11-26-2012, 11:03 | #1 (permalink) | |
Insane Poster Join Date: Jul 2005 Age: 39
Member: 158108 Status: Offline Thanks Meter: 7 | S5260 resurrection problem I got a dead S5260 (was flashed with S5230 BL). Resurrection was working but not the phone coz IMEI seems to be damaged. So I started to fullearase the phone. And now if i want to resurrection the phone I always gets this error: Quote:
12-14-2012, 06:33 | #4 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 263548 Status: Offline Thanks Meter: 24 | help fail for ressuection s5620 hi Mr BABAK NURI need help for ressuection s5620 Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung S5260 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - CORRECT! Set I/O Voltage reads as 3.00V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 100 kHz] Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x42): Communication is not established. Terminating. Any ideal?? THANKS |
12-14-2012, 08:11 | #5 (permalink) | |
Member: 263548 Status: Offline Thanks Meter: 24 | Quote:
Prolem sovled just resoldes the wire Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung S5260 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - CORRECT! Set I/O Voltage reads as 3.00V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at MAX] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0040 (256MB) Selected Resurrection Data for the NAND Chip with Page size = 2KB Flashing the dead body...OK Resurrection complete! | |
12-15-2012, 06:57 | #6 (permalink) | |
No luck phone after flash just saw samsung logo Help who was sovled this problem?? i try many flash file all same ... Phone come is working just ned unlock Any ideal all supporter??? | |
12-15-2012, 08:23 | #7 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | @ supermatrix -- Plz Erase Full Flash Size,Then Resurrect and Start "DL-Mode" With USB+Jig..... Flash With Multiloader, |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
01-03-2013, 06:46 | #9 (permalink) |
Member: 263548 Status: Offline Thanks Meter: 24 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung S5260 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - IGNORED! Set I/O Voltage reads as 3.00V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 8 MHz] Settings Code: 0x0501000E000000000000000010000000 Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0040 (256MB) Looking for the RIFF BOX DCCLoader USB Interface Port...FAILED The DCCLoader USB Interface is not found. Communication continues over the DCC Interface Erasing FLASH1 memory from 0x000000000000 to 0x00000FFFFFFF...OK WARNING: Erasing Error (0x24) at 0x000008D20000 is Ignored. Erase continues. WARNING: Erasing Error (0x24) at 0x000009260000 is Ignored. Erase continues. WARNING: Erasing Error (0x24) at 0x00000A8A0000 is Ignored. Erase continues. WARNING: Erasing Error (0x24) at 0x00000B5A0000 is Ignored. Erase continues. Completed in 00:00:22.141 (Average Transfer Rate: 11839.75 kB/s) Erassing error Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung S5260 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - IGNORED! Set I/O Voltage reads as 3.00V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 8 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0040 (256MB) Selected Resurrection Data for the NAND Chip with Page size = 2KB Flashing the dead body...OK Resurrection complete! Phone now totaly can go DL MODE HELP ALL SUPPORTER THANKS>>>>>>> |
01-06-2013, 02:39 | #13 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi I told you before in Post #7 ..... ANyway ,This is Complete Guides : RIFF JTAG Box FAQ - JTAG Manager - DCC Read/Write TAB |
