Unbrick htc one s problem.... hi i have problem for unlock htc one s:confused::confused::confused: Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC OneS (PJ4010000) V1.0.4734.57977] Connecting to the dead body...OK Detected dead body ID: 0x000000E1 - WRONG!!! ERROR: Current ID does not belong to the HTC OneS (PJ4010000) family. Help.... Thanks |
3 Attachment(s) Jtag read/write funtion Help Mr legija THANKS |
You need change the TCK speed to lower, 1 MHz first |
no luck:(:(:( Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC OneS (PJ4010000) V1.0.4734.57977] Connecting to the dead body...OK Detected dead body ID: 0x407910E1 - CORRECT! Set I/O Voltage reads as 1.81V, TCK Frequency is 1 MHz Resurrection sequence started. Establish communication with the phone...FAILED ERROR(0x44): Communication is not established. Terminating. Help..... |
You need do it with your patience One S often get this Error, you need charge the battery by power supply for 15-20 minutes, then try again. Here is my result in Vietnamese forum, you can see pictures and log: HTC Ville (One S S4) T-Mobile repair boot OK HTC One S repair boot - Super CID - Repair IMEI OK |
Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC OneS (PJ4010000) V1.0.4734.57977] Connecting to the dead body...OK Detected dead body ID: 0x407910E1 - CORRECT! Set I/O Voltage reads as 1.78V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...FAILED ERROR: Read/Write memory failed during H/W Init. help..... @Hoayeu105 thank for reply |
Please start using RIFF error codes database ! http://forum.gsmhosting.com/vbb/f634...-more-1476587/ |
Please Read : RIFF JTAG Box FAQ - Detected dead body ID: 0x000000E1 - WRONG!!! -------- Also Plz Connect Phone to RIFF-Box,Then Contact Me Via Sonork... I teach you How You Can Solve Your Problem |
Open serial port...OK Connecting to the RIFF Box...OK Firmware Version: 1.34, JTAG Manager Version: 1.48 Selected Resurrector: [HTC OneS (PJ4010000) V1.0.4734.57977] Connecting to the dead body...OK Detected dead body ID: 0x407910E1 - CORRECT! Set I/O Voltage reads as 1.78V, TCK Frequency is RTCK Adaptive Clocking RTCK Sampling is: [Sample at 2 MHz] Resurrection sequence started. Establish communication with the phone...OK Initializing internal hardware configuration...OK Uploading resurrector data into memory...FAILED ERROR: RAM memory selftest failed. no luck get many error... Any idael?? |
