04-29-2018, 20:58 | #2 (permalink) |
Product Supporter Join Date: May 2004 Location: INDIA Age: 55
Member: 65063 Status: Offline Thanks Meter: 2,419 | This topic will serve as initial guide for RIFF Box eMMC ISP/Direct functionality. This is not regular update, but rather a major upgrade. As such, it will come free for all RIFF Boxes registered in last 6 months, and of course for all new RIFF Box customers. To prepare everything on Your side for this upgrade, You'll need the following: RJ45 cable 2x100 ohms resistors External source for VCC and VCCQ (Optional) Moorc adapters (Optional) Activation credits (If Your box is older than 6 months) RJ45 cable is required to connect RIFF Box to eMMC as RIFF Box RJ45 port is used for this function. 2x100 Ohms resistors are required as pull up, to increase signal levels and improve stability. Extarnal source for VCC and VCCQ is required in case that You don't want to open Your RIFF Box, in order to connect RIFF Box internal VCC voltage source. We know that there are already some adapters on market, which offer this function. Moorc adapters are well known, and they offer best at price range. RIFF Box RJ45 port pinout: 1-NC 2-SD_CLK 3-SD_DAT0 4-SD_CMD 5-NC 6-NC 7-NC 8-GND VCC pin is located on RIFF Box motherboard, bottom side. You can locate it if You check attached photo. Pull up resistors should be connected from VCCQ to both SD_CMD and SD_DAT0 lines. regards, |
The Following User Says Thank You to ~AKSingh~ For This Useful Post: |
04-29-2018, 21:03 | #3 (permalink) |
Member: 65063 Status: Offline Thanks Meter: 2,419 | One can use Rc1000 adopter This one is working exellent with RiFF Box V1 regards, |
05-14-2018, 21:25 | #5 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: IN MY PC
Member: 745721 Status: Offline Sonork: 100.1605292 Thanks Meter: 2,390 | Quote:
