11-17-2014, 11:25 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: My Computer
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | [Need Help] Xperia LT30a bricked by repair pack available in support. Dear Riff box support i have bricked Xperia LT30a by doing resurrect with repair pack available in support. please help me to revive my phone. before this phone was working well with counter block (locked) and my mistake that i thought resurrection will show me what should i do as xperia x10 have many option in resurrection. so this bricked by pressing resurrection button. now only hardware connection sound and i am unable to flash this phone. setool log. Code: SIGNED MODE (USING SERVER) CFG:100000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... now suck on. Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Package: [SE LT30A V1.00 by <legija>] Connecting to the dead body...OK Detected dead body ID: 0x706B50E1 Set I/O Voltage reads as 1.81V, TCK Frequency is 8 MHz Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x42): Communication is not established. Terminating. Code: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.37, JTAG Manager Version: 1.56 Selected Package: [SE LT30A V1.00 by <legija>] Connecting to the dead body...OK Detected dead body ID: 0x706B50E1 Set I/O Voltage reads as 1.81V, TCK Frequency is 6 MHz Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...OK Starting communication with resurrector...OK Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (MAG2GA, 0x0003A3E00000 Bytes = 14.56 GB) Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (MAG2GA, 0x000000200000 Bytes = 2.00 MB) Flashing the dead body...OK Resurrection complete! |
11-26-2014, 07:25 | #4 (permalink) |
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | Created my own repair pack programing complete but phone still dead. i need dumped file plz share if anyone have or have phone in hands i can do. Code: [START OPERATION_ID = RESURRECT] [11/25/2014 6:08:15 AM] Open serial port...OK [11/25/2014 6:08:15 AM] Connecting to the RIFF Box...OK [11/25/2014 6:08:15 AM] Firmware Version: 1.37, JTAG Manager Version: 1.56 [11/25/2014 6:08:15 AM] Selected Package: [lt30a abdulhakeem V1.02 by <abdulhakeem>] [11/25/2014 6:08:15 AM] [11/25/2014 6:08:15 AM] Connecting to the dead body...OK [11/25/2014 6:08:15 AM] Detected dead body ID: 0x706B50E1 [11/25/2014 6:08:15 AM] Set I/O Voltage reads as 1.81V, TCK Frequency is 8 MHz [11/25/2014 6:08:15 AM] [11/25/2014 6:08:15 AM] Resurrection sequence started. [11/25/2014 6:08:15 AM] Establish communication with the phone...OK [11/25/2014 6:08:15 AM] Initializing internal hardware configuration...OK [11/25/2014 6:08:15 AM] Uploading resurrector data into memory...OK [11/25/2014 6:08:15 AM] Starting communication with resurrector...OK [11/25/2014 6:08:15 AM] [11/25/2014 6:08:15 AM] Detected an Initialized FLASH1 Chip, ID: 0x0015/0x0100 (MAG2GA, 0x0003A3E00000 Bytes = 14.56 GB) [11/25/2014 6:08:15 AM] Detected an Initialized FLASH2 Chip, ID: 0x0015/0x0100 (MAG2GA, 0x000000200000 Bytes = 2.00 MB) [11/25/2014 6:08:15 AM] [11/25/2014 6:08:15 AM] Flashing the dead body...OK [11/25/2014 6:08:15 AM] ERROR: Timeout while waiting for DCC Loader response. Trying to recover...OK [11/25/2014 6:08:15 AM] Resurrection complete! |
11-27-2014, 12:19 | #6 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi Resurrection pack as i know have only bootloader data,so possible have old data in repair pack then you have new bootloader in phone and some phone not accept downgrade ... so ,best ways is found other alive phone,Then flash with latest FW,Then Read dump,Then open dump in "eMMC Plugin" and Write only bootloader Partitions Like(SBL1,etc) But please take 128mb backup from your phone before doing anything...because if you damage TA,you can't repair |
12-01-2014, 08:12 | #7 (permalink) |
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | So if anyone have working phone in hands please read dump and past link under this post if anyone have problem reading this phone plz select HTC X8 dll to read dump. |
