02-04-2012, 19:48 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | HTC Desire S only PHD HS-USB QDLoader 9008 Port.. pc detects the phone as com port.. and not enter to dl mode and power on.. i tried boot repair but 3 pins are broken.. not exist.. i tried to scratch them and software not detect it again.. RUU is not detects phone.. any idea pls... PHD HS-USB QDLoader 9008 |
02-04-2012, 20:29 | #2 (permalink) | |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
Connecting to the RIFF Box...OK Firmware Version: 1.30, JTAG Manager Version: 1.38 Selected Resurrector: [HTC Desire S] Connecting to the dead body...OK Set I/O Voltage reads as 1.79V, TCK Frequency is RTCK Model selected: HTC - HTC Desire S Detected dead body ID: 0x07B360E1 Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.30, JTAG Manager Version: 1.38 Selected Resurrector: [HTC Desire S] Connecting to the target...OK Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x07B360E1, IR Length = 0x05 bits Total IR length: 0x0005 bits Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.30, JTAG Manager Version: 1.38 Selected Resurrector: [HTC Desire S] Connecting to the dead body...OK Detected dead body ID: 0x07B360E1 - WRONG!!! ERROR: Current ID does not belong to the HTC Desire S family. what is the reason of this warning..? weak connection..? flash ic damaged..? or unsupported flash ic..? | |
02-04-2012, 23:09 | #3 (permalink) | |
Detected TAP ID: 17B360E1, IR Length = 5. http://forum.gsmhosting.com/vbb/f664...2/#post8119099 | |
02-04-2012, 23:42 | #4 (permalink) | |
Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.30, JTAG Manager Version: 1.38 Selected Resurrector: [HTC Desire S] Connecting to the target...OK Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Following devices are found on the JTAG chain: Device on TAP #0: ID = 0xFFFFFFFF, IR Length = 0x05 bits Total IR length: 0x0005 bits and this, Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.30, JTAG Manager Version: 1.38 Selected Resurrector: [HTC Desire S] Connecting to the target...OK Set I/O Voltage reads as 1.80V, TCK Frequency is RTCK Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x00000000, IR Length = 0x05 bits Total IR length: 0x0005 bits | |
02-04-2012, 23:49 | #5 (permalink) |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | and i got this dead id but on analyze jtag chain... i think this is the right area. Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.30, JTAG Manager Version: 1.38 Selected Resurrector: [HTC Desire S] Connecting to the target...OK Set I/O Voltage reads as 1.80V, TCK Frequency is 200 kHz Following devices are found on the JTAG chain: Device on TAP #0: ID = 0x17B360E1, IR Length = 0x05 bits Total IR length: 0x0005 bits |
02-04-2012, 23:58 | #6 (permalink) | |
and finaly but comminicating with phone, Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.30, JTAG Manager Version: 1.38 Selected Resurrector: [HTC Desire S] Connecting to the dead body...OK Set I/O Voltage reads as 1.79V, TCK Frequency is 9 MHz Model selected: HTC - HTC Desire S Detected dead body ID: 0x17B360E1 R0 = 0x00000000 R6 = 0x00000000 R12 = 0x00000000 R1 = 0x00000000 R7 = 0x00000000 R13 = 0x00000000 R2 = 0x00000000 R8 = 0x00000000 R14 = 0x00000000 R3 = 0x00000000 R9 = 0x00000000 R15 = 0x00000000 R4 = 0x00000000 R10 = 0x00000000 CPSR = 0x00000000 R5 = 0x00000000 R11 = 0x00000000 Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.30, JTAG Manager Version: 1.38 Selected Resurrector: [HTC Desire S] Connecting to the dead body...OK Detected dead body ID: 0x17B360E1 - CORRECT! Set I/O Voltage reads as 1.79V, TCK Frequency is 9 MHz Resurrection sequence started. Establish communication with the phone...FAILED ERROR: No response from the RIFF Box. | |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
Only MAX232 ??? | AMIGO | Nokia Hardware & Hardware Repair | 7 | 04-12-2000 09:41 |
Is it possible to use the Nokia 6150 with the IR Port of a Toshiba Laptop? | telefonman | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-13-2000 20:06 |
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed | spterminator | Main Sales Section | 0 | 08-08-1999 05:08 |
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only | spterminator | Main Sales Section | 0 | 08-01-1999 05:46 |
