07-05-2020, 20:45 | #1 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1954101 Status: Offline Thanks Meter: 1 | Ta-1130 imei damaged after flash with best 2 My ta-1130 lost imei after flash with best 2 . I tried to repair imei but in security part i forced erorr. How can i solve it? No baseband and no imei I try to flash with other frimware but problem still not solved. I need modem file for repair Can any body help me? |
07-06-2020, 13:47 | #3 (permalink) | |
Please always post software operation log text. Also post here details what was the problem with phone before flash and what was the damage of the phone before flash | |
07-07-2020, 07:37 | #4 (permalink) |
Member: 1954101 Status: Offline Thanks Meter: 1 | repair imei log hi bro thanksfor reply this is my repair imei log 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM186) MODE : BOOTROM PORT : 186 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 V0: 0000 0000 [0001] BROM : SOCID : A61B64CCCB11C65EA4064F1175A07C3BB9397D8DC141259906 B2A3B40C6AA2F2 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6739 AGENT : BEST_Nokia_DA_v19_1711_06 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 150100464E36324D42030FF4A81B362D EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B6291F5360B6A748649289C6DD827B DA : USB : HIGH-SPEED Boot done! SECURITY check : Failed! SECURITY REBUILD required!!! Done! Elapsed: 00:00:10 Reconnect Power/Cable! and this is the identify log 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM186) MODE : BOOTROM PORT : 186 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 V0: 0000 0000 [0001] BROM : SOCID : A61B64CCCB11C65EA4064F1175A07C3BB9397D8DC141259906 B2A3B40C6AA2F2 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6739 AGENT : BEST_Nokia_DA_v19_1711_06 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 150100464E36324D42030FF4A81B362D EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : B6291F5360B6A748649289C6DD827B DA : USB : HIGH-SPEED Boot done! --- SysInfoSub [PART A]: Patch Level : PPR1.180610.011 Display ID : 00WW_0_360 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-01-05 Build Time : 1548137548 Product Model : ANT Product Brand : alps Product Name : ANT_00WW_FIH Product Device : ANT Product Manfct : alps Product Info : ANT Product Board : ANT Board Platform : mt6739 --- SecuritySub : NVRAM check : Passed! Backup sensetive data [ 11 ] Backup path : Backup\MT6739__B6291F53060B6A748649289C06DD827B\ Backup done! Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
11-22-2020, 13:34 | #6 (permalink) |
Freak Poster Join Date: Nov 2004 Location: tunisia Age: 46
Member: 90859 Status: Offline Sonork: 100.1623226 Thanks Meter: 42 | same issue solved you have to tick meta in platfom main and repair security with the original imei dont forget to hold the volum down to enter meta i done it the same way here is the log Card found : E1508362 , v0145 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.16 Load IDBase v729152 Ok! Operation : Repair Security [ v2.16 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM249) MODE : PRELOADER PORT PORT : 249 Waiting BOOT ack ... PRELOADER : ACK confirmed! INIT : META enter failed by timeout! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Repair Security [ v2.16 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM249) MODE : PRELOADER PORT PORT : 249 Waiting BOOT ack ... PRELOADER : ACK confirmed! INIT : META enter failed by timeout! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Repair Security [ v2.16 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM280) MODE : BOOTROM PORT : 280 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E1 BROM : SecMode : SBC+EXT BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 V0: 0000 0000 [0001] BROM : SOCID : 37A050A14A9E52235A2F3E5C791915C58BCCC85675CE669ABC 113A42B4DAB7CB BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6739 AP_SWTM : Sun Mar 31 01:51:27 CST 2019 AP_SWVR : alps-mp-p0.mp2-V3.5 MD_CHIP : MT6739 MD_SWTM : 2000.00.00 MD_DSPV : 1.0 MD_DSPP : MOLY.LR12A.R2.MP.V61.12.P13 MD_SWVR : TK_MD_L4_HW MD_HWVR : Unknown IMEI[0] : [ ERASED ] IMEI[1] : [ ERASED ] IMEI[0] : 35288610297xxx Item : update Ok! IMEI[1] : 352886103073xxx Item : update Ok! Done! Elapsed: 00:00:53 Reconnect Power/Cable! |
The Following 5 Users Say Thank You to sahboub For This Useful Post: |
