Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 06-11-2015, 15:10   #1 (permalink)
Member: 130995
Thanks Meter: 35,227
Chinese Miracle-2 (Test Version) free Activation for Infinity-Box [BEST] users
Dear Friends,
- You can activate Chinese Miracle-2 (Test Version) Coolsand/Spredtrum/MediaTek for your Main Infinity-Box or Infinity-Box [BEST] or Infinity-Box CDMA-Tool.
- Chinese Miracle-2 (Test Version) Activation is FREE
- After Activation you can use Chinese Miracle (Test Version) v0.xx
- You can activate Chinese Miracle-2 (Release) Coolsand/Spredtrum/MediaTek/Rockchip for your Infinity-Box [BEST] or Infinity-Box CDMA-Tool.
- Chinese Miracle-2 (Release) Activation is not free
VERY IMPORTANT:
- You must use Infinity-Box [BEST] v2.08 or higher after Chinese Miracle-2 (Test Version) Activation !
- If you have DC-Unlocker Activation: use DC-Unlocker Client version 1.00.1190 or higher after Chinese Miracle-2 (Test Version) Activation !
How to Activate Chinese Miracle-2 (Test Version) for Free:
1. Login to your Infinity Online Service (IOS) account (you have it created already)
2. Go to Products menu
3. Select Software activations item
4. Select Activation depends on your Box/Dongle type:
- Chinese Miracle-2 (Test Version) software activation for Main Infinity-Box
- Chinese Miracle-2 (Test Version) software activation for Infinity-Box [BEST]
- Chinese Miracle-2 (Test Version) software activation for Infinity-Box CDMA-Tool
5. Click to Buy button
6. You will see a confirmation and Activation status
7. Run DongleManager software and update your Smart-Card firmware
8. Now you can use new software
How to know your Infinity Online Service Login/Password:
- Each Infinity-Box User already has a free Infinity Online Service (IOS) Account.
Read your Login/Password from your Dongle and you can login into IOS: Infinity-Box - Online Service
How to get (Test Version) software:
1. Download (Test Version) software
2. Download and install: InfinityBox_install_CM2xxx_v0.XX.rar
How to fix problem with Dongle Firmware update:
- http://forum.gsmhosting.com/vbb/f296...lated-1950792/
- If you have FT-SCR2000 Card-Reader you should update your Card-Reader Drivers:
Download CardReader_Fetian_FT2K_x32_x64 Drivers and read instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f
If you have SPT-Box Activation and it stop to work after Smart-Card update:
1. Go here: SPT-Box software activation for USTPRO2 and Infinity-Box
2. Download Activator from: SPT-Box Support Area
3. Run Activator.exe
4. Enetr your data
5. You will get user.ini file
6. Copy user.ini into folder with SPT software
7. Run SPT.exe - it can not run
8. Run SPT.exe again - it can run and works well
More Activations:
http://forum.gsmhosting.com/vbb/f296...users-1947911/
http://forum.gsmhosting.com/vbb/f296...users-1983140/
The Following 18 Users Say Thank You to InfinitySupport For This Useful Post:
Old 06-11-2015, 15:52   #2 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
(BEST)Test Module Active Done :) Thanks Team
Activation Logs.....
6/11/2015 7:50:35 PM DongleManager version: 1.56
PC HWID: B6118F72A3Axxxxxx00E8E34
Card-Reader: FT SCR2000 0
Token HWID: 0102xxxxx292
Box/Dongle type: [BEST]
Box/Dongle Serial No (S/N): xxxxx
Firmware version: 0122.02
"UK edition" status: Off
Last launched application: 0000 v.0000
Active modules:
- 03: [BEST] v.0122
- 0A: Test Version
Online Service Account: http://www.infinity-box.com/service
- Username: xxxxxF
- Password: xxxxxj
Checksum: 87877F
Qmobile E6 Read Info Done (World First with BEST Dongle)
Card found: S/N xxxxx
Chinese Miracle II  [MTK module] v 0.03
Operation : Check / Read Info [ v0.03 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 12 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0000
BB_CPU_SN : 8FD9AA58EC0FD622D7734F1E5634939B
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
InitRes : 00000000
DEV[0] : EF00 4000 1600 0000
DEV[1] : 0000 0000 0000 0000
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x88
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV
[0] : FLASH_DIE : 00EF 0040 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS : 0x00000000 , 0x00000000
Done!
Elapsed: 00:00:09
Reconnect Power/Cable!
The Following 3 Users Say Thank You to syed tuqeer For This Useful Post:
Old 06-11-2015, 16:21   #3 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
----------Process started: 6/11/2015 8:20:15 PM----------
6/11/2015 8:20:15 PM DongleManager version: 1.56
PC HWID: 8C7B34BDEDC8CA5F252A158630A461E1
Locating server...
Server address found
Connecting to server
Server connection successfully established
S/N: 63BD8D82, HWID: 01018D8203EF1292, Firmware: 0122.02
Authenticating on server...
Authentication stage error:
Server reported error:[0007] No more upgrade logs.
Dongle is up-to-date and has latest firmware. DO NOT try more !
actvion error
The Following 3 Users Say Thank You to Tanha0321 For This Useful Post:
Old 06-11-2015, 16:23   #4 (permalink)
Member: 1905774
Sonork: 100.1646709
Thanks Meter: 972
Locating server...
same brother how fix this
The Following User Says Thank You to shaikh.mushahid For This Useful Post:
Old 06-11-2015, 16:29   #5 (permalink)
Member: 130995
Locating server...
actvion error
You must read instruction !
How to Activate:
1. Login to your Infinity Online Service (IOS) account: Infinity-Box - Online Service
2. Go to "Products" menu
3. Select "Software activations" item
4. Select "Chinese Miracle-2 (Test Version) software activation for Infinity-Box [BEST]"
5. Click to "Buy" button
7. Follow by given instruction and update your Smart-Card firmware - Smart-Card Update Manual
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 06-11-2015, 16:29   #6 (permalink)
Member: 130995
How to Activate:
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 06-11-2015, 16:42   #7 (permalink)
Member: 459784
Sonork: +91-9179403087
Thanks Meter: 1,543
Locating server...
actvion error
Hello Update Again Your Box Now
The Following User Says Thank You to pradeep_kus For This Useful Post:
Old 06-11-2015, 16:43   #8 (permalink)
Member: 1905774
Sonork: 100.1646709
Thanks Meter: 972
How to Activate:
after all success now show this eeror
Old 06-11-2015, 16:50   #9 (permalink)
Member: 459784
Thanks Meter: 1,543
Hello , Update Box Done? Can You Pls Post Update Log?
Old 06-11-2015, 17:00   #10 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,067
i acivate software on my best dongle but when update then error comes
0	Info 2015-06-11 15:44:01	0	System		Chinese Miracle-2 (Test Version) software activation for Infinity-Box [BEST]	2195xxxx		COMPLETED
----------Process started: 6/11/2015 8:59:04 PM----------
6/11/2015 8:59:04 PM DongleManager version: 1.56
PC HWID: 51BBBC5B009E6A83B710980BFA42060B
Locating server...
S/N: 2195xxxx, HWID: 020091851D04xxxx, Firmware: 0118.04
Authentication successfull
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Identification check error:
Server reported error:[0010] Dongle authentication failed. Retry upgrade.
The Following User Says Thank You to asad_nomy7 For This Useful Post:
Old 06-11-2015, 17:05   #11 (permalink)
Member: 1905774
Sonork: 100.1646709
Thanks Meter: 972
Finaly Reached Cm2 In Best
Old 06-11-2015, 17:14   #12 (permalink)
rizwankhan8670's Avatar
Member: 1497980
Thanks Meter: 1,266
hi im not found pass update ok butt pass not found
The Following 2 Users Say Thank You to rizwankhan8670 For This Useful Post:
Old 06-11-2015, 17:19   #13 (permalink)
Member: 130995
Locating server...
Download Drivers and read Instruction
What is the results ?
Old 06-11-2015, 17:19   #14 (permalink)
Member: 130995
You must make all steps !
Old 06-11-2015, 17:21   #15 (permalink)
Member: 130995
Update Drivers !
And update your Dongle again.
Page generated in 0.27547 seconds with 9 queries
