05-10-2011, 16:50 | #151 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | ------------------------------------- - fixed bug when resurrection stopped at the 0x00000000 address |
The Following 7 Users Say Thank You to legija For This Useful Post: |
05-10-2011, 17:33 | #152 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 10.05.2011 CDMA LG VM265, CDMA Huawei Broadband Modem EC1260 supported Resurrecting LG VM265 is easy. Phone is auto powered on with USB Data Cable connected to the PC. Battery presence is not required; connection can be established with detached board. To resurrect LG VM265:
Resurrecting Huawei EC1260 is simple. Just make sure you solder all JTAG signals and insert modem into a USB port for it to get powered. If modem is not detected by RIFFBOX JTAG, disconnect JTAG connector, re-insert modem into USB and then connect back the JTAG connector. At resurrection startup you can select which zones are to be re-flashed. Thus you can save a lot of time if you know approximately which zone is damaged. Select EFS or MMC areas to be flashed only in case you are sure those are damaged – these areas quite big in size; unnecessary reflash is just a waste of time. Please note, if you chose EFS to be repaired, an original ESN will be lost and substituted with the one contained in resurrection data. Current resurrector does not support ESN repair. To resurrect Huawei EC1260:
Please click “Check For Updates” button in order to download and apply new files. Closing all running application before starting update process is recommended. |
The Following 6 Users Say Thank You to legija For This Useful Post: |
05-12-2011, 14:33 | #153 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 12.05.2011 Samsung Eternity A867 Unbrick - Boot repair supported The Samsung A867 board is auto powered on with USB Data Cable connected to the PC. Battery presence is not required; connection can be established with detached board. To resurrect Samsung A867:
To enter download mode:
05-12-2011, 14:35 | #154 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 12.05.2011 Huawei E5830 Broadband modem Unbrick – Boot repair supported Resurrecting Huawei E5830 is simple. Just make sure you solder all JTAG signals. Connection can be established with USB Cable connected, though in some rare cases battery presence may be required. If modem is not detected by RIFFBOX JTAG, disconnect JTAG connector, re-insert modem into USB and then connect back the JTAG connector. Please note, if only an USB cable is connected the device is detected by PC as unknown device. So, after resurrection in order to check if modem is alive make sure battery is connected. To resurrect Huawei E5830:
05-12-2011, 14:36 | #155 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 12.05.2011 Samsung Galaxy Ace S5830 Unbrick – Boot repair supported Samsung S5830 resurrection is simple. Phone is auto powered when USB Data Cable is inserted while battery is inside. If you don’t use USB cable, make sure to hold Power On button during JTAG connection establishing phase. To resurrect Samsung S5830 do this:
The Following 2 Users Say Thank You to legija For This Useful Post: |
05-12-2011, 15:12 | #156 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | HTC_Legend.dll ------------------------------------- - fixed IMEI repair bug - added read unlock codes as it's done in all recent HTC DLLs |
The Following 8 Users Say Thank You to legija For This Useful Post: |
05-13-2011, 11:52 | #157 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 13.05.2011 Samsung Z630 Unbrick – Boot repair supported Resurrection of Samsung Z630 requires battery or external power supply. Most convenient way is to use additionally an USB cable: in this case power is auto powered on and there will be no need to hold power on key during connection startup. Please note, phone will be detected even with only USB cable connected, but stable connection and stable data exchange will be achieved only when battery (or external power supply) is connected too. To resurrect Samsung Z630:
The Following User Says Thank You to legija For This Useful Post: |
05-13-2011, 14:44 | #158 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Dopod Magic A6188 (HTC Sapp400) Unbrick, Unlock, IMEI and CID repair supported The HTC Magic (SAPP400) is based on ESM7206A chipset. Phone is auto powered on with USB Data Cable connected to the PC while battery is connected. In case you have no USB cable near, make sure battery is charged enough and hold Power On button during initiation of JTAG connection. Resurrector will reflash radio’s boot zone and will re-write PDA’s SPL to 1.53.02000 version. Additionally to SPL and Radio zones, the zone which contains Model ID is re-flashed too. Thus after resurrection phone will have Model ID = ‘SAPP*****’. Additionally, you can check ‘Repair RECOVERY zones’ to reflash android BOOT and RECOVERY code. To resurrect HTC Magic (SAPP400):
05-13-2011, 15:46 | #159 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 13.05.2011 CDMA Huawei C5589 Unbrick – Boot repair supported Resurrecting Huawei C5589 is simple. Phone is auto powered on with USB Cable connected to the PC. Battery presence is not required; connection can be established with detached board. Current resurrector contains Firmware and EEPROM zones for memory chip with ID 0x017E/0×2230 To resurrect Huawei C5589:
05-17-2011, 11:31 | #160 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Huawei_E5830.dll ------------------------------------- - Added ID 0xC01B00E1 to allowed list. So, now it will accespt: 0x901B10E1, 0xC01B00E1. - Added info to manual about login/password in case EFS2 area was flashed (cloned). |
05-19-2011, 13:41 | #161 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | HTC_HD7.dll ------------------------------------- - Added resurrection data for 2Kb NAND chips, so now DLL has data for both 4KB and 2KB versions. - Added reead unlock code as it's done in all recent HTC DLLs |
The Following 4 Users Say Thank You to legija For This Useful Post: |
05-19-2011, 15:28 | #162 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | HTC_Mozart.dll & HTC_Trophy ------------------------------------- - ModelID zone is not touched now, so RUU Invalid Model ID shall not happend now after resurrection Those with error 244 problem should flash phone with full backup, repair IMEI and then reflash phone. |
The Following 3 Users Say Thank You to legija For This Useful Post: |
05-20-2011, 10:28 | #163 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | QSC1100_X14_NOR, QSC60XX_L18_D08_NOR, QSC60XX_L20_D08_NOR, QSC60XX_L24_D08_NOR ---------------------------------------- - Embedded DCC Loaders are updated to the most recent ones. |
05-20-2011, 10:43 | #164 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Samsung_S5260.dll ------------------------------------- - JTAG pinout was wrong. Now is ok. |
05-20-2011, 12:46 | #165 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | 29.05.2011 More CDMA Models, Samsung S5250 Unbrick supported New CDMA models added today :
Does any one know how to program the ESN number with nokia 6120? | Bert | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-02-1999 10:45 |
SMS via system connector | pasisoft | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-21-1999 11:05 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
