Asah 301 flash done with Best dongle Here is logs Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x16 IF xCPUID : XGOLD 618 [XMM6180 QUARK] IF uCHIPID : 2020D1E0493EA8B6 IF Resp Data : 50A9070100030101E0001809 Wait for user action : Insert battery Sending EBL Loader ... EBL Loader Ok EBL Loader ready Sending EBL ... EBL sent Ok EBL : QUARK_1315.400_M1S1 QUARK EEP config Ok FLASHID : EC004000 , [ MuxOneNAND ] Boot conf set, Target Ready Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 3572760531***** IMEI 2 : 35727605****** NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357276053****7_CRT .rpl ===Flashing [MCU]=== Processing file : rm839__02.33.mcusw Region count : 8 00 : psi_flash_unsigned.fls 01 : slb_signed.fls 02 : main_toc_signed.fls 03 : rm839__02.33.mcusw_signed_mcusw.fls 04 : swap_signed.fls 05 : dynsw.fls 06 : aeneas_signed.fls 07 : fota_signed.fls Parse done , flashing now Processing image : 00 : psi_flash_unsigned.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x00090000 , Len : 0x00020000 Erase now... Erase done Load region psi_flash_unsigned.fls Region Start : 0x00090000 , Data Len : 0x00010FB0 Region Load done psi_flash_unsigned.fls image flash done Processing image : 01 : slb_signed.fls Sending Sec-Pack SecInfo Area : 0x0001 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60000000 , Len : 0x00040000 Erase now... Erase done Load region slb_signed.fls Region Start : 0x60000000 , Data Len : 0x00040000 Region Load done slb_signed.fls image flash done Processing image : 02 : main_toc_signed.fls Sending Sec-Pack SecInfo Area : 0x0002 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x60040000 , Len : 0x00000400 Erase now... Erase done Load region main_toc_signed.fls Region Start : 0x60040000 , Data Len : 0x00000400 Region Load done main_toc_signed.fls image flash done Processing image : 03 : rm839__02.33.mcusw_signed_mcusw.fls Sending Sec-Pack SecInfo Area : 0x0003 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x62E00000 , Len : 0x01100000 Erase now... Erase done Erase area 0x01 , Start 0xFFF00000 , Len : 0x00080000 Erase now... Erase done Load region rm839__02.33.mcusw_signed_mcusw.fls Region Start : 0x62E00000 , Data Len : 0x00F05210 Region Load done rm839__02.33.mcusw_signed_mcusw.fls image flash done Processing image : 04 : swap_signed.fls Sending Sec-Pack SecInfo Area : 0x0004 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x80000000 , Len : 0x00F00000 Erase now... Erase done Load region swap_signed.fls Region Start : 0x80000000 , Data Len : 0x00C1B3CC Region Load done swap_signed.fls image flash done Processing image : 05 : dynsw.fls Sending Sec-Pack SecInfo Area : 0x0005 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x62080000 , Len : 0x00100000 Erase now... Erase done Load region dynsw.fls Region Start : 0x62080000 , Data Len : 0x00044000 Region Load done dynsw.fls image flash done Processing image : 06 : aeneas_signed.fls Sending Sec-Pack SecInfo Area : 0x0006 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x63F79C00 , Len : 0x00080000 Erase now... Erase done Load region aeneas_signed.fls Region Start : 0x63F79C00 , Data Len : 0x00046870 Region Load done aeneas_signed.fls image flash done Processing image : 07 : fota_signed.fls Sending Sec-Pack SecInfo Area : 0x0007 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x61F00004 , Len : 0x0017FFFC Erase now... Erase done Load region fota_signed.fls Region Start : 0x61F00004 , Data Len : 0x00145478 Region Load done fota_signed.fls image flash done ===Flashing [PPM]=== Processing file : rm839__02.33.ppm_m3 Region count : 1 00 : package_m3.ppm_ebl_psi.fls Parse done , flashing now Processing image : 00 : package_m3.ppm_ebl_psi.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0x80F00000 , Len : 0x00B00000 Erase now... Erase done Load region package_m3.ppm_ebl_psi.fls Region Start : 0x80F00000 , Data Len : 0x0051399C Region Load done package_m3.ppm_ebl_psi.fls image flash done ===Flashing [CNT]=== Processing file : rm839__02.33.image_m3_059R1J9 Region count : 1 00 : package_m3_059R1J9.image.fls Parse done , flashing now Processing image : 00 : package_m3_059R1J9.image.fls Sending Sec-Pack SecInfo Area : 0x0000 , SecInfo Len : 0x0800 Erase area 0x00 , Start 0xA1000000 , Len : 0x0C580000 Erase now... Erase done Erase area 0x01 , Start 0xAE000000 , Len : 0x00300000 Erase now... Erase done Load region package_m3_059R1J9.image.fls Region Start : 0xA1000000 , Data Len : 0x0195FA00 Region Load done package_m3_059R1J9.image.fls image flash done Flashing done! Total flash time : 00:00:17 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 301 Dual SIM Software Info: V 02.33 17-05-13 RM-839 (c) Nokia IMEI: 357276053123407 PPM version : V 02.33 17-05-13 RM-839 (c) Nokia M3 Product code: 059Q9B9 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 58 certs Data exist, skip certificate repair... Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:00:50 Connect phone on selected interface... |
