01-26-2013, 19:36 | #91 (permalink) |
Junior Member Join Date: Jan 2013 Location: spain
Member: 1861678 Status: Offline Thanks Meter: 0 | is not that hard to use, also, graba jig for put it into download mode and full flash, no MD5 flash, peace by peace csc, phone, boot, etc good luck |
01-26-2013, 19:37 | #92 (permalink) | |
Freak Poster Join Date: Jan 2006 Location: Sudan
Member: 219803 Status: Offline Sonork: 1582317 Thanks Meter: 38 | Quote:
I have same problem and I can not repair my phone | |
01-29-2013, 19:34 | #93 (permalink) |
Freak Poster Join Date: Oct 2001 Location: Moscow, Russia Age: 47
Member: 6653 Status: Offline Sonork: 100.1597550 Thanks Meter: 26 | Help me ! RIFF log: Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9070P V1.0.4705.16925] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.80V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x59): Communication is not established. Terminating. |
02-01-2013, 18:52 | #94 (permalink) |
No Life Poster Join Date: May 2010 Location: EGYPT Age: 39
Member: 1298774 Status: Offline Sonork: 100.1584126 Thanks Meter: 94 | ERROR(0x51) repair i9070 phone dead after flash by worng firmware Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x51): Communication is not established. Terminating. |
02-01-2013, 22:03 | #95 (permalink) | |
Junior Member Join Date: Dec 2012
Member: 1857622 Status: Offline Thanks Meter: 1 | Quote:
Repair logsIZE] Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9070 V1.0.4762.51152] Restarting target (nRST Low then High)...OK Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is 12 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0045/0x0000 (SEM08G, 0x0001D2000000 Bytes = 7.28 GB) Detected an Initialized FLASH2 Chip, ID: 0x0045/0x0000 (SEM08G, 0x000000200000 Bytes = 2.00 MB) Selected Resurrection Data for the eMMC Chip with Capacity = 7.28GB Flashing the dead body...OK Resurrection complete! | |
The Following User Says Thank You to mobile_pol For This Useful Post: |
02-03-2013, 21:33 | #96 (permalink) |
Junior Member Join Date: Nov 2004 Age: 41
Member: 90381 Status: Offline Thanks Meter: 5 | Help me ! Sometimes give me this error Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9070 V1.0.4762.51152] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is 12 MHz Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x59): Communication is not established. Terminating. or that Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9070 V1.0.4762.51152] Connecting to the dead body...OK Detected dead body ID: 0x4BA00477 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is 12 MHz Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x51): Communication is not established. Terminating. |
02-05-2013, 11:46 | #97 (permalink) |
Insane Poster Join Date: Feb 2013 Location: Iran Age: 34
Member: 1878895 Status: Offline Thanks Meter: 19 | Problem (Detected dead body ID: 0xFFFFFFFE - WRONG!!!) in I9070p Hi Every Body I have a I9070P phone. off by I9070 Frimware !!! I'm with Riff. I noticed the following messages? Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9070P V1.0.4705.16925] Connecting to the dead body...OK Detected dead body ID: 0xFFFFFFFE - WRONG!!! ERROR: Current ID does not belong to the Samsung I9070P family Thanks |
02-05-2013, 17:06 | #99 (permalink) | |
Member: 1878895 Status: Offline Thanks Meter: 19 | Quote:
I'm Ready "Resurrection Help". and Solder Jitag.. But Not Allowed... help me | |
02-07-2013, 13:40 | #100 (permalink) |
Freak Poster Join Date: Feb 2004 Location: 502-12 Age: 41
Member: 52985 Status: Offline Thanks Meter: 10 | same problem here , support team plz fix it Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [Samsung I9070 V1.0.4762.51152] Connecting to the dead body...OK Detected dead body ID: 0xFFFFFF00 - WRONG!!! ERROR: Current ID does not belong to the Samsung I9070 family. ps: phone is working (just wanted dump full flash) & i try 2pcs i9070 also same error |
02-08-2013, 13:36 | #101 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Current dll Work Propery Without Any Problem: Quote:
02-08-2013, 15:57 | #102 (permalink) |
No Life Poster Join Date: Aug 2004 Location: With old & new friends Age: 49
Member: 79640 Status: Offline Sonork: 1577251 Thanks Meter: 238 | Current thread is about I9070P and your log is from I9070. I was not able to ressurect I9070p with RIFF. http://forum.gsmhosting.com/vbb/f634...5/#post9174932 |
02-11-2013, 02:02 | #105 (permalink) |
Member: 79640 Status: Offline Sonork: 1577251 Thanks Meter: 238 | @Legija. No way to connect 02 samsung I9070p with Riff. Problem is not related to noise or Jtag wires or phone hardware because I can get Target Info with another jtag tool. with Riff, when trying resurrection, U8500 usb ROM device is detected for 2 or 3 seconds by PC then disconnected. With other JTAG tool device stays online. Sorry for talking about other tool in RIFF support forum, It is just to show that all is Ok with jtag wires !!! Anyway, RIFF is a very good JTAG tool !!!! I added you on Sonork, may be you can help me to reveive my phones !! |
