05-23-2013, 07:01 | #363 (permalink) |
Freak Poster Join Date: May 2013 Location: IRAN__SHIRAZ
Member: 1933631 Status: Offline Sonork: 100.1618169 Thanks Meter: 52 | plz tell me how team support i9300???? but friest read this post... http://forum.gsmhosting.com/vbb/f634...i9300-1465412/ br majidinia |
The Following 2 Users Say Thank You to ALI MAJIDINIA For This Useful Post: |
05-23-2013, 07:06 | #364 (permalink) |
No Life Poster Join Date: Feb 2008 Location: KABUPATEN SLEMAN
Member: 714648 Status: Offline Sonork: 1609640 Thanks Meter: 931 | no one have success for repair I9300 anyone just say try and try when u try maybe same like other show downloading failed waiting who have successfull for repair this |
05-23-2013, 22:38 | #365 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi This is not true.... I did repair over 20 pcs with SD Method I can take photo or make video if you can't blive this Please Note: All Suddenly dead phone ,Have a HW Problem And You Can't Repair Via SD or Jtag Like I9100,N7000....You Can See in every where on Forum...Many user have a "0x3e) error or Repair done Then can't turn on This is HW Problem and we need replace eMMC usually I Have Preprogramed eMMC Also Blank Chip for I9300..... I use this method for blank chip.....Work Properly..... Please Note Again.....This SW Released By Samsung...So,How That is Possible Not Work???? |
The Following 3 Users Say Thank You to BABAK NURI For This Useful Post: |
05-24-2013, 14:37 | #366 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 714291 Status: Offline Thanks Meter: 39 | Am also having trouble with s3 i9300 dead boot i followed the procedure you mentioned , but the normal powered phones failed to load GT-I9300_Boot_Recoverythe and now two phones can't power on just stuck on "firmware upgrade encountered an issue.Please select recovery mode in kies & try again" i tried flashing fully but still end up on that screen please help to revive them Thank you |
05-25-2013, 15:32 | #369 (permalink) |
Junior Member Join Date: May 2013
Member: 1946079 Status: Offline Thanks Meter: 0 | My Galaxy Nexus has completely died but shows up as OMAP4440 when I plug it in without the battery. I installed the OMAP flash driver thing and when I plugged the phone in then it showed up as OMAP4460 instead (is this correct behaviour?) and then ran the .bat file, that gave me this. Code: OMAPFlash v4.15 (Aug 12 2011) » -v » Entering parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.txt at line : 1 » -omap 4 » -t 36000 » -p OMAP4460_TUNA_8G_HS_PRO » -2 » chip_download EMMC Targets\Projects\tuna\MLO_4460_HS_PRO » chip_download EMMC Targets\Projects\tuna\sbl.img » command cold_sw_reset » Leaving parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.txt » @targets\Projects\tuna\omap4460_tuna_hs_pro.txt » Looking for device (omap usb) » Please turn on device » Waiting for device (omap usb) » Found device (omap usb) » Requesting ASIC id » AsicId items 05 » AsicId id 01 05 01 44 40 07 01 » AsicId secure_mode 13 02 01 00 » AsicId public_id 12 15 01 AB E3 1B 06 16 F3 D4 39 BD 96 8D D3 24 29 8A 18 26 43 4B 31 » AsicId root_key_hash 14 21 01 67 98 9B 35 54 CC 86 B4 67 32 47 05 36 74 E2 25 F0 9D A3 5C F4 59 B9 C9 3A 13 E0 B9 58 1E 5A BC » AsicId checksum 15 09 01 22 9E 85 BA DC 58 74 BC » Searching 2nd for: OMAP4460_TUNA_8G_HS_PRO 444007 01 HS » Loading second file Targets/2nd-Downloaders/dnld_startup_omap4_hs_8g_es2.s2.si gned.2nd.hs_pro » Entering parameter file:omapflash2nd.txt at line: 46 » -pheriphalboot_reopen » Reading board configuration file Targets\Configurations\configuration_omap4460 _tuna_8g.txt » Reading definition file .\targets\definitions\definitions_omap4.txt » -board_config Targets\Configurations\configuration_omap4460_tuna_8g.txt » Leaving parameter file:omapflash2nd.txt » Sending size of second file (0x000071B0 bytes) » Transferring second file to target (0x71B0 bytes) » Closing boot connection » Found device (omap usb) » Waiting for 2nd » Found 2nd » Looking for a driver for 'EMMC' » chip_driver EMMC Targets\Flash-Drivers\emmc_drv.bin sid 0 width 4 delay 9 rpap i_base 0x00030400 » Downloading driver » Downloading 'Targets\Flash-Drivers\emmc_drv.bin' » Sending data (47160 bytes) :::::::::::::::::::: [47160] » Download failed (final data response error): Remote: : Fail: Wrong driver vers ion expected OMAPFLASH DRIVER v6 got OMAPF└ASH DRI└ER v6 » Elapsed time: 0:00.038 (1241052 bytes/s) » Operation FAILED (Remote: : Fail: Wrong driver version expected OMAPFLASH DRIV ER v6 got OMAPF└ASH DRI└ER v6) » Elapsed time: 0:08.355 Tryck ned valfri tangent för att fortsätta... Code: » OMAPFlash v4.15 (Aug 12 2011) » -v » Entering parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.txt at line : 1 » -omap 4 » -t 36000 » -p OMAP4460_TUNA_8G_HS_PRO » -2 » chip_download EMMC Targets\Projects\tuna\MLO_4460_HS_PRO » chip_download EMMC Targets\Projects\tuna\sbl.img » command cold_sw_reset » Leaving parameter file:Targets\Projects\tuna\omap4460_tuna_hs_pro.txt » @targets\Projects\tuna\omap4460_tuna_hs_pro.txt » Looking for device (omap usb) » Please turn on device » Waiting for device (omap usb) » Found device (omap usb) » Requesting ASIC id » AsicId items 05 » AsicId id 01 05 01 44 40 07 01 » AsicId secure_mode 13 02 01 00 » AsicId public_id 12 15 01 AB E3 1B 06 16 F3 D4 39 BD 96 8D D3 24 29 8A 18 26 43 4B 31 » AsicId root_key_hash 14 21 01 67 98 9B 35 54 CC 86 B4 67 32 47 05 36 74 E2 25 F0 9D A3 5C F4 59 B9 C9 3A 13 E0 B9 58 1E 5A BC » AsicId checksum 15 09 01 22 9E 85 BA DC 58 74 BC » Searching 2nd for: OMAP4460_TUNA_8G_HS_PRO 444007 01 HS » Loading second file Targets/2nd-Downloaders/dnld_startup_omap4_hs_8g_es2.s2.si gned.2nd.hs_pro » Entering parameter file:omapflash2nd.txt at line: 46 » -pheriphalboot_reopen » Reading board configuration file Targets\Configurations\configuration_omap4460 _tuna_8g.txt » Reading definition file .\targets\definitions\definitions_omap4.txt » -board_config Targets\Configurations\configuration_omap4460_tuna_8g.txt » Leaving parameter file:omapflash2nd.txt » Sending size of second file (0x000071B0 bytes) » Transferring second file to target (0x71B0 bytes) » Closing boot connection » Found device (omap usb) » Waiting for 2nd » Found 2nd » Looking for a driver for 'EMMC' » chip_driver EMMC Targets\Flash-Drivers\emmc_drv.bin sid 0 width 4 delay 9 rpap i_base 0x00030400 » Downloading driver » Downloading 'Targets\Flash-Drivers\emmc_drv.bin' » Sending data (47160 bytes) :::::::::::::....... [32768] |
05-29-2013, 08:15 | #372 (permalink) | |
No Life Poster Join Date: Feb 2012 Location: Romania Age: 41
Member: 1722871 Status: Offline Thanks Meter: 116 | Quote:
I wrote here how to do the backup http://forum.gsmhosting.com/vbb/9080787-post246.html But I am sure you already know how to do this Thx | |
06-13-2013, 10:24 | #374 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 895045 Status: Offline Thanks Meter: 14 | legija,pls help.i9250 write success but still dead. Code: » Downloading 'Targets\Flash-Drivers\emmc_drv.bin' » Sending data (47160 bytes) :::::::::::::::::::: [47160] Interface 'OMAPFLASH DRIVER v6' Driver 'eMMC JESD84-A43' Driver configuration: sid = 0x00000000 Driver configuration: width = 0x00000004 Driver configuration: delay = 0x00000009 Driver configuration: rpapi_base = 0x00030400 MMC sid = 0x00 MMC mmc_volt = 0x01 MMC data_width = 0x04 MMC card_rca = 0x04 MMC card_type = 0x03 MMC data_width_support = 0x08 MMC transfer_clk_max = 0xBB80 MMC card_size = 0x1D5A000 eMMC CID MID = 0x15 // Manufacturer ID eMMC CID CBX = 0x01 // Card/BGA eMMC CID OID = 0x00 // OEM/Application ID eMMC CID PNM = 0xDEDE00001FEF // Product name eMMC CID PRV = 0x25 // Product revision eMMC CID PSN = 0x00001FEF // Product serial numbe r eMMC CID MDT = 0x1F // Manufacturing date eMMC CID CRC = 0x77 // CRC7 checksum eMMC CSD CSD_STRUCTURE = 0x03 // CSD structure eMMC CSD SPEC_VERS = 0x04 // System specification version eMMC CSD TAAC = 0x27 // Data read access-tim e 1 eMMC CSD NSAC = 0x01 // Data read access-tim e 2 in CLK cycles (NSAC*100) eMMC CSD TRAN_SPEED = 0x32 // Max. bus clock frequ ency eMMC CSD CCC = 0x00F5 // Card command classes eMMC CSD READ_BL_LEN = 0x09 // Max. read data block length eMMC CSD READ_BL_PARTIAL = 0x00 // Partial blocks for r ead allowed eMMC CSD WRITE_BLK_MISALIGN = 0x00 // Write block misalign ment eMMC CSD READ_BLK_MISALIGN = 0x00 // Read block misalignm ent eMMC CSD DSR_IMP = 0x00 // DSR implemented eMMC CSD C_SIZE = 0x00FF // Device size eMMC CSD VDD_R_CURR_MIN = 0x06 // Max. read current @ VDD min eMMC CSD VDD_R_CURR_MAX = 0x06 // Max. read current @ VDD max eMMC CSD VDD_W_CURR_MIN = 0x06 // Max. write current @ VDD min eMMC CSD VDD_W_CURR_MAX = 0x06 // Max. write current @ VDD max eMMC CSD C_SIZE_MULT = 0x01 // Device size multipli er eMMC CSD ERASE_GRP_SIZE = 0x1F // Erase group size eMMC CSD ERASE_GRP_MULT = 0x1F // Erase group size mul tiplier eMMC CSD WP_GRP_SIZE = 0x0F // Write protect group size eMMC CSD WP_GRP_ENABLE = 0x01 // Write protect group enable eMMC CSD DEFAULT_ECC = 0x00 // Manufacturer default ECC eMMC CSD R2W_FACTOR = 0x02 // Write speed factor eMMC CSD WRITE_BL_LEN = 0x09 // Max. write data bloc k length eMMC CSD WRITE_BL_PARTIAL = 0x00 // Partial blocks for w rite allowed eMMC CSD CONTENT_PROT_APP = 0x00 // Content protection a pplication eMMC CSD FILE_FORMAT_GRP = 0x00 // File format group eMMC CSD COPY = 0x01 // Copy flag (OTP) eMMC CSD PERM_WRITE_PROTECT = 0x00 // Permanent write prot ection eMMC CSD TMP_WRITE_PROTECT = 0x00 // Temporary write prot ection eMMC CSD FILE_FORMAT = 0x00 // File format eMMC CSD ECC = 0x00 // ECC code eMMC CSD CRC = 0x33 // CRC eMMC EXT_CSD S_CMD_SET = 0x00 // Supported Command Se ts eMMC EXT_CSD BOOT_INFO = 0x15 // Boot information eMMC EXT_CSD BOOT_SIZE_MULTI = 0x0A // Boot partition size eMMC EXT_CSD ACC_SIZE = 0x07 // Access size eMMC EXT_CSD HC_ERASE_GRP_SIZE = 0x00 // High-capacity erase unit size eMMC EXT_CSD ERASE_TIMEOUT_MULT = 0x04 // High-capacity erase timeout eMMC EXT_CSD REL_WR_SEC_C = 0x07 // Reliable write secto r count eMMC EXT_CSD HC_WP_GRP_SIZE = 0x01 // High-capacity write protect group size eMMC EXT_CSD S_C_VCC = 0x01 // Sleep current (VCC) eMMC EXT_CSD S_C_VCCQ = 0x01 // Sleep current (VCCQ) eMMC EXT_CSD S_A_TIMEOUT = 0x07 // Sleep/awake timeout eMMC EXT_CSD SEC_COUNT = 0x01D5A000 // Sector Count eMMC EXT_CSD MIN_PERF_W_8_52 = 0xA0 // Minimum Write Perfor mance for 8bit at 52MHz eMMC EXT_CSD MIN_PERF_R_8_52 = 0x00 // Minimum Read Perform ance for 8bit at 52MHz eMMC EXT_CSD MIN_PERF_W_8_26_4_52 = 0x00 // Minimum Write Perfor mance for 8bit at 26MHz, for 4bit at 52MHz eMMC EXT_CSD MIN_PERF_R_8_26_4_52 = 0x00 // Minimum Read Perform ance for 8bit at 26MHz, for 4bit at 52MHz eMMC EXT_CSD MIN_PERF_W_4_26 = 0x00 // Minimum Write Perfor mance for 4bit at 26MHz eMMC EXT_CSD MIN_PERF_R_4_26 = 0x00 // Minimum Read Perform ance for 4bit at 26MHz eMMC EXT_CSD PWR_CL_26_360 = 0x00 // Power class for 26MH z at 3.6V eMMC EXT_CSD PWR_CL_52_360 = 0x00 // Power class for 52MH z at 3.6V eMMC EXT_CSD PWR_CL_26_195 = 0x00 // Power class for 26MH z at 1.95V eMMC EXT_CSD PWR_CL_52_195 = 0x00 // Power class for 52MH z at 1.95V eMMC EXT_CSD CARD_TYPE = 0x01 // Card type eMMC EXT_CSD CSD_STRUCTURE = 0x00 // CSD structure versio n eMMC EXT_CSD EXT_CSD_REV = 0x00 // Extended CSD revisio n eMMC EXT_CSD CMD_SET = 0x02 // Command set eMMC EXT_CSD CMD_SET_REV = 0x05 // Command set revision eMMC EXT_CSD POWER_CLASS = 0x00 // Power class eMMC EXT_CSD HS_TIMING = 0x00 // High-speed interface timing eMMC EXT_CSD BUS_WIDTH = 0x00 // Bus width mode eMMC EXT_CSD ERASED_MEM_CONT = 0x00 // Erased memory conten t eMMC EXT_CSD BOOT_CONFIG = 0x00 // Boot configuration eMMC EXT_CSD BOOT_BUS_WIDTH = 0x00 // Boot bus width1 eMMC EXT_CSD ERASE_GROUP_DEF = 0x00 // High-density erase g roup definition EMMC eMMC DRIVER INIT COMPLETE » Downloading complete » Elapsed time: 0:09.390 (5070 bytes/s) » End loading driver » Downloading » Downloading 'Targets\Projects\tuna\MLO_4460_HS_PRO' » Sending data (131072 bytes) :::::::::::::::::::: [131072] » Downloading complete » Elapsed time: 0:00.579 (226376 bytes/s) » Looking for a driver for 'EMMC' » chip_driver EMMC Targets\Flash-Drivers\emmc_drv.bin sid 0 width 4 delay 9 rpap i_base 0x00030400 » Downloading driver EMMC eMMC DRIVER DEINIT COMPLETE » Downloading 'Targets\Flash-Drivers\emmc_drv.bin' » Sending data (47160 bytes) :::::::::::::::::::: [47160] Interface 'OMAPFLASH DRIVER v6' Driver 'eMMC JESD84-A43' Driver configuration: sid = 0x00000000 Driver configuration: width = 0x00000004 Driver configuration: delay = 0x00000009 Driver configuration: rpapi_base = 0x00030400 MMC sid = 0x00 MMC mmc_volt = 0x01 MMC data_width = 0x04 MMC card_rca = 0x04 MMC card_type = 0x03 MMC data_width_support = 0x08 MMC transfer_clk_max = 0xBB80 MMC card_size = 0x1D5A000 eMMC CID MID = 0x15 // Manufacturer ID eMMC CID CBX = 0x01 // Card/BGA eMMC CID OID = 0x00 // OEM/Application ID eMMC CID PNM = 0xDEDE00001FEF // Product name eMMC CID PRV = 0x25 // Product revision eMMC CID PSN = 0x00001FEF // Product serial numbe r eMMC CID MDT = 0x1F // Manufacturing date eMMC CID CRC = 0x77 // CRC7 checksum eMMC CSD CSD_STRUCTURE = 0x03 // CSD structure eMMC CSD SPEC_VERS = 0x04 // System specification version eMMC CSD TAAC = 0x27 // Data read access-tim e 1 eMMC CSD NSAC = 0x01 // Data read access-tim e 2 in CLK cycles (NSAC*100) eMMC CSD TRAN_SPEED = 0x32 // Max. bus clock frequ ency eMMC CSD CCC = 0x00F5 // Card command classes eMMC CSD READ_BL_LEN = 0x09 // Max. read data block length eMMC CSD READ_BL_PARTIAL = 0x00 // Partial blocks for r ead allowed eMMC CSD WRITE_BLK_MISALIGN = 0x00 // Write block misalign ment eMMC CSD READ_BLK_MISALIGN = 0x00 // Read block misalignm ent eMMC CSD DSR_IMP = 0x00 // DSR implemented eMMC CSD C_SIZE = 0x00FF // Device size eMMC CSD VDD_R_CURR_MIN = 0x06 // Max. read current @ VDD min eMMC CSD VDD_R_CURR_MAX = 0x06 // Max. read current @ VDD max eMMC CSD VDD_W_CURR_MIN = 0x06 // Max. write current @ VDD min eMMC CSD VDD_W_CURR_MAX = 0x06 // Max. write current @ VDD max eMMC CSD C_SIZE_MULT = 0x01 // Device size multipli er eMMC CSD ERASE_GRP_SIZE = 0x1F // Erase group size eMMC CSD ERASE_GRP_MULT = 0x1F // Erase group size mul tiplier eMMC CSD WP_GRP_SIZE = 0x0F // Write protect group size eMMC CSD WP_GRP_ENABLE = 0x01 // Write protect group enable eMMC CSD DEFAULT_ECC = 0x00 // Manufacturer default ECC eMMC CSD R2W_FACTOR = 0x02 // Write speed factor eMMC CSD WRITE_BL_LEN = 0x09 // Max. write data bloc k length eMMC CSD WRITE_BL_PARTIAL = 0x00 // Partial blocks for w rite allowed eMMC CSD CONTENT_PROT_APP = 0x00 // Content protection a pplication eMMC CSD FILE_FORMAT_GRP = 0x00 // File format group eMMC CSD COPY = 0x01 // Copy flag (OTP) eMMC CSD PERM_WRITE_PROTECT = 0x00 // Permanent write prot ection eMMC CSD TMP_WRITE_PROTECT = 0x00 // Temporary write prot ection eMMC CSD FILE_FORMAT = 0x00 // File format eMMC CSD ECC = 0x00 // ECC code eMMC CSD CRC = 0x33 // CRC eMMC EXT_CSD S_CMD_SET = 0x00 // Supported Command Se ts eMMC EXT_CSD BOOT_INFO = 0x15 // Boot information eMMC EXT_CSD BOOT_SIZE_MULTI = 0x0A // Boot partition size eMMC EXT_CSD ACC_SIZE = 0x07 // Access size eMMC EXT_CSD HC_ERASE_GRP_SIZE = 0x00 // High-capacity erase unit size eMMC EXT_CSD ERASE_TIMEOUT_MULT = 0x04 // High-capacity erase timeout eMMC EXT_CSD REL_WR_SEC_C = 0x07 // Reliable write secto r count eMMC EXT_CSD HC_WP_GRP_SIZE = 0x01 // High-capacity write protect group size eMMC EXT_CSD S_C_VCC = 0x01 // Sleep current (VCC) eMMC EXT_CSD S_C_VCCQ = 0x01 // Sleep current (VCCQ) eMMC EXT_CSD S_A_TIMEOUT = 0x07 // Sleep/awake timeout eMMC EXT_CSD SEC_COUNT = 0x01D5A000 // Sector Count eMMC EXT_CSD MIN_PERF_W_8_52 = 0xA0 // Minimum Write Perfor mance for 8bit at 52MHz eMMC EXT_CSD MIN_PERF_R_8_52 = 0x00 // Minimum Read Perform ance for 8bit at 52MHz eMMC EXT_CSD MIN_PERF_W_8_26_4_52 = 0x00 // Minimum Write Perfor mance for 8bit at 26MHz, for 4bit at 52MHz eMMC EXT_CSD MIN_PERF_R_8_26_4_52 = 0x00 // Minimum Read Perform ance for 8bit at 26MHz, for 4bit at 52MHz eMMC EXT_CSD MIN_PERF_W_4_26 = 0x00 // Minimum Write Perfor mance for 4bit at 26MHz eMMC EXT_CSD MIN_PERF_R_4_26 = 0x00 // Minimum Read Perform ance for 4bit at 26MHz eMMC EXT_CSD PWR_CL_26_360 = 0x00 // Power class for 26MH z at 3.6V eMMC EXT_CSD PWR_CL_52_360 = 0x00 // Power class for 52MH z at 3.6V eMMC EXT_CSD PWR_CL_26_195 = 0x00 // Power class for 26MH z at 1.95V eMMC EXT_CSD PWR_CL_52_195 = 0x00 // Power class for 52MH z at 1.95V eMMC EXT_CSD CARD_TYPE = 0x01 // Card type eMMC EXT_CSD CSD_STRUCTURE = 0x00 // CSD structure versio n eMMC EXT_CSD EXT_CSD_REV = 0x00 // Extended CSD revisio n eMMC EXT_CSD CMD_SET = 0x02 // Command set eMMC EXT_CSD CMD_SET_REV = 0x05 // Command set revision eMMC EXT_CSD POWER_CLASS = 0x00 // Power class eMMC EXT_CSD HS_TIMING = 0x00 // High-speed interface timing eMMC EXT_CSD BUS_WIDTH = 0x00 // Bus width mode eMMC EXT_CSD ERASED_MEM_CONT = 0x00 // Erased memory conten t eMMC EXT_CSD BOOT_CONFIG = 0x00 // Boot configuration eMMC EXT_CSD BOOT_BUS_WIDTH = 0x00 // Boot bus width1 eMMC EXT_CSD ERASE_GROUP_DEF = 0x00 // High-density erase g roup definition EMMC eMMC DRIVER INIT COMPLETE » Downloading complete » Elapsed time: 0:04.180 (11500 bytes/s) » End loading driver » Downloading » Downloading 'Targets\Projects\tuna\sbl.img' » Sending data (1835008 bytes) :::::::::::::::::::: [1835008] » Downloading complete » Elapsed time: 0:02.464 (764580 bytes/s) » cold_sw_reset » Elapsed time: 0:21.081 Press any key to continue . . . |
06-17-2013, 04:58 | #375 (permalink) |
Freak Poster Join Date: May 2001 Location: Philippine/Bermuda Age: 49
Member: 4691 Status: Offline Thanks Meter: 42 | Please gentlemen if anyone who can prove that the solution truly exist please make a video and dont post to much photos because i dont believe taking pictures which can be easy to alter and make some foolish magic evidence.As we always say, ( ACTION SPEAKS LOUDER THAN WORDS ) right? before people admitting they have fix 5,20,100pcs of i9300 and N7100 please make a solid evidence not making believe of your self if you can't prove a thing in VIDEO not Photos ok??? this threading is getting no where to find the right solution. i am sick and tired watching the post they say this Oh i fix already many phones but where is the evidence?? no bluffing please we are serious to find the way to repair. i hope this will bring out the attention to all B.R. |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
I am looking for information about GSM-CABLES.NE | DUPOND | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 08-03-1999 15:29 |
Selling original Nokia DAU9P cable | TheDon | Main Sales Section | 0 | 07-21-1999 15:44 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
