Can't flash att Lumia 1020(RM-877) I'm trying to flash att lumia 1020 with rogers canada fw(also RM-877) because I'd like to unlock AWS band(1700 MHz) which seems to be locked in att version, so that I could get better coverage with t-mobile but I always get error. I tried to paste logs but I'm not allowed Or maybe it's possible to change product code? br |
Logs can be past via "code" tag. BEST keeps log in txt format. |
Flashing log attached below: Code: card found: S/N 2513:0118 |
Where is it? I see nothing. |
FFU ROOT matching, but, seems, MODEL_ID not same and signature check not pass. You can flash only ATT rom's. Try latest version of it - can be chance to your problems will gone. |
Thank you for your reply. As far as I know rogers and att version of lumia 1020 have the same hw they're both RM-877. It's possible to flash any rom to RM-875 so why it's not for RM-877? Diffrent radio fw or something? Is there any way to disable signature checking? Will bootloader accept it? Is it possible to change product code in wp8 lumias? |
Change product code not a problem. Problem is Signature Checking : Mean FlashFile have : RRKH : 0CBD2EED6F62230571CBAB55B7DBC15F8A7DC7BB PRODUCT_ID : P5217 Phone have : RRKH : 0CBD2EED6F62230571CBAB55B7DBC15F8A7DC7BB PRODUCT_ID : P5217_ATT I made only Product ID checking, seems as need check whole name. Phone will reject flashfile even, if you change product code. Other way is try flash dump via JTAG - where will be all Bootloader, TZ, UEFI parts from non ATT version. But it require JTAG, solder skill, knowing of structure and security part of flash (DPP backup/restore) |
I have nokia tool with jtag and some solder skills;) but I'm not sure if I have all needed knowledge. Do I also need dump from rogers RM-877? |
Yeah, you need dump from working phone. Need first 250-300 mb to make fully sure all is Ok. Also need make DPP partition backup and you can fun. Also make backup dump - good idea. But all is just a theory, both should be same by HW, and should work after that. |
Thanks for all the info. Is there a way to flash radio fw only without dump? |
No way, FFU is fully signed and checked. I not remember exactly memory map, but can check it in near days. Also NVI can hold some RF settings , so, we can try read NVM from working Rogers and write to that one. But also - I not tested that and no have idea what will happen. I plan run SX4 server in end of next week, if find way to get good internet channel for it. In BEST exist ability to write NVI (Factory settings NVM , specified for model) and NVM (Backup) , but it not activated, because my SX4 server now down. |
OK Guess I'm gonna need to find Rogers Lumia 1020 or ask someone to make the dump for me. Anyway thanks again. Hopefully your server will be up soon. |
Has anyone had any luck with this? I'm trying to flash my ATT Lumia 1020 with any non ATT rom - even the RM-877 light swap. I get the FFU error with anything non ATT. Has anyone figured out how to bypass this check? |
What if read thread again from start? |
P.S. : Because I can't answer to PM for answer to some questions. Currently SX4 is offline, because I can't find way to make server. If say simple - not have enough money to do that. NVM handling and sd uath and rest thing are exist, but only with local SX4. |
