Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 10-18-2020, 16:05   #1 (permalink)
Member: 2763156
Thanks Meter: 28
Any plan of fixing Nokia C3 identification?
Recently I borrowed a Nokia C3 sold in Mainland China (TA-1258), and it cannot be recognized by Infinity BEST NK2 properly.
Card found : xxxxxxxx , v0122
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20
Operation : Identify [FTM] [ v1.20 ]
-> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable
-> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear
Wait for phone...
Connect Ok!
Device Found!
Initialize ...
Error : Fail to init protocol!
Remove battery, cable. Check cable and connection. Repeat operation!
Reconnect Power/Cable!
I tried all of the ports, and the same PC can recognize Nokia 7.2 properly. The driver is pulled from HMD Device Kit 1.0.17.2.
Executing fastboot oem getsecurityversion will return 3 FYI.
Also from what I have acknowledged, this device utilized a special build of PackageDownload that requires online authorization for flashing - either generic Infinity CM2SP2 or ResearchDownload won't flash it properly.
And of course, I've already got the stock firmware (both CN and Global).
Old 10-18-2020, 17:31   #2 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hi,
You know about "online authorization for flashing" - it's good. There is no alternative solution for it at the moment.
And yes, more work regarding [BEST] improvements is in progress.
please upload flash files for investigation via IOS File Uploader Tool
Old 10-19-2020, 02:10   #3 (permalink)
Member: 2763156
Thanks Meter: 28
Originally Posted by YellowBoss View Post
Hi,
Of course I know it since 2018 when processing FIH-made models, but the problem is BEST NK2 even cannot output identification of GamoraPlus😂
I believe @JayDi will have access of these files.
Old 10-19-2020, 02:16   #4 (permalink)
Member: 2763156
Thanks Meter: 28
Output of "fastboot oem getversions":
(bootloader) model=Nokia C3
(bootloader) sub_model=nokia_cn
(bootloader) software version=00CN_1_040
(bootloader) SW model=00CN
(bootloader) build number=A01
(bootloader) hardware version=V01
(bootloader) RF band id=RF_BAND_ID
OKAY [  0.030s]
Finished. Total time: 0.039s
Actually I found the stock OS (CN) of Nokia C3 is disgusting and no update since release. But the Global release of Nokia C3 is getting update frequently.
Page generated in 0.13711 seconds with 8 queries
