01-01-2013, 11:48 | #3 (permalink) |
No Life Poster Join Date: Nov 2011 Location: .::INDIA::. Age: 35
Member: 1681461 Status: Offline Sonork: [OFFLINE] Thanks Meter: 1,011 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung B219 V1.0.4443.4197] Connecting to the dead body...OK Set I/O Voltage reads as 2.59V, TCK Frequency is 5 kHz Detected dead body ID: 0x122CE0E1 Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - CORRECT! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x76010000000000000000000000800000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Wrong response code from the RIFF Box: 0x45 |
The Following User Says Thank You to .::TEJARAM::. For This Useful Post: |
01-01-2013, 13:30 | #4 (permalink) | |
No Life Poster Join Date: May 2011 Location: india
Member: 1583254 Status: Offline Sonork: 100.1602320 Thanks Meter: 4,792 | Quote:
Please Check Nrst Pin Conntection | |
01-01-2013, 13:37 | #5 (permalink) |
Member: 1681461 Status: Offline Sonork: [OFFLINE] Thanks Meter: 1,011 | Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - IGNORED! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Settings Code: 0x3E0100000000000000000000007FFFFF Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. |
01-01-2013, 19:02 | #6 (permalink) | |
No Life Poster Join Date: May 2010 Location: <:D-R-E-A-M-S:>
Member: 1312746 Status: Offline Thanks Meter: 766 | Quote:
01-03-2013, 15:02 | #7 (permalink) |
Member: 1681461 Status: Offline Sonork: [OFFLINE] Thanks Meter: 1,011 | thanks all bor my porblam is ok by riff WBR ; tejaram |
01-12-2013, 07:10 | #9 (permalink) | |
Please Check here http://forum.gsmhosting.com/vbb/f634...-want-1572131/ | |
The Following User Says Thank You to M0YAL For This Useful Post: |
01-19-2013, 09:34 | #11 (permalink) |
Freak Poster Join Date: Feb 2008 Location: chhattisgarh India
Member: 698592 Status: Offline Sonork: 100.1645954 Thanks Meter: 18 | i Can't rpaird sucsss.. [QUOTE=KIMTTeam;9118244] Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [QSC1100 X14 NOR V1.0.0.0] Connecting to the dead body...OK Detected dead body ID: 0x122CE0E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 8 MHz] Settings Code: 0x4601000E000000000000000000400000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Wrong response code from the RIFF Box: 0x45 |
01-19-2013, 13:12 | #12 (permalink) |
Member: 1583254 Status: Offline Sonork: 100.1602320 Thanks Meter: 4,792 | [QUOTE=DILIP_MKPKRB;9118397] Quote: Plz Check your Connection (Nrst Must not Connect ) |
01-19-2013, 13:29 | #13 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Delhi Age: 35
Member: 885719 Status: Offline Sonork: 100.1604802 Thanks Meter: 412 | [QUOTE=DILIP_MKPKRB;9118397] Quote: just connect using qsc1100 dll then halt the target now write dump you got error "0x45" don't worry again go to jtag read/write tab and again halt the target you see its waiting for halt now remove power and put again power in board you see halt completed now go again in dcc read/write and write dump this time dump start writing in it. |
The Following User Says Thank You to Athelcute For This Useful Post: |
02-05-2013, 12:33 | #14 (permalink) |
Member: 1681461 Status: Offline Sonork: [OFFLINE] Thanks Meter: 1,011 | |
02-05-2013, 16:50 | #15 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,827 | Dear Friend If Your Cellphone In Blinking Condition, So Please Check It's Taking Download Mode By Pressing 9+Power Keys, If Yes Then Flash By PST & Flash File. Here It's Samsung B229 Flash File With PST : http://forum.gsmhosting.com/vbb/9123645-post1.html |
The Following 2 Users Say Thank You to MyGSM World For This Useful Post: |
