04-10-2017, 10:52 | #46 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | RIFF JTAG Manager v1.67, RIFF Box Firmware v1.43 --------------------------- - Fixed bug (which is related to RIFFBOX2 only), which caused box connection error, after this operation: "Setting new JTAG/eMMC License to the RIFFBOX." RIFF Box Firmware v1.43 --------------------------- - Fixed bug related to RIFF Box v1 eMMC detection - Fixed bug related to RIFF Box v2 USB 2.0 ports enumeration New RIFF Box v2 drivers: ---------------------------- - Drivers from year 2014 (x86 and x64) Instructions for users with V2 box and "Device cannot start, error code 10" problem: Method 1: - Disconnect RIFF Box v2 from USB port - Open box housing and take PCB out - Connect TP1 to TP2 using tweezers, - Connect USB cable to Box and PC - Disconnect TP-s - Launch JTAG Manager (any version from 1.65 and up) - Perform Firmware Update as requested After You connect TP-s and USB cable, box will enumerate in bootloader mode. RIFF Update Port driver is required (like allways during firmware update) and Recovery firmware will be flashed. After this, normal Firmware Update procedure will follow and You can use RIFF Box on any USB port (2.0 or 3.0). Method 2: - Find working USB 3.0 port (By working means that LPCDevice driver works) - Update box to V1.43 firmware |
The Following 18 Users Say Thank You to legija For This Useful Post: |
04-10-2017, 12:43 | #47 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Bahia-Brazil
Member: 521610 Status: Offline Thanks Meter: 38 | Is it worth buying the activation for RIFFBOX 1? Or is it better to buy version 2? Thank you If you buy activation for version 1 ... will you do the same functions as version 2? |
04-10-2017, 14:20 | #48 (permalink) | |
Insane Poster Join Date: Nov 2014 Location: barwani MP Age: 37
Member: 2287153 Status: Offline Thanks Meter: 8 | connection problem before 3 month Quote:
04-29-2017, 11:33 | #57 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | RIFF Box Firmware v1.45, RIFF JTAG Manager v1.69 eMMC Plugin v3.02 released Firmware 1.45 --------------------------- - Added MassStorage Mode for RIFFBOX2 JTAG Manager 1.69 --------------------------- - Fixed the bug for General Purpose Partition Sizes - Added feature to switch ON/OFF the MassStorage Mode. For this, please connect an eMMC (either via Direct or ISP interface), make sure it is detected (on the "eMMC/SD Card" page), and on the 'eMMC/SD Advanced' dialog click the 'MassStorage Mode ON/OFF' button to setup which partitions are to be mounted. Please note, for stable connection, first of all do reads on the "eMMC/SD Card" page to adjust stable Frequency, BusWidth and Voltage. After you click "MassStorage Mode ON/OFF" button, current settings for Voltage, Frequencty, BusWidth will be written into RIFFBOX non-volatile memory, and while the MassStorage mode is ON, upon each connection to USB the RIFFBOX will additinally to normal Control interface enumarate the MassStorage Disks (as if a FlashStick is connected to PC) eMMC Partition Table FullFlash Image Files Processing Plugin (eMMCDiskPartitions.dll) v3.02 ------------------------------------- - Added support for User Area Partition bounds selection from the JTAG Manager's MassStorage settings dialog - Added file system detection: the plugin analyzes the partition's data structure to autodetect what file system (if any) is used. The result is displayed in the new "F/S" row .. To mount EXT/x partitions You should install EXT FS driver from here: http://www.ext2fsd.com .. |
The Following 8 Users Say Thank You to legija For This Useful Post: |
09-08-2017, 13:39 | #60 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | RIFF JTAG Manager v1.73, RIFF Firmware v1.47 Mass storage mode support for RIFF Box RIFF Firmware 1.47 MassStorage Mount/Dismount support for RIFFBOX1 is added. Working with special eMMC vendor features (like dedicated Samsung eMMC Chips commands) is re-organized. Due to high risk of erasing User/Boot areas on the eMMC chips which are not Samsung, the Samsung chips autodetection is completely removed. To access special Samsung eMMCs features (like firmware update, factory reset, etc) User must manually select Vendor Mode. RIFF1 & RIFF2: Finally!!! The eMMC/SD Erase Operation (for Direct/ISP connection) finally is implemented!!! RIFF JTAG Manager 1.73 MassStorage mount/dismount feature is reworked and improved. Now is possible to Mount/Reconfigure/Dismount the MassStorage via the same dialog. The MassStorage settings are read from the RIFFBOX, so it is much more convenient in case users need to mount/dismount same eMMC Area ocasianlly or to adjust eMMC connection parameters for better stability. MassStorage Mount/Dismount support for RIFFBOX1 is added. Working with special eMMC vendor features (like dedicated Samsung eMMC Chips commands) is re-organized (see the Firmware 1.47 notes) Finally!!! The eMMC/SD Erase Operation (for Direct/ISP connection) is implemented!!! JTAG Manager 1.72 New method of resurrectors grouping is added. Setting ISP Resurrectors shows only the ISP available DLLs; Setting ISP Resurrectors shows only the packages (PKG files); setting JTAG Resurrectors shows only the JTAG available DLLs Setting ALL Resurrectors shows all available DLLs same as is done in JTAG Manager 1.71 and lower. Fixed bug for correct setting of the recommended SD/MMC VCCIO voltage for ISP DLLs: when model is selected, the JTAG Manager adjusts the frequency, voltage and other settings to match (if possible) those values, which are hardcoded into resurrector DLL. List of newest repair DLL-s with ISP support: LG F240L, Asus ZenFone2 (ZE551ML), Huawei Honor 4C (CHM-U01) ISP Nokia lumia 530 ISP Samsung I9305 ISP Samsung J105H ISP Samsung N8000 ISP Samsung P5100 ISP Samsung T531 ISP Samsung G361H ISP Samsung I9300 ISP Samsung I9300I ISP Samsung I9301I ISP Samsung i9070 ISP Samsung i8552 ISP Samsung n7000 ISP Samsung i9192 ISP Samsung i9060 ISP Samsung G318H ISP HTC Flyer ISP HTC Desire 326G ISP ZTE V811 ISP |
The Following 47 Users Say Thank You to legija For This Useful Post: |
