09-22-2012, 16:20 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Location: indonesia
Member: 154427 Status: Offline Thanks Meter: 61 | i9000 still dead after boot repair... phone cannot go to download mode with 3 key combination. i use adb comand to go download mode. then i have only flash pit file and done,phone goes to restart and cannot on again.. i repair boot and sucses but still cannot go to download mode even i repair with glamin zone.. any idea? thanks for help.. |
09-22-2012, 16:36 | #2 (permalink) |
No Life Poster Join Date: Jul 2012
Member: 1783314 Status: Offline Sonork: 100.1620532 Thanks Meter: 127 | You need to flash 4 part stock rom ( pit, pda, phone, csc) after that the phone will boot normal and work and you will be able to use button combo for download mode |
09-22-2012, 17:39 | #4 (permalink) | |
Freak Poster Join Date: Sep 2009
Member: 1129443 Status: Offline Thanks Meter: 3 | Quote:
09-23-2012, 07:31 | #7 (permalink) |
Member: 154427 Status: Offline Thanks Meter: 61 | heres the log Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.33, JTAG Manager Version: 1.44 Selected Resurrector: [Samsung I9000 V1.00] Connecting to the dead body...OK Detected dead body ID: 0x1BA00477 - CORRECT! Set I/O Voltage reads as 2.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x00EC/0x0050 (512MB) Flashing the dead body...OK Resurrection complete! |
09-23-2012, 14:01 | #9 (permalink) |
Member: 154427 Status: Offline Thanks Meter: 61 | problem solved after Resurrector 3x... phone now have baseband unknown and don't have imei.. write efs with i9000 active plugin still unknown baseband and error imei.. any idea? |
