04-06-2011, 15:53 | #76 (permalink) | |
No Life Poster Join Date: May 2009 Age: 49
Member: 1027729 Status: Offline Thanks Meter: 97 | Quote:
brother just try to upload if it is supported hash will submit the job if not supported hash then u have to read bcl from other tool like atf the upload log file credit for 1 sl3 is 70 hope u understand | |
04-07-2011, 11:40 | #81 (permalink) |
No Life Poster Join Date: Mar 2004 Location: BELARUS, Minsk Age: 44
Member: 59319 Status: Offline Sonork: 100.1606948 Thanks Meter: 82 | I tried to read gallery from phone: but I have this error Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok BackUp UserData : [SMS/MMS] Generation mode : [S60] Operating mode is OK, no need change... SmartPhone algo initialise... Setup data... StartUp FileSystem... FS run fail, please, remove SD card first Change phone mode manualy to local/test and try again If still no luck - phone have damaged FS/SD-MMC part.. Done with major error... BackUp UserData : [Gallery] Generation mode : [S60] Operating mode is OK, no need change... SmartPhone algo initialise... Setup data... StartUp FileSystem... Fsrun OK... Running : APE_TEST_SERVER,w43_05,(c)NMP Total - 41 files Reading, wait.... Not found Error on CS packet! Skipping... Not found Error on CS packet! Skipping... Not found Error on CS packet! Skipping... Not found Error on CS packet! Skipping... Not found Error on CS packet! Skipping... Not found Error on CS packet! Skipping... |
04-08-2011, 14:32 | #90 (permalink) |
Member: 59319 Status: Offline Sonork: 100.1606948 Thanks Meter: 82 | Problem with flashing 1800 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Core version : 1.18 , Rev : 3.0 Selected FlashSettings : Manual Files Set for Flashing : MCU : rm653_006.200 PPM : rm653_006.20el CNT : rm6530_nai06.20el Infineon flashing... Booting phone now.... Sync Ok , A2 CPU ID : XGOLD , A200341100 Boot Ok , 01 PBL : SE0_091125 F11 Algo Ok , 01 SBL mode Ok SBL : Default_RAM_Bootloader EPP CFG [Bering]... FLASH ID : 0020000000C08800 FLASH ID : ST, M58WR064 Boot Done! ===Flashing [MCU]=== File : rm653_006.200 Image : hw_b2_rm653_r06.200.fls Cert block found, sending.... Cert sent Found 3 region(s) Processing Region 1/3 Erase , Start : 0x00800000 , Len : 0x00210000 Erasing, wait ... Erase done Write , Start : 0x00800000 , Len : 0x00210000 Flashing , wait ... Region flash done Processing Region 2/3 Erase , Start : 0x00C60000 , Len : 0x0020A0C0 Erasing, wait ... Erase done Write , Start : 0x00C60000 , Len : 0x0020A0C0 Flashing , wait ... Region flash done Processing Region 3/3 Erase , Start : 0x00FFC000 , Len : 0x00000040 Erasing, wait ... Erase done Write , Start : 0x00FFC000 , Len : 0x00000040 Flashing , wait ... Region flash done Check : 7CCF ===Flashing [PPM]=== File : rm653_006.20el Image : hw_b2_rm653_006.20el.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00210000 , Len : 0x001C3680 Erasing, wait ... Erase done Write , Start : 0x00210000 , Len : 0x001C3680 Flashing , wait ... Region flash done Check : D43F ===Flashing [CNT]=== File : rm6530_nai06.20el Image : hw_b2_rm6530_nai06.20el.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x00EB0000 , Len : 0x00059280 Erasing, wait ... Erase Error [1B0012009F010100250000000000] Error... Phone disconected! Connect phone on selected interface... |
Antinokia ver 1.0 Collection of all best unlock softwares | AMTX99 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 04-13-2001 08:16 |
NetMonitor on Nokia 5110 & PC-Locals V1.3 | SashaM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-31-2001 11:12 |
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 | Nk_Cable | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-10-1999 10:08 |
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 | nk.cable | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-14-1999 15:33 |
