eMMC Partition Table FullFlash Image Files Processing Plugin (eMMCDiskPartitions.dll)
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.35, JTAG Manager Version: 1.49
Selected Resurrector: [Samsung I9003 (via IRAM) V1.0.4464.49936]
Connecting to the dead body...OK
Detected dead body ID: 0x0B6D602F - CORRECT!
Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at MAX]
Settings Code: 0x00000000000000000000000020000000
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...OK
Starting communication with resurrector...OK
Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB)
Invalid length [0x000000000200]: It should be alighed to 0x1000 |
Reading FLASH1 address space from 0x000000040000 to 0x000000040FFF
Completed in 00:00:00.015 (Average Transfer Rate: 139810133.27 kB/s)
Completed in 00:00:00.031 (Average Transfer Rate: 3.15 kB/s)
Detected NAND Page = 0x1000 bytes
Detected NAND Block = 0x00040000 bytes
Partition Table is found in block: 0x0001
Total quantity of listed partitions: 0x000D Checking which Partition is blank...COMPLETE!
Following partitions are found to be completely blank:
Partition: IBL+PBL at 0000000000000000000000000003FFFF000000000000000000 00000000000000
Partition: EFS at 00000000000800000000000000A7FFFF000000000000000200 00000000000029
Partition: SBL at 0000000000A800000000000000BBFFFF000000000000002A00 0000000000002E
Partition: SBL2 at 0000000000BC00000000000000CFFFFF000000000000002F00 00000000000033
Partition: PARAM at 0000000000D0000000000000011FFFFF000000000000003400 00000000000047
Partition: KERNEL at 0000000001200000000000000197FFFF000000000000004800 00000000000065
Partition: RECOVERY at 000000000198000000000000020FFFFF000000000000006600 00000000000083
Partition: FACTORYFS at 00000000021000000000000013F7FFFF000000000000008400 000000000004FD
Partition: DBDATAFS at 0000000013F80000000000001C57FFFF00000000000004FE00 00000000000715
Partition: CACHE at 000000001C580000000000001E87FFFF000000000000071600 000000000007A1
Partition: MODEM at 000000001E880000000000001F4FFFFF00000000000007A200 000000000007D3
Partition: at 000000001F500000000000001FFFFFFF00000000000007D400 000000000007FF
and On access rom 2 address spase not found.
Selected Resurrector: [Samsung I9003 V1.00]
Set I/O Voltage reads as 2.62V, TCK Frequency is 8 MHz
Settings Code: 0x10020B00000000000000000020000000
ERROR: Selected FLASH2 Chip was not Recognized by the DCC Loader. Terminating.
does it mean to die of internal memory..??
any solution..??
Please help me..!
