08-09-2012, 22:24 | #1 (permalink) |
Major Poster Join Date: Dec 2011 Location: Sofia, Bulgaria
Member: 1705542 Status: Offline Thanks Meter: 10 | Desire S - no GPS after resurrection This is the second one that lost the GPS after boot repair. Resurrection is performed at all levels (all options ticked). OS manage the GPS without any error, but found no satellites at all. Tried any radio and some fixes - unsuccessful. Any idea? Maybe reflashing some partitions from working phone? I didn't find a dump to try. BR dailor |
08-13-2012, 11:11 | #3 (permalink) |
Product Manager Join Date: Apr 2006 Age: 55
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Hi, There could be two reasons for non working GPS. - Antenna not assembled - Wrong driver loaded Since GPS is detected and handled, it's probably antenna problem. Though, it could be related to driver too, in this case You should check HW revision sticker and WLAN partition at 0x10000 offset. First four numbers are HW revision, it's from where OS knows which driver to load. |
The Following User Says Thank You to legija For This Useful Post: |
08-13-2012, 12:11 | #4 (permalink) | |
Member: 1705542 Status: Offline Thanks Meter: 10 | Quote:
If the values are different, I need to correct that in WLAN partition at 0x10000 offset, am I right? Thanks for the replay! | |
08-13-2012, 12:46 | #5 (permalink) |
Member: 256342 Status: Offline Sonork: None Thanks Meter: 28,276 | Thats usually small green sticker, mostly on or around usb connector. If its removed, there still should be date or production printed on PCB. This could help too, but You'll need to get HW revision ID from same date phone. |
08-13-2012, 13:44 | #7 (permalink) |
Member: 1705542 Status: Offline Thanks Meter: 10 | For some reason eMMC Partition Table Plugin does not read particular partitions when phone connected by DCC Loader USB Interface, am I wrong or missing something? |
08-13-2012, 14:51 | #8 (permalink) |
Member: 1705542 Status: Offline Thanks Meter: 10 | OK, I managed to change these 4 digits in WLAN partition at 0x10000 offset, but nothing happens with GPS - same situation. When looked closely in WLAN partition I found another instance of same value at 0x11070 offset. Did I need to change that too? |
08-13-2012, 15:27 | #9 (permalink) |
Member: 1705542 Status: Offline Thanks Meter: 10 | OK, the P-sensor also does not work properly. When make external call it offs the LCD every time without reason and if another side cancel or close (if answered), then the LCD can't turn on with power switch. Only reinserting the battery or connecting to USB brings it back. Could this be related to WLAN partition change and GPS issue? |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
6150 no outgoing calls | edis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-20-2000 20:19 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
"Menu 11"? after Net monitor | Pyron | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-09-1999 10:07 |
