08-03-2019, 08:38 | #1 (permalink) |
Junior Member Join Date: Sep 2015 Location: iran
Member: 2466134 Status: Offline Sonork: ahmednemat Thanks Meter: 3 | Authentication error:Socket Error # 10054 Connection reset by peer. Card found : 82EBCE8A , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.18 Load : J:\Nokia\TA-1021 Nokia 6\PLE-324A-0-00WW-A01.nb0 Project : PLE Model : TA-1025 SW_ver : PLE-324A-0-00WW-A0 DSP_ID : 00WW_3_24A Platform : Q8 SecVer : 0x0001 Load Ok! Operation : Flash Firmware [FTM] [ v1.18 ] Setting : UserData preserve : False Setting : FRP Reset : False Setting : Keep SVC : True -> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable -> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Dev Model : PAD HW version : 5.1 HW variant : FIH eMMC HW RF_BAND : G_850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28_38 _40 SW version : PLE-613A-0-00WW-B03 SW serialnm : PLEGAR8791400373 SW secured : YES Bootloader type : RETAIL Security Version : 0004 OP : Activate SVC Device : PAD ( PLE1 ) BLType : RETAIL SecVer : 04 Device authentification ... Processing server operation ... Connecting to server... Connected Authenticating... Authentication error:Socket Error # 10054 Connection reset by peer. |
08-17-2019, 08:40 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Code: Authentication error:Socket Error # 10054 |
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post: |
08-25-2019, 13:58 | #8 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Karachi,Pakistan Age: 34
Member: 701004 Status: Offline Sonork: 1626436:danish Thanks Meter: 116 | Device : E2M ( E2M ) BLType : RETAIL SecVer : 04 Device authentification ... Processing server operation ... Connecting to server... Connected Authenticating... Authentication error:Socket Error # 10053 Software caused connection abort. |
08-27-2019, 14:48 | #13 (permalink) | |
Member: 2466134 Status: Offline Sonork: ahmednemat Thanks Meter: 3 | Quote:
BLType : RETAIL SecVer : 04 Device authentification ... Processing server operation ... Connecting to server... Connected Authenticating... Authentication error:Socket Error # 10054 Connection reset by peer. | |
08-27-2019, 15:35 | #14 (permalink) | |
if problem still exists it may be a problem with your ISP and you should try with VPN. what is the result with VPN ? | |
08-28-2019, 16:49 | #15 (permalink) | |
BLType : RETAIL SecVer : 04 Device authentification ... Processing server operation ... Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version check error:Error: Client version is too old Disconnected Disconnected Finished Error : Device auth failed! Server reported error! Send log and report.log to support! Include device info also! Reconnect Power/Cable! | |
