06-16-2014, 07:03 | #1 (permalink) |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Nokia 5230 RM-588 After Flash Vibrate Only .. .. Nokia 5230 RM-588 After Flash Vibrate Only .. Phone Status Before Flash : Call Log Not Showing or Slow Here I Flash with Latest Version : 51.9.002 Here is the Flash Status with BEST Code: card found: S/N xxxx:xxxx registered to: AniAXN Connect phone on selected interface... Core : v1.88 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-588_51.9.002_prd.core.C00 PPM : RM-588_51.9.002_prd.rofs2.V25 PPM2 : RM-588_51.9.002_C01_prd.rofs3.fpsx CNT : RM-588_51.0.002_000_001_U002.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPIDO Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1940000E5CAF005285568415A1D62B1F5788FBD2 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! :) TIME : Boot time : 00:00:04 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! RHASH : 479C6DDE3942E12C429C1D6ADED80371 RPAKeys : 7DC72D3FDC552426A4479BC820097D304CFB6C15 Pr.Code : 0589750 IMEI : 357015043577961 ADL : Auth done... === SW Version Check === - > REFLASHING or UPGRADE === SW Version Check === ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-588_51.9.002_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-588_51.9.002_prd.core.C00 Total 461 [461/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:33 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-588_51.9.002_prd.rofs2.V25 Found 1 areas to erase Erasing area 0x06FE0000 - 0x0915FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-588_51.9.002_prd.rofs2.V25 Total 110 [110/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:08 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-588_51.9.002_C01_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-588_51.9.002_C01_prd.rofs3.fpsx Total 28 [28/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:01 PPM Write done ===Flashing [CNT]=== Erase : Processing RM-588_51.0.002_000_001_U002.uda.fpsx Found 1 areas to erase Erasing area 0x09E60000 - 0x0F47FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-588_51.0.002_000_001_U002.uda.fpsx Total 66 [66/0/0] blocks to write, writing... TIME : Write time : 00:00:05 CNT Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:50 Reboot phone now... After Flash Now the Phone Status is Only Vibrate when Power On I Rely Confuse Plz Give Any Idea to Solve it .. Br, AniAXN |
The Following User Says Thank You to AniAxn For This Useful Post: |
06-16-2014, 07:22 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. Check BSI line first. If it is ok (BSI/GND contact is not broken/lift and e.t.c.) - proceed to step 2. Flash with ColdFlash mode ( FlashSettings ) Check. Erase - is not a way, here is hardware problem. |
The Following User Says Thank You to Dzirt For This Useful Post: |
06-16-2014, 08:13 | #3 (permalink) |
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Thanks Sir For Your Reply .. BSI/GND Line Are All OK .. Here I Try with Cold Flash .. But Result is Same .. See The Log ... Code: card found: S/N xxxxxxxx registered to: AniAXN Connect phone on selected interface... Core : v1.88 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Cold Flash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-588_51.9.002_prd.core.C00 PPM : RM-588_51.9.002_prd.rofs2.V25 PPM2 : RM-588_51.9.002_C01_prd.rofs3.fpsx CNT : RM-588_51.0.002_000_001_U002.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPIDO Generation Check files done... -> SWversion check skipped : Dead mode selected - > Force ColdFlash mode Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1940000E5CAF005285568415A1D62B1F5788FBD2 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.5 Use URAPIDOv11_XSR15_alg.fg , Rev : 2.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:00 Reopening the connection... CFL: Wait for Loader take control ... CFL: Check mode Phone ready, boot Ok TransReq set Ok PAPUBkeys : 7DC72D3FDC552426A4479BC820097D304CFB6C15 CFL: phone is in flash mode === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [MCU]=== Erase : Processing RM-588_51.9.002_prd.core.C00 Partitioning.... Partitioning Ok... Erasing.... Erasing Data.... Erase area : 0x00040000 - 0x00082FFF , CMT , NAND Erase area : 0x00083400 - 0x003FFFFF , CMT , NAND Erase area : 0x00400000 - 0x007FFFFF , CMT , NAND Erase area : 0x00800000 - 0x00D5FFFF , CMT , NAND Erase area : 0x00D60000 - 0x09E5FFFF , CMT , NAND Erase Partition Partition 0x0A Erase Ok... TIME : Erase time : 00:00:01 CFL: Request programm status NAND status : 00000000 / 00000000 / 00000000 Write : Processing RM-588_51.9.002_prd.core.C00 CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*ENO] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 437 blocks TIME : Write time : 00:02:07 MCU Write done CFL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing RM-588_51.9.002_prd.rofs2.V25 Erasing.... Erasing Data.... Erase area : 0x06FE0000 - 0x0915FFFF , CMT , NAND Erase Ok... TIME : Erase time : 00:00:00 CFL: Request programm status NAND status : 00000000 / 00000000 / 00000000 Write : Processing RM-588_51.9.002_prd.rofs2.V25 CMT: Writing Hash CERT [SOS+ROFS2] Total writen 108 blocks TIME : Write time : 00:00:32 PPM Write done CFL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM2]=== Erase : Processing RM-588_51.9.002_C01_prd.rofs3.fpsx Erasing.... Erasing Data.... Erase area : 0x09160000 - 0x09E5FFFF , CMT , NAND Erase Ok... TIME : Erase time : 00:00:00 CFL: Request programm status NAND status : 00000000 / 00000000 / 00000000 Write : Processing RM-588_51.9.002_C01_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 26 blocks TIME : Write time : 00:00:07 PPM Write done CFL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing RM-588_51.0.002_000_001_U002.uda.fpsx Erasing.... Erasing Data.... Erase area : 0x09E60000 - 0x0F47FFFF , CMT , NAND Erase Ok... TIME : Erase time : 00:00:00 CFL: Request programm status NAND status : 00000000 / 00000000 / 00000000 Write : Processing RM-588_51.0.002_000_001_U002.uda.fpsx Total writen 66 blocks TIME : Write time : 00:00:21 CNT Write done CFL: Request programm status NAND status : 00000000 / 00000000 / 00000000 CFL: Close_Session Content: 000300000000000000000000000000 CFL: Reboot Flashing done! Total flash time : 00:03:10 Reboot phone now... - > AfterFlash Failed! :( Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Elapsed: 00:05:15 Connect phone on selected interface... See This .... See the Read Line .. Br, AniAXN |
06-16-2014, 08:20 | #4 (permalink) |
No Life Poster Join Date: Oct 2005 Location: pakistan
Member: 188374 Status: Offline Sonork: 1000.2 Thanks Meter: 203 | Quote: |
06-16-2014, 10:28 | #11 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | State - same? Probably - need open it and resolder : CPU , Flash , power. After flash again and it will be alive. Some samples of 5228/5230 had alive after FBUS flashing in 5% case (after erase). But I not seen such phone to check it more better for that things. |
