09-03-2011, 15:52 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india Age: 37
Member: 1146038 Status: Offline Thanks Meter: 196 | Nokia x3-02............. Problem....help Code: card found: S/N 05FB:0118 registered to: arun DLL not found... Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 22C0000D5AE555407630DB2E60178D8A383F286D ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.24.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.24.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] ADL: Reading certificates... Reading NPC certificate... IMEI : 356981041601296 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Cert Read done! ADL: Reading certificates done! :) ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Wait, reconneting... SLx Simlock Data read ... ok SL3 Simlock Sign read ... ok WMDRM read ... ok CRT308 Backup Created NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\356981041601296.rpl All done, Disconnecting Elapsed: 00:01:20 Connect phone on selected interface... card found: S/N 05FB:0118 registered to: arun DLL not found... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia X3-02 Software ver : V 05.65 26-11-10 RM-639 (c) Nokia IMEI : 356981041601296 Ape Ver : APE Var : APE ADSP: DSP Ver : 92_MP2.2_5.63j APE Test: PPM : V 05.65 26-11-10 RM-639 (c) Nokia MR1 CNT : Content: mr1_0598209 V 05.65 26-11-10 RM-639 (c) Nokia Product SN : C8E284523 Product code : 0598209 Base Prd.code: 0593642 Module code : 0204600 Long Prod.SN : 0 Hardware info======= HWID : 1004 Retu : 51 Tahvo : 00 Batery: 4001 mV Camera: CMT BT: APE BT: APE HW: LCDVer: TPO RF ic : Lock info =========== IMEI : 356981041601296 IMEI spNet : 3A 65 89 01 14 06 21 09 IMEI svNet : 33 65 89 01 14 06 21 29 F7 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! BackUp UserData : [PhoneBook] Generation mode : [S40] Cnt Server Info : 99/1901/2000 Using search engine... Data proceed ok... csv file save to C:\InfinityBox\BEST\RM-639 Nokia X3-02_356981041601296.csv 99 phonebook records are found! VCF Records saved to : BEST\Phones_Data\IMEI\ File saved to : C:\InfinityBox\BEST\RM-639 Nokia X3-02_356981041601296.S4pb Read done ;) Done... card found: S/N 05FB:0118 registered to: arun DLL not found... Connect phone on selected interface... Core version : 1.26 Rev : 2.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm639__06.00.mcusw PPM : rm639__06.00.ppm_mr1 CNT : rm639__06.00.image_mr1_0598209_008 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 22C0000D5AE555407630DB2E60178D8A383F286D ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 11.24.0 Processing RAWLOADER... FLIC : 003000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 11.24.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 356981041601296 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\356981041601296_CRT.rpl ===Flashing [MCU]=== Erase : Processing rm639__06.00.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm639__06.00.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 264 blocks TIME : Write time : 00:00:10 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing rm639__06.00.ppm_mr1 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm639__06.00.ppm_mr1 Total writen 63 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing rm639__06.00.image_mr1_0598209_008 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm639__06.00.image_mr1_0598209_008 Total writen 260 blocks TIME : Write time : 00:00:07 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:00:21 Reboot phone now... -> Flashing Failed! :( Maybee HW error, or Downgrade try???! Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Elapsed: 00:03:03 Connect phone on selected interface... IT'S HARDWARE PROBLEM YA SOFTWARE PROBLEM....? |
