06-23-2013, 18:07 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: bangalore india
Member: 156994 Status: Offline Sonork: 100.1615423 Thanks Meter: 650 | htc one v i got a phone which is in dead condition . htc one v . when i connect to pc it takes drivers HS-USB QDLoader . riff box error like this please help |
06-24-2013, 00:02 | #2 (permalink) |
Member: 156994 Status: Offline Sonork: 100.1615423 Thanks Meter: 650 | Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.35, JTAG Manager Version: 1.49 Selected Resurrector: [HTC OneV (PK76100) via USB V1.0.4608.58885] Looking for the HS-USB QDLoader Interface...OK Open the HS-USB QDLoader Interface Port...OK Establish connection with the Device...OK Uploading resurrector data into memory...OK Starting communication with resurrector... |
06-24-2013, 00:04 | #3 (permalink) |
Member: 156994 Status: Offline Sonork: 100.1615423 Thanks Meter: 650 | this is all i get . and after 10 seconds it shows device not recognized in pc. if i reconnect i get hs-usb loader driver on pc . all blank screen . please help . is the emmc bad ? |
06-24-2013, 02:47 | #4 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi First,,,You Need Use TP For Resurrect Then,,,99/9% of One_V Have a eMMC Problem... You Need Replace |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
06-24-2013, 15:31 | #7 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi I Know....This is Reason Why I Told You About "Using TP" This not matter if pc can detect your phone at "QUHSB"....It's Important Using TP For Disable eMMC And Detected By DCC Loader ---- Anyway,,,,I'm Sure If You Use TP ,Even Detect eMMC ,Resurrector Can't Write Boot data |
06-24-2013, 15:32 | #8 (permalink) |
