11-18-2010, 21:34 | #1 (permalink) |
No Life Poster Join Date: May 2006
Member: 276432 Status: Offline Thanks Meter: 65 | Let's Make Big Target For XDA Atom Life here is the connected ID Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.15, JTAG Manager Version: 1.19 Selected Custom Target: [PXA270, 3.30V, 0-0-C-2] Connecting to the PXA270 target...OK Set I/O Voltage reads as 3.31V, TCK Frequency is 8 MHz Target ID on TAP(0-0-C-2): 0x79265013 - Connected OK this settings after make an jtag connection with 4 points only TDI - TDO - TCK - TMS - WE NEED NRST OR TRST I THINK PXA270 NEED TRST PIN ONLY ALSO WE NEED FILES FOR REPAIR HERE IS THE FULL INFO ABOUT JTAG BUT ATOM LIFE HAVE CPU TYPE IS PXA272 AND WE HAVE IN CUSTOM TARGET SETTINGS ONLY PXA270 Dead Boot Loader on O2 Atom, O2 Atom Exec, Rover G5, Orsio n725, HP68xx DeadBoot - XDA-Developers |
11-19-2010, 12:39 | #3 (permalink) | |
Freak Poster Join Date: Aug 2004 Location: Lithuania Age: 43
Member: 78090 Status: Offline Thanks Meter: 43 | Quote:
You are wrong - ATOM LIFE (AKA Atom APOLLO or O2 XDA Comet) has pxa270 CPU... other atom versions (and there is four of it) has pxa272 CPU... | |
11-20-2010, 12:12 | #8 (permalink) |
Member: 78090 Status: Offline Thanks Meter: 43 | Here it is... other testpoints are here: Dead Boot Loader on O2 Atom, O2 Atom Exec, Rover G5, Orsio n725, HP68xx DeadBoot - XDA-Developers |
11-20-2010, 18:39 | #9 (permalink) | |
Member: 276432 Status: Offline Thanks Meter: 65 | Quote:
11-20-2010, 19:06 | #11 (permalink) |
Member: 78090 Status: Offline Thanks Meter: 43 | Description in words: NRST - there is two resistors near crystal oscillator placed horizontally, nRST pin is rightmost contact of second (counting UP from oscillator) resistor. |
11-21-2010, 13:03 | #15 (permalink) |
Member: 78090 Status: Offline Thanks Meter: 43 | I haven't repaired it... i can communicate with CPU using RIFF, same as using WIGGLER ... hardware is not important. I can read, write memory (CPU's memory, but not flash chip), run from specified address and so on... But to repair this device you must have a ramloader, which you should write to CPU's RAM and execute it, then you would be able to write original device firmware with original bootloaders from SD card or USB... Problem is that there is no available such ramloader (at least i could not find), if you have enough skills you can write your own loader... |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
