Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 06-12-2011, 10:36   #1 (permalink)
Member: 729092
Sonork: 99879
htc desire after riff dead
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.24, JTAG Manager Version: 1.32
Selected Resurrector: [HTC Desire]
Connecting to the dead body...OK
Detected dead body ID: 0x202400E1 - CORRECT!
Set I/O Voltage reads as 3.00V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at MAX]
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip ID: 0x00EC/0x55BC (512MB)
Selected Resurrection Data for the NAND Chip with Page size = 2KB
Flashing the dead body...FAILED
ERROR: Resurrection is not Completed due to Error: 0x3901
Old 06-12-2011, 10:39   #2 (permalink)
Member: 1454100
Thanks Meter: 28
set your RTCK sample rate to a very low number ...
Sent from my xxx using Tapatalk
Old 06-12-2011, 10:54   #3 (permalink)
Member: 729092
Sonork: 99879
Adaptive Clocking RTCK Sampling is: [Sample at 800 kHz]
Old 06-12-2011, 11:12   #4 (permalink)
Member: 1454100
Thanks Meter: 28
6 or 8
Old 06-12-2011, 11:16   #5 (permalink)
Member: 729092
Sonork: 99879
Adaptive Clocking RTCK Sampling is: [Sample at 6 MHz]
Adaptive Clocking RTCK Sampling is: [Sample at 8 MHz]
Old 06-12-2011, 11:35   #6 (permalink)
Member: 1454100
Thanks Meter: 28
I would say it maybe a hardware problem but what was the state of the phone before hand ? Or are you just changing the CID or unlocking ?
Old 06-12-2011, 11:37   #7 (permalink)
Member: 1454100
Thanks Meter: 28
Some times with this phone it error outs at about 40 percent but the phone will still get in Hboot after . How far do you get ?
Old 06-12-2011, 12:41   #8 (permalink)
Member: 729092
Sonork: 99879
it finshes 100% and no boot
i have 5 phones same thing
all after last update prior to update all was 100%
Old 06-13-2011, 09:02   #9 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 28,276
Hi,
You need to rewrite HTC Partition too.
Old 06-14-2011, 07:41   #10 (permalink)
Member: 729092
Sonork: 99879
Originally Posted by legija View Post
Hi,
Where are you I am doing this???
Old 06-14-2011, 17:08   #11 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Rewrite phone IMEI, this will also rewrite HTC partition. You can also write supercid (11111111).
Old 06-23-2011, 19:51   #12 (permalink)
Member: 272137
Thanks Meter: 75
i did same thng resurrection done? but fone is not going to botloader mode ,phone was ok HTC MOZART ,came to me for rebuild imei.
5110 v 6.0 after unlocking problem with net cole Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 01-10-2001 16:11
5110/6110 after unlocking see only network to which it was locked and ... 2M Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 07-25-2000 00:51
5110 5.24 locked all 4 locks after unlocking... MCG Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 03-07-2000 22:24
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) tcamilo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-19-1999 22:30
"Menu 11"? after Net monitor Pyron Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 08-09-1999 10:07
Page generated in 0.17035 seconds with 9 queries
