S5560 boot repair error help me Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [Samsung S5560 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - CORRECT! WARNING: Embedded I/O Voltage is overriden to 3.30V Set I/O Voltage reads as 3.29V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: Wrong DCC data checksum. |
chek ground wire dear.......................... |
another DLL download please it may bug |
Hi Quote:
1-Check Soldered Wires 2-Connect Power supply then press and keep power on key or 2-Connect Power Supply and Usb Cable 3-Speed 4 or 6 or 8 Mhz at TCK......(Not 1mhz at RTCK Speed) ... S5560.dll Work Perfectly and not have any bug....Tested By many User |
Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [Samsung S5560 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - CORRECT! Set I/O Voltage reads as 3.00V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: Wrong DCC data checksum. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [Samsung S5560 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - CORRECT! Set I/O Voltage reads as 3.00V, TCK Frequency is 4 MHz Resurrection sequence started. Establish communication with the phone...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: Wrong DCC data checksum. I checked all the wires 6-8 MHz no result can be a model S5560i dll need |
Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [Samsung S5560i V1.00] Connecting to the dead body...OK Detected dead body ID: 0x07926F0F - CORRECT! Set I/O Voltage reads as 3.01V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...FAILED ERROR: No response from the RIFF Box. |
Hi Can you tell me about phone history? You can't repair s5560 via "i" dll -- Can you contact me via sonork with conected phone to Riff-Box...??? |
connection with BP response I can get in contact with you my time zone +5 (9:00 -18:00) I will at this time |
There is big chance that You have some HW problem on that board. My suggestion is, check PCB carefully for cracks and water damage. As I could see from the logs, PCB has developed some problem with RAM, so it could be cold soldering or PCB cracks. |
you're right HW problem on that board. maybe Thanks I look definitively |
