #4 (permalink) | |
Member: 2256382 Status: Offline Sonork: 100.1658813 Thanks Meter: 8 | Quote:
not working brother thanks for reply any soution pls. | |
The Following User Says Thank You to gsm-yogal For This Useful Post: |
03-11-2016, 05:47 | #6 (permalink) | |
Member: 1800292 Status: Offline Sonork: 100.1668763 Thanks Meter: 122 | Quote:
Boot Key is -- (Press '1' + 'OK' button and connect USB cable) Chinese box doesn't support this CPU Sorry for these errors. Use flash file from z3x support. Driver "SCIUSB2SERIAL" is needed. You need to check device manager when connecting phone to USB in flash mode if the driver "SCIUSB2SERIAL" is OK. If not right click and update driver. ( Show the SCIUSB2SERIAL.inf file you downloaded) If you are using W7 or W8 disable "forced driver signature". Hope this will help. | |
03-11-2016, 06:05 | #7 (permalink) |
Member: 2256382 Status: Offline Sonork: 100.1658813 Thanks Meter: 8 | device must boot into download mode so that z3x can fash it bro but the status of this device is not booting yet. |
03-12-2016, 11:22 | #10 (permalink) | |
Member: 1800292 Status: Offline Sonork: 100.1668763 Thanks Meter: 122 | Quote: B350E -- CPU SC6551c B310E -- CPU SC6530 | |
The Following User Says Thank You to pgharidas For This Useful Post: |
03-13-2016, 19:14 | #11 (permalink) |
No Life Poster Join Date: Sep 2008 Location: with mobile phone Age: 35
Member: 866865 Status: Offline Sonork: 1645198 Thanks Meter: 182 | i think Volcano can fix just try with volcano and post result Last edited by Pratheesh T K; 03-13-2016 at 19:21. |
The Following User Says Thank You to Pratheesh T K For This Useful Post: |
