Samsung I777 resurection complete but no download mode! So a customer brought me a samsung I777 for flashing because it was rooted using Chainfire's root kernel, but for I9100. After rooting the phone wifi was not working at all. So I tought I'll flash it back to stock I777 and job done. Now as I was trying to put the phone into download mode It went to recovery mode and I saw that it was a custom recovery or CWM if you will. So I took out the battery and started again but phone wouldn't power on at all. Practically dead. No connection to usb, nothing. So I started to repair it via jtag with riff. The first 3 times it did the job to 100% the error. Tried the 4th time a all was ok. Phone succesfully resurected. Or not. The phone does not power on at all. Tried multiple times. Now the phone was on original firmware but rooted nothing more. It was 2.3.6 and not any other leaked firmware that may have the brickbug. I just can't understand what happened. If anyone has an idea I'm willing to try it. I really need to get it working. Don't want to be an *** in front of my customer. Thank you in advance. |
Noone knows anything? Any ideas? |
Nope. Usb jig not working either. |
plz put full log for your resurrected |
[8/28/2012 1:16:47 PM] [START OPERATION_ID = RESURRECT] [8/28/2012 1:18:29 PM] Open serial port...OK [8/28/2012 1:18:29 PM] Connecting to the RIFF Box...OK [8/28/2012 1:18:29 PM] Firmware Version: 1.33, JTAG Manager Version: 1.44 [8/28/2012 1:18:29 PM] Selected Resurrector: [Samsung i777 V1.0.0.0] [8/28/2012 1:18:29 PM] [8/28/2012 1:18:29 PM] Connecting to the dead body...OK [8/28/2012 1:18:29 PM] Detected dead body ID: 0x4BA00477 - CORRECT! [8/28/2012 1:18:29 PM] Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz [8/28/2012 1:18:29 PM] [8/28/2012 1:18:29 PM] Resurrection sequence started. [8/28/2012 1:18:29 PM] Establish communication with the phone...OK [8/28/2012 1:18:29 PM] Initializing internal hardware configuration...OK [8/28/2012 1:18:29 PM] Uploading resurrector data into memory...OK [8/28/2012 1:18:29 PM] Starting communication with resurrector...OK [8/28/2012 1:18:29 PM] [8/28/2012 1:18:29 PM] Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) [8/28/2012 1:18:29 PM] Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (VYL00M, 0x000000080000 Bytes = 0.50 MB) [8/28/2012 1:18:29 PM] [8/28/2012 1:18:29 PM] Flashing the dead body...OK [8/28/2012 1:18:29 PM] Resurrection complete! [8/28/2012 1:18:29 PM] [FINISH OPERATION_ID = RESURRECT] Here is full log. |
Hi Quote:
Also,Please look firmware.tar ....may have "boot.bin" ? if yes,maybe can help: (But Don't Use i9100 Boot.bin) http://forum.gsmhosting.com/vbb/f634...ution-1508808/ |
[9/14/2012 3:29:31 PM] [START OPERATION_ID = DCC_WRITE_MEMORY] [9/14/2012 3:29:32 PM] [9/14/2012 3:29:32 PM] Current Settings: [9/14/2012 3:29:32 PM] ----------------- [9/14/2012 3:29:32 PM] Address: 000000000000 [9/14/2012 3:29:32 PM] Length: 000000008000 [9/14/2012 3:29:32 PM] Address Space: ROM2 [9/14/2012 3:29:32 PM] AutoFullFlash: UNCHECKED [9/14/2012 3:29:32 PM] Use End Address: UNCHECKED [9/14/2012 3:29:32 PM] ECC Module Enabled: UNCHECKED [9/14/2012 3:29:32 PM] Image File is Used: UNCHECKED [9/14/2012 3:29:32 PM] Use Address as Offset: CHECKED [9/14/2012 3:29:32 PM] Main (CHECKED): C:\GSM NEW\Riff Box\I777 boot\I777 boot.bin [9/14/2012 3:29:32 PM] Redu (UNCHECKED): [9/14/2012 3:29:32 PM] [9/14/2012 3:29:41 PM] Open serial port...OK [9/14/2012 3:29:41 PM] Connecting to the RIFF Box...OK [9/14/2012 3:29:41 PM] Firmware Version: 1.33, JTAG Manager Version: 1.44 [9/14/2012 3:29:41 PM] Selected Resurrector: [Samsung i777 V1.0.0.0] [9/14/2012 3:29:41 PM] [9/14/2012 3:29:41 PM] Connecting to the dead body...OK [9/14/2012 3:29:41 PM] Detected dead body ID: 0x4BA00477 - CORRECT! [9/14/2012 3:29:41 PM] Set I/O Voltage reads as 2.80V, TCK Frequency is 8 MHz [9/14/2012 3:29:41 PM] Settings Code: 0x22020B00000000000000000000008000 [9/14/2012 3:29:41 PM] [9/14/2012 3:29:41 PM] Resurrection sequence started. [9/14/2012 3:29:41 PM] Establish communication with the phone...OK [9/14/2012 3:29:41 PM] Initializing internal hardware configuration...OK [9/14/2012 3:29:41 PM] Uploading resurrector data into memory...OK [9/14/2012 3:29:41 PM] Starting communication with resurrector...OK [9/14/2012 3:29:41 PM] [9/14/2012 3:29:41 PM] Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) [9/14/2012 3:29:41 PM] Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (VYL00M, 0x000000080000 Bytes = 0.50 MB) [9/14/2012 3:29:41 PM] [9/14/2012 3:29:41 PM] Writting FLASH2 memory from 0x000000000000 to 0x000000007FFF [9/14/2012 3:29:41 PM] Completed in 00:00:04.860 (Average Transfer Rate: 6.58 kB/s) [9/14/2012 3:29:41 PM] [FINISH OPERATION_ID = DCC_WRITE_MEMORY] [9/14/2012 3:30:55 PM] [START OPERATION_ID = DCC_WRITE_MEMORY] [9/14/2012 3:30:55 PM] [9/14/2012 3:30:55 PM] Current Settings: [9/14/2012 3:30:55 PM] ----------------- [9/14/2012 3:30:55 PM] Address: 000000008000 [9/14/2012 3:30:55 PM] Length: 000000008000 [9/14/2012 3:30:55 PM] Address Space: ROM2 [9/14/2012 3:30:55 PM] AutoFullFlash: UNCHECKED [9/14/2012 3:30:55 PM] Use End Address: UNCHECKED [9/14/2012 3:30:55 PM] ECC Module Enabled: UNCHECKED [9/14/2012 3:30:55 PM] Image File is Used: UNCHECKED [9/14/2012 3:30:55 PM] Use Address as Offset: CHECKED [9/14/2012 3:30:55 PM] Main (CHECKED): C:\GSM NEW\Riff Box\I777 boot\I777 boot.bin [9/14/2012 3:30:55 PM] Redu (UNCHECKED): [9/14/2012 3:30:55 PM] [9/14/2012 3:31:01 PM] Open serial port...OK [9/14/2012 3:31:01 PM] Connecting to the RIFF Box...OK [9/14/2012 3:31:01 PM] Firmware Version: 1.33, JTAG Manager Version: 1.44 [9/14/2012 3:31:01 PM] Selected Resurrector: [Samsung i777 V1.0.0.0] [9/14/2012 3:31:01 PM] [9/14/2012 3:31:01 PM] Connecting to the dead body...OK [9/14/2012 3:31:01 PM] Detected dead body ID: 0x4BA00477 - CORRECT! [9/14/2012 3:31:01 PM] Set I/O Voltage reads as 2.80V, TCK Frequency is 8 MHz [9/14/2012 3:31:01 PM] Settings Code: 0x22020B00000000008000000000008000 [9/14/2012 3:31:01 PM] [9/14/2012 3:31:01 PM] Resurrection sequence started. [9/14/2012 3:31:01 PM] Establish communication with the phone...OK [9/14/2012 3:31:01 PM] Initializing internal hardware configuration...OK [9/14/2012 3:31:01 PM] Uploading resurrector data into memory...OK [9/14/2012 3:31:01 PM] Starting communication with resurrector...OK [9/14/2012 3:31:01 PM] [9/14/2012 3:31:01 PM] Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) [9/14/2012 3:31:01 PM] Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (VYL00M, 0x000000080000 Bytes = 0.50 MB) [9/14/2012 3:31:01 PM] [9/14/2012 3:31:01 PM] Writting FLASH2 memory from 0x000000008000 to 0x00000000FFFF [9/14/2012 3:31:01 PM] Completed in 00:00:04.516 (Average Transfer Rate: 7.09 kB/s) [9/14/2012 3:31:01 PM] [FINISH OPERATION_ID = DCC_WRITE_MEMORY] [9/14/2012 3:31:15 PM] [START OPERATION_ID = DCC_WRITE_MEMORY] [9/14/2012 3:31:15 PM] [9/14/2012 3:31:15 PM] Current Settings: [9/14/2012 3:31:15 PM] ----------------- [9/14/2012 3:31:15 PM] Address: 000000010000 [9/14/2012 3:31:15 PM] Length: 000000008000 [9/14/2012 3:31:15 PM] Address Space: ROM2 [9/14/2012 3:31:15 PM] AutoFullFlash: UNCHECKED [9/14/2012 3:31:15 PM] Use End Address: UNCHECKED [9/14/2012 3:31:15 PM] ECC Module Enabled: UNCHECKED [9/14/2012 3:31:15 PM] Image File is Used: UNCHECKED [9/14/2012 3:31:15 PM] Use Address as Offset: CHECKED [9/14/2012 3:31:15 PM] Main (CHECKED): C:\GSM NEW\Riff Box\I777 boot\I777 boot.bin [9/14/2012 3:31:15 PM] Redu (UNCHECKED): [9/14/2012 3:31:15 PM] [9/14/2012 3:31:21 PM] Open serial port...OK [9/14/2012 3:31:21 PM] Connecting to the RIFF Box...OK [9/14/2012 3:31:21 PM] Firmware Version: 1.33, JTAG Manager Version: 1.44 [9/14/2012 3:31:21 PM] Selected Resurrector: [Samsung i777 V1.0.0.0] [9/14/2012 3:31:21 PM] [9/14/2012 3:31:21 PM] Connecting to the dead body...OK [9/14/2012 3:31:21 PM] Detected dead body ID: 0x4BA00477 - CORRECT! [9/14/2012 3:31:21 PM] Set I/O Voltage reads as 2.80V, TCK Frequency is 8 MHz [9/14/2012 3:31:21 PM] Settings Code: 0x22020B00000000010000000000008000 [9/14/2012 3:31:21 PM] [9/14/2012 3:31:21 PM] Resurrection sequence started. [9/14/2012 3:31:21 PM] Establish communication with the phone...OK [9/14/2012 3:31:21 PM] Initializing internal hardware configuration...OK [9/14/2012 3:31:21 PM] Uploading resurrector data into memory...OK [9/14/2012 3:31:21 PM] Starting communication with resurrector...OK [9/14/2012 3:31:21 PM] [9/14/2012 3:31:21 PM] Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) [9/14/2012 3:31:21 PM] Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (VYL00M, 0x000000080000 Bytes = 0.50 MB) [9/14/2012 3:31:21 PM] [9/14/2012 3:31:21 PM] Writting FLASH2 memory from 0x000000010000 to 0x000000017FFF [9/14/2012 3:31:21 PM] Completed in 00:00:04.359 (Average Transfer Rate: 7.34 kB/s) [9/14/2012 3:31:21 PM] [FINISH OPERATION_ID = DCC_WRITE_MEMORY] [9/14/2012 3:31:58 PM] [START OPERATION_ID = DCC_WRITE_MEMORY] [9/14/2012 3:31:58 PM] [9/14/2012 3:31:58 PM] Current Settings: [9/14/2012 3:31:58 PM] ----------------- [9/14/2012 3:31:58 PM] Address: 000000018000 [9/14/2012 3:31:58 PM] Length: 000000008000 [9/14/2012 3:31:58 PM] Address Space: ROM2 [9/14/2012 3:31:58 PM] AutoFullFlash: UNCHECKED [9/14/2012 3:31:58 PM] Use End Address: UNCHECKED [9/14/2012 3:31:58 PM] ECC Module Enabled: UNCHECKED [9/14/2012 3:31:58 PM] Image File is Used: UNCHECKED [9/14/2012 3:31:58 PM] Use Address as Offset: CHECKED [9/14/2012 3:31:58 PM] Main (CHECKED): C:\GSM NEW\Riff Box\I777 boot\I777 boot.bin [9/14/2012 3:31:58 PM] Redu (UNCHECKED): [9/14/2012 3:31:58 PM] [9/14/2012 3:32:04 PM] Open serial port...OK [9/14/2012 3:32:04 PM] Connecting to the RIFF Box...OK [9/14/2012 3:32:04 PM] Firmware Version: 1.33, JTAG Manager Version: 1.44 [9/14/2012 3:32:04 PM] Selected Resurrector: [Samsung i777 V1.0.0.0] [9/14/2012 3:32:04 PM] [9/14/2012 3:32:04 PM] Connecting to the dead body...OK [9/14/2012 3:32:04 PM] Detected dead body ID: 0x4BA00477 - CORRECT! [9/14/2012 3:32:04 PM] Set I/O Voltage reads as 2.80V, TCK Frequency is 8 MHz [9/14/2012 3:32:04 PM] Settings Code: 0x22020B00000000018000000000008000 [9/14/2012 3:32:04 PM] [9/14/2012 3:32:04 PM] Resurrection sequence started. [9/14/2012 3:32:04 PM] Establish communication with the phone...OK [9/14/2012 3:32:04 PM] Initializing internal hardware configuration...OK [9/14/2012 3:32:04 PM] Uploading resurrector data into memory...OK [9/14/2012 3:32:04 PM] Starting communication with resurrector...OK [9/14/2012 3:32:04 PM] [9/14/2012 3:32:04 PM] Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0001 (VYL00M, 0x0003AB400000 Bytes = 14.68 GB) [9/14/2012 3:32:04 PM] Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0001 (VYL00M, 0x000000080000 Bytes = 0.50 MB) [9/14/2012 3:32:04 PM] [9/14/2012 3:32:04 PM] Writting FLASH2 memory from 0x000000018000 to 0x00000001FFFF [9/14/2012 3:32:04 PM] Completed in 00:00:04.359 (Average Transfer Rate: 7.34 kB/s) [9/14/2012 3:32:04 PM] [FINISH OPERATION_ID = DCC_WRITE_MEMORY] I tryed the trick with boot.bin extracted from an I777 original flash tar not working. I also had multiple error 0x3E. After pc restart it worked but still brick. I think this is a total brick. Corrupt Nand. Any other ideas I'm willing to try. Thanks everybody for the ideas so far. |
