Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > RIFF Box Team > RIFFBOX
Old 10-06-2013, 14:05   #406 (permalink)
Member: 1166351
Thanks Meter: 3
i9300
i am new on riff box.... untill now still not support i9300 on riff
Old 11-14-2013, 13:08   #407 (permalink)
Member: 2065256
How repair a i9250?
How repair a i9250? Plz! (((
Old 11-19-2013, 19:25   #408 (permalink)
Member: 459220
Sonork: 100.1590597
Thanks Meter: 85
» Downloading 'Targets\Flash-Drivers\emmc_drv.bin'
» Sending data (47160 bytes) :::::::::::::::::::: [47160]
Interface 'OMAPFLASH DRIVER v6'
Driver 'eMMC JESD84-A43'
Driver configuration: sid = 0x00000000
Driver configuration: width = 0x00000004
Driver configuration: delay = 0x00000009
Driver configuration: rpapi_base = 0x00030400
MMC sid = 0x00
MMC mmc_volt = 0x01
MMC data_width = 0x04
MMC card_rca = 0x04
MMC card_type = 0x03
MMC data_width_support = 0x08
MMC transfer_clk_max = 0xBB80
MMC card_size = 0x1D5A000
eMMC CID MID = 0x15 // Manufacturer ID
eMMC CID CBX = 0x01 // Card/BGA
eMMC CID OID = 0x00 // OEM/Application ID
eMMC CID PNM = 0x23600000BEA5 // Product name
eMMC CID PRV = 0x25 // Product revision
eMMC CID PSN = 0x0000BEA5 // Product serial numbe
r
eMMC CID MDT = 0xBE // Manufacturing date
eMMC CID CRC = 0x52 // CRC7 checksum
eMMC CSD CSD_STRUCTURE = 0x03 // CSD structure
eMMC CSD SPEC_VERS = 0x04 // System specification
version
eMMC CSD TAAC = 0x27 // Data read access-tim
e 1
eMMC CSD NSAC = 0x01 // Data read access-tim
e 2 in CLK cycles (NSAC*100)
eMMC CSD TRAN_SPEED = 0x32 // Max. bus clock frequ
ency
eMMC CSD CCC = 0x00F5 // Card command classes
eMMC CSD READ_BL_LEN = 0x09 // Max. read data block
length
eMMC CSD READ_BL_PARTIAL = 0x00 // Partial blocks for r
ead allowed
eMMC CSD WRITE_BLK_MISALIGN = 0x00 // Write block misalign
ment
eMMC CSD READ_BLK_MISALIGN = 0x00 // Read block misalignm
ent
eMMC CSD DSR_IMP = 0x00 // DSR implemented
eMMC CSD C_SIZE = 0x00FF // Device size
eMMC CSD VDD_R_CURR_MIN = 0x06 // Max. read current @
VDD min
eMMC CSD VDD_R_CURR_MAX = 0x06 // Max. read current @
VDD max
eMMC CSD VDD_W_CURR_MIN = 0x06 // Max. write current @
VDD min
eMMC CSD VDD_W_CURR_MAX = 0x06 // Max. write current @
VDD max
eMMC CSD C_SIZE_MULT = 0x01 // Device size multipli
er
eMMC CSD ERASE_GRP_SIZE = 0x1F // Erase group size
eMMC CSD ERASE_GRP_MULT = 0x1F // Erase group size mul
tiplier
eMMC CSD WP_GRP_SIZE = 0x0F // Write protect group
size
eMMC CSD WP_GRP_ENABLE = 0x01 // Write protect group
enable
eMMC CSD DEFAULT_ECC = 0x00 // Manufacturer default
ECC
eMMC CSD R2W_FACTOR = 0x02 // Write speed factor
eMMC CSD WRITE_BL_LEN = 0x09 // Max. write data bloc
k length
eMMC CSD WRITE_BL_PARTIAL = 0x00 // Partial blocks for w
rite allowed
eMMC CSD CONTENT_PROT_APP = 0x00 // Content protection a
pplication
eMMC CSD FILE_FORMAT_GRP = 0x00 // File format group
eMMC CSD COPY = 0x01 // Copy flag (OTP)
eMMC CSD PERM_WRITE_PROTECT = 0x00 // Permanent write prot
ection
eMMC CSD TMP_WRITE_PROTECT = 0x00 // Temporary write prot
ection
eMMC CSD FILE_FORMAT = 0x00 // File format
eMMC CSD ECC = 0x00 // ECC code
eMMC CSD CRC = 0x33 // CRC
eMMC EXT_CSD S_CMD_SET = 0x00 // Supported Command Se
ts
eMMC EXT_CSD BOOT_INFO = 0x15 // Boot information
eMMC EXT_CSD BOOT_SIZE_MULTI = 0x0A // Boot partition size
eMMC EXT_CSD ACC_SIZE = 0x07 // Access size
eMMC EXT_CSD HC_ERASE_GRP_SIZE = 0x00 // High-capacity erase
unit size
eMMC EXT_CSD ERASE_TIMEOUT_MULT = 0x04 // High-capacity erase
timeout
eMMC EXT_CSD REL_WR_SEC_C = 0x07 // Reliable write secto
r count
eMMC EXT_CSD HC_WP_GRP_SIZE = 0x01 // High-capacity write
protect group size
eMMC EXT_CSD S_C_VCC = 0x01 // Sleep current (VCC)
eMMC EXT_CSD S_C_VCCQ = 0x01 // Sleep current (VCCQ)
eMMC EXT_CSD S_A_TIMEOUT = 0x07 // Sleep/awake timeout
eMMC EXT_CSD SEC_COUNT = 0x01D5A000 // Sector Count
eMMC EXT_CSD MIN_PERF_W_8_52 = 0xA0 // Minimum Write Perfor
mance for 8bit at 52MHz
eMMC EXT_CSD MIN_PERF_R_8_52 = 0x00 // Minimum Read Perform
eMMC EXT_CSD MIN_PERF_W_8_26_4_52 = 0x00 // Minimum Write Perfor
mance for 8bit at 26MHz, for 4bit at 52MHz
eMMC EXT_CSD MIN_PERF_R_8_26_4_52 = 0x00 // Minimum Read Perform
eMMC EXT_CSD MIN_PERF_W_4_26 = 0x00 // Minimum Write Perfor
mance for 4bit at 26MHz
eMMC EXT_CSD MIN_PERF_R_4_26 = 0x00 // Minimum Read Perform
eMMC EXT_CSD PWR_CL_26_360 = 0x00 // Power class for 26MH
z at 3.6V
eMMC EXT_CSD PWR_CL_52_360 = 0x00 // Power class for 52MH
z at 3.6V
eMMC EXT_CSD PWR_CL_26_195 = 0x00 // Power class for 26MH
z at 1.95V
eMMC EXT_CSD PWR_CL_52_195 = 0x00 // Power class for 52MH
z at 1.95V
eMMC EXT_CSD CARD_TYPE = 0x01 // Card type
eMMC EXT_CSD CSD_STRUCTURE = 0x00 // CSD structure versio
n
eMMC EXT_CSD EXT_CSD_REV = 0x00 // Extended CSD revisio
n
eMMC EXT_CSD CMD_SET = 0x02 // Command set
eMMC EXT_CSD CMD_SET_REV = 0x05 // Command set revision
eMMC EXT_CSD POWER_CLASS = 0x00 // Power class
eMMC EXT_CSD HS_TIMING = 0x00 // High-speed interface
timing
eMMC EXT_CSD BUS_WIDTH = 0x00 // Bus width mode
eMMC EXT_CSD ERASED_MEM_CONT = 0x00 // Erased memory conten
t
eMMC EXT_CSD BOOT_CONFIG = 0x00 // Boot configuration
eMMC EXT_CSD BOOT_BUS_WIDTH = 0x00 // Boot bus width1
eMMC EXT_CSD ERASE_GROUP_DEF = 0x00 // High-density erase g
roup definition
EMMC eMMC DRIVER INIT COMPLETE
» Downloading complete
» Elapsed time: 0:00.496 (95080 bytes/s)
» End loading driver
» Downloading
» Downloading 'Targets\Projects\tuna\MLO_4460_HS_PRO'
» Sending data (131072 bytes) :::::::::::::::::::: [131072]
» Elapsed time: 0:00.210 (624152 bytes/s)
» Looking for a driver for 'EMMC'
» chip_driver EMMC Targets\Flash-Drivers\emmc_drv.bin sid 0 width 4 delay 9 rpap
i_base 0x00030400
» Downloading driver
EMMC eMMC DRIVER DEINIT COMPLETE
MMC sid = 0x00
MMC mmc_volt = 0x01
MMC card_rca = 0x04
r
version
e 1
ency
length
ead allowed
ment
ent
VDD min
VDD max
VDD min
VDD max
er
tiplier
size
enable
ECC
k length
rite allowed
pplication
ection
ection
ts
unit size
timeout
r count
protect group size
z at 3.6V
z at 3.6V
z at 1.95V
z at 1.95V
n
n
timing
t
roup definition
» Elapsed time: 0:00.446 (105739 bytes/s)
» Downloading
» Downloading 'Targets\Projects\tuna\sbl.img'
» Sending data (1835008 bytes) :::::::::::::::::::: [1835008]
» Elapsed time: 0:01.590 (1223330 bytes/s)
» cold_sw_reset
» Elapsed time: 0:07.553
i repair boot with this sw , and ok phone turn in mode download ,
but when i flash with odin or other tools freeze iN XLOADER
<ID:0/195> Get PIT for mapping..
<ID:0/195> Firmware update start..
<ID:0/195> xloader.img
<ID:0/195> NAND Write Start!!
<ID:0/195>
please help me
THXS advc
Old 12-17-2013, 14:04   #409 (permalink)
Member: 1306214
Sonork: ANSASRIHENZ
legiji samsung i9100g rar password plzzzzzzzzzzz sir
Old 12-17-2013, 15:55   #410 (permalink)
Member: 6884
Sonork: 100.1621477
Thanks Meter: 105
use this:
File-Upload.net - omap4430hs_espresso_Inter-i9100g.rar
this is international file, the link from legija is for chinese firmware
Old 12-18-2013, 06:10   #411 (permalink)
Member: 1306214
Sonork: ANSASRIHENZ
good share sirrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
Old 01-13-2014, 18:30   #412 (permalink)
manule's Avatar
Member: 786607
Thanks Meter: 66
» Waiting for device (omap usb)
» Found device (omap usb)
» Requesting ASIC id
» AsicId items 05
» AsicId id 01 05 01 44 40 07 01
» AsicId secure_mode 13 02 01 00
» AsicId public_id 12 15 01 9D 24 5C 2B B8 77 45 B8 C1 80
98 41 CC F1 CB
» AsicId root_key_hash 14 21 01 67 98 9B 35 54 CC 86 B4 67 32
25 F0 9D A3 5C F4 59 B9 C9 3A 13 E0 B9 58 1E 5A BC
» AsicId checksum 15 09 01 22 9E 85 BA DC 58 74 BC
» Searching 2nd for: OMAP4430_8G_HS 444007 01 HS
» Error no 2nd for: OMAP4430_8G_HS 444007 01 HS
Drücken Sie eine beliebige Taste . . .
C:\Users\dellamino\Desktop\omap4430hs_espresso_Int er i9100g>GOTO
» OMAPFlash v4.15 (Aug 12 2011)
» -v
» Entering parameter file:Targets\Projects\espresso\omap4430hs_1
ne: 1
» -omap 4
» -t 36000
» -p OMAP4430_8G_HS
» -2
» chip_download EMMC Targets\Projects\espresso\MLO.hs
» chip_download EMMC Targets\Projects\espresso\Sbl.bin
» command cold_sw_reset
» Leaving parameter file:Targets\Projects\espresso\omap4430hs_12
» @Targets\Projects\espresso\omap4430hs_1200MHZ.txt
» Looking for device (omap usb)
» Please turn off device
» Please turn on device
» Unable to read ASIC id. Searched 32 bytes of data - no ASIC ID
» -v
ne: 1
» -omap 4
» -t 36000
» -p OMAP4430_8G_HS
» -2
» AsicId items 05
98 41 CC F1 CB
Old 02-24-2014, 08:06   #413 (permalink)
Member: 1913544
Thumbs up so good
thank for sharing
Old 04-14-2014, 12:59   #414 (permalink)
Member: 183410
Thanks Meter: 7
google nexus s dead ripear
try this team cam help u
https://www.facebook.com/pages/Dead-...1983066?ref=hl
Old 07-15-2014, 19:53   #415 (permalink)
bhiret's Avatar
Member: 1295624
Thanks Meter: 151
Originally Posted by legija View Post
For galaxy S3 GT-i9300, please carefully read this:
  • Euro/Asian models are based on 4 core Samsung Exynos 4412 CPU
  • JTAG access in all i9300 phones is DISABLED (password protected)and password is not available (yet).
  • Repair procedure for bricked phones is performed via SD card
This archive contains repair guide and files.
I'd like to ask all RIFF users to be patient, for some phones for now there is no tested solution (SD card download failed).
We are working on the problem and may come with solution at some point, but it is also possible that there will be no solution at all, besides replacing eMMC or programming it via external programmer.
Please DO NOT ask me anything about this model on Sonork or ICQ.
As with all other solutions, once we have it, we will release it.
If You wish to experiment and possibly You have device with unsecured MCU, You can use Exynos 4412 DLL for DCC operations (DCC TAB and eMMC Plugin).
Secured MCU will return 0x44 error code, and unsecured MCU will be accessible.
GT-I9250:
Just execute *.bat file from this package.
Installing drivers first would be pretty smart idea too.
Google
Enjoy !
Edit:
For i9100G phones which have ID 0xFFFFFFFE, download this archive, unpack and run *.bat file from root folder:
Thanks to R3IS
Google.
i9250 live again thanks bro
Old 08-03-2014, 18:01   #416 (permalink)
Member: 1858019
Unlock code Samsung Galaxy Nexus GT-I9250
Hi,
I have a 4 year old Galaxy Nexus (GT-I9250) and used it these years in Vodafone Romania.
Now I need to use it in other network, but it seems to be SIM network locked.
Can you help me with an unlock code, please?
The IME is 351554050459750.
Thank you in advance.
Old 01-08-2015, 15:33   #417 (permalink)
Member: 2324400
1. I’ve installed drivers
2. Have launched a bat file
3. Have connected the phone with extended battery
4. Have run the script, it worked without errors, see the output code below.
dropbox[dot]com/s/kg3gssae7mcv5k6/omap[dot]txt?dl=0
After rebooting the phone, the problems have not gone away - the phone continues to restart, it also impossible to delete anything from it before turning off. As far as I see, the file system continues to be read only.
I’ve got one more question, ‘Sending data’ ends at 1835008 bytes, this is 1.835 MB (megabytes), although my phone for 16 GB. Does this mean that EMMC memory has been broken? Or this is software problem?
Again, the phone is loaded and running 30-60 seconds, during this time you can run applications, watch videos, etc.
Does anyone have any ideas?
Old 01-09-2015, 07:46   #418 (permalink)
Member: 3658
Thanks Meter: 66
I have same problem .
Phone start normal but after 5 - 10 sec restart .
Try to hard reset and flash firmware but not result.
Old 01-18-2016, 00:23   #419 (permalink)
Member: 2503297
dead i9250 SOLVED
halo every 1.
for i9250 hard breaked just download it with omap 4460 if it does not work open it and warm it with hot air then reassemble . power on
worked for me
Old 04-06-2017, 04:11   #420 (permalink)
Member: 1612077
Can anyone help with LG Optimus L9 ?
It has 4GB memory , I have aboot and uboot image with me.
Running abobe script with changing aboot and uboot from my phone doesn't work.
How can I port this script to new device. Please anyone know . Give some knowledge on this topic
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
I am looking for information about GSM-CABLES.NE DUPOND Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 08-03-1999 15:29
Selling original Nokia DAU9P cable TheDon Main Sales Section 0 07-21-1999 15:44
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.28814 seconds with 9 queries
