03-13-2013, 16:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: india. kerala.
Member: 1245320 Status: Offline Sonork: 100.1612126 Thanks Meter: 140 | n9 cant on..?? Connect phone on selected interface... Connect phone on selected interface... Check : Processing DFL61_HARMATTAN_40.2012.21-3.262.3_PR_LEGACY_262_ARM_RM-696_PRD_signed.bin ========== FW APE version : 40.2012.21-3.262.3 FW CMT version : 9.2.2011.51 FW PRx release : PR_1.3 FW Region info : BRANDED TO CARRIER FW Region ver : 262 KERNEL version : 2.6.32-20121301+0m8 ========== Check : File Is Ok ! Check : Processing DFL61_HARMATTAN_40.2012.21-3.SEAP.23_EMMC_SEAP.bin ========== eMMC version : DFL61_HARMATTAN_40.2012.21-3.SEAP.23 ========== Check : File Is Ok ! Core : v1.61 , Tablet FlashEngine : v2.9 Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RM-696 , HWRev : 1501 NOLO : 01/06/23 SWVer: DFL61_HARMATTAN_40.2012.21-3.262.3_PR_262 Device mode : Production mode ========== FW APE version : 40.2012.21-3.262.3 FW PRx release : PR_1.3 FW Region info : BRANDED TO CARRIER FW Region ver : 262 ========== Read info Ok === SW version Check ==== Ok [Reflashing or Upgrade] === SW version Check ==== Processing APE Boot... File : DFL61_HARMATTAN_40.2012.21-3.262.3_PR_LEGACY_262_ARM_RM-696_PRD_signed.bin Processing : ape-algo APE Algorithm boot Ok Reopening the connection... RFS mode init Ok Device : RM-696 HW build : 1501 Bat.level : 100 SW release : (empty) Protocol : 108 UPDAPP ver : 1.7.2 Upd/Dev PT : 3 , 3 FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mm c,tar,cmt-2nd,cmt-algo,cmt-mcusw Last errors : bb5_rdc_cert_read failed Code Match Ok HW match Ok RFS : Performing FULL WIPE... Starting Wipe... Bat.level : 100 Battery voltage is enough, starting wipe... Formatting... Can take up to 15-50 minutes, wait until process complete Do not disconnect phone, until done! Stage #1 : Swap format Ok RFS : No any errors Stage #2 : eMMC format Ok RFS : No any errors RFS Set : Host Protocol set to 108 RFS Set : CMT Verify On RFS Set : Perform RFS On RFS Set : eMMC preserve Off ---Processing MCU image--- Processing File : DFL61_HARMATTAN_40.2012.21-3.262.3_PR_LEGACY_262_ARM_RM-696_PRD_signed.bin RFS : Sending config for [cert-sw] -> Ver T : RM-696 -> Ver H : 1501 , 1502 RFS : Init pipe 00 RFS : Flashing... RFS : Finalizing... cert-sw Flash done RFS : Sending config for [kernel] -> Ver I : 2.6.32-20121301+0m8 RFS : Init pipe 01 RFS : Flashing... RFS : Finalizing... kernel Flash done RFS : Sending config for [rootfs] -> Ver I : DFL61_HARMATTAN_40.2012.21-3.262.3_PR_262 RFS : Init pipe 02 RFS : Flashing... RFS : Finalizing... rootfs Flash done RFS : Sending config for [cmt-2nd] -> Ver T : RM-696 RFS : Init pipe 03 RFS : Flashing... RFS : Finalizing... cmt-2nd Flash done RFS : Sending config for [cmt-algo] -> Ver T : RM-696 RFS : Init pipe 04 RFS : Flashing... RFS : Finalizing... cmt-algo Flash done RFS : Sending config for [cmt-mcusw] -> Ver I : 9.2.2011.51 -> Ver T : RM-696 RFS : Init pipe 05 RFS : Flashing... RFS : Finalizing... cmt-mcusw Flash done RFS : Sending config for [xloader] -> Ver I : 2.3.6+0m7 -> Ver T : RM-696 -> Ver H : 1501 , 1502 RFS : Init pipe 06 RFS : Flashing... RFS : Finalizing... xloader Flash done RFS : Sending config for [secondary] -> Ver I : 2.3.6+0m7 -> Ver T : RM-696 -> Ver H : 1501 , 1502 RFS : Init pipe 07 RFS : Flashing... RFS : Finalizing... secondary Flash done Switch : OSSO UART+USB Version : DFL61_HARMATTAN_40.2012.21-3.262.3_PR_262 Update SW release Ok ---Processing eMMC image--- Processing File : DFL61_HARMATTAN_40.2012.21-3.SEAP.23_EMMC_SEAP.bin RFS : Sending config for [mmc] -> Ver I : DFL61_HARMATTAN_40.2012.21-3.SEAP.23 RFS : Init pipe 08 RFS : Flashing... RFS : Finalizing... RFS : ERROR_PIPE_FINAL_REQ FAILED Receiving error list... Last errors : No any errors Flashing failed More info in Last Error Log Elapsed: 00:10:11 Connect phone on selected interface... |
