Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #18 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2008 Location: in Your Heart :)
Member: 681758 Status: Offline Sonork: 100.1676160 Thanks Meter: 347 ![]() | Quote:
check usb driver its driver problem NTU8500 not installed check usb cable in other port | |
![]() | #19 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2006 Location: Sri Lanka
Member: 221857 Status: Offline Thanks Meter: 13 | nokia 625 dear during flash. now i try to resurrection using riff,here is log open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Nokia Lumia 625 V1.0.5280.5626] Connecting to the dead body...OK Detected dead body ID: 0x207220E1 - IGNORED! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0011/0x0100 (008G92, 0x0001D2000000 Bytes = 7.28 GB) Detected an Initialized FLASH2 Chip, ID: 0x0011/0x0100 (008G92, 0x000000400000 Bytes = 4.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 7.28GB Flashing the dead body...OK Resurrection complete! But still 625 not in boot mode usb detect as "QHSUSB_DLOAD" what is the next step?. please help.how can i get this phone to boot mode. |
![]() | #20 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2007
Member: 550428 Status: Offline Thanks Meter: 25 | i still don understand how to solve the problem below.. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9070 V1.0.4762.51152] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is 12 MHz Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x51): Communication is not established. Terminating. please teach and explain how to solve.. thankyou |
![]() | #21 (permalink) |
Junior Member ![]() ![]() Join Date: Oct 2006
Member: 381684 Status: Offline Thanks Meter: 1 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Samsung I8530 V1.0.4705.16748] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x51): Communication is not established. Terminating. how to solve this? |
![]() | #22 (permalink) |
Junior Member Join Date: Aug 2010
Member: 1359258 Status: Offline Sonork: 100.99999 Thanks Meter: 2 | always error in htc t328w on riff box Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [HTC DesireV (PL1110000) V1.0.4800.54829] Connecting to the dead body...OK Detected dead body ID: 0x106220E1 - IGNORED! Set I/O Voltage reads as 2.59V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0065/0x646F (M MORN, 0x000008000000 Bytes = 128.00 MB) ERROR: Read Failed with Error Code: 0x46. Terminating at 0x000002E73800 Flashing the dead body... ERROR: DCC Loader has reported Error Code = 0x46 (0x000000). Trying to recover...FAILED ERROR: Failed due to multiple communication errors. Terminating at 0x000005000200 |
![]() | #24 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2007 Location: ****pur
Member: 447533 Status: Offline Sonork: 100.1589374 Thanks Meter: 29 | my s-5360 same probleme Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Samsung S5360 V1.0.4443.1900] Connecting to the dead body...OK Detected dead body ID: 0x07B3617F - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. |
![]() | #25 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2351071 Status: Offline Thanks Meter: 0 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.55 Selected Resurrector: [ZTE S1602 V1.00] Connecting to the dead body... ERROR: Set I/O Voltage to 1.80V failed. Real reading is 2.10V |
![]() | #26 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: May 2004 Location: INDIA Age: 53
Member: 65063 Status: Offline Thanks Meter: 2,418 ![]() | Quote:
meet me on icq with set connect to jtag br, | |
![]() | #27 (permalink) |
Junior Member ![]() Join Date: Oct 2010
Member: 1417615 Status: Offline Thanks Meter: 0 | Help ! htc 802d ERROR: DCC Loader has reported Error Code = 0x51 Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [HTC One802Dual (PN0771000) V1.0.5053.62566] Connecting to the dead body...OK Detected dead body ID: 0x207150E1 - IGNORED! Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0100 (SEM32G, 0x000747C00000 Bytes = 29.12 GB) Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0100 (SEM32G, 0x000000400000 Bytes = 4.00 MB) Flashing the dead body... ERROR: DCC Loader has reported Error Code = 0x51 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x51 (0x000000). Trying to recover...OK ERROR: DCC Loader has reported Error Code = 0x51 (0x000000). Trying to recover...OK ERROR: Stopped due to multiple communication errors. Terminating at 0x000000000000 Report Post |
![]() | #28 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2009 Location: Micro Service Loznica Age: 44
Member: 1006045 Status: Offline Thanks Meter: 13 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Resurrector: [Samsung I8190 V1.0.4836.65460] Connecting to the dead body...OK WARNING: Connection via USB failed with Code: 0xC000FF01 Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is 12 MHz Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x51): Communication is not established. Terminating. |
![]() | #29 (permalink) |
Member: 1006045 Status: Offline Thanks Meter: 13 | after change usb connector Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is 12 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
![]() | #30 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2014 Location: Peshawar Age: 33
Member: 2123463 Status: Offline Sonork: 100.1652545 Thanks Meter: 29 | how to block my riff box hi supporters can any one tell me how can i block my riff box actually some one steal my riff box and i want to block it as soon as possible plz help me |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
