06-27-2017, 16:22 | #1 (permalink) |
Freak Poster Join Date: Sep 2010
Member: 1392507 Status: Offline Thanks Meter: 38 | LUMIA UNLOC Unknown result,something wrong with SDauth or Data #1,try "Unlock" again! Unknown result , something wrong with SDauth or Data #1 , try "Unlock" again! Any idea? |
06-29-2017, 15:29 | #5 (permalink) |
Member: 1392507 Status: Offline Thanks Meter: 38 | I just flash and when I try to unlock I get the same error, any idea , if not please refund the credits. I must return the Lumia. -------------------------------------------------------- Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Core : v2.29 , WP10x FlashEngine : v3.2 FFU : RM975_02173.00000.15154.50006_RETAIL_prod_signed_1 050_025C52_AIO-US.ffu Checking FFU file, wait... FFU Revision ID : 2.0 FFU Model ID : Nokia.MSM8926.P6112 FFU RootKeyHash : 0000000000000000000000000000000000000000 FFU Languages : Portuguese(Brazil) , Russian , Greek , fr-ca , Indonesian , Korean , Polish , bn-bd , Uzbekistan(Latin) , Catalan , Swedish , Bulgarian , Japanese , Spanish , English (UK) , Czech , Latvian , Slovak , Chinese , sr-latn-rs , Vietnamese , af-za , Hindi (India) , gl-es , Turkish , Thai , Italian , Danish (Denmark) , ha-latn-ng , Slovenian , Malay (Malaysia) , Lithuanian , Persian (Iran) , Kazakh , Romanian , English , eu-es , Estonian , Filipino (Philippines) , Belorusian , Norwegian (Bokmal , Norway) , Finnish , lo-la , km-kh , Arabic , Ukrainian , Croatian , Portuguese(Portugal) , Chinese(Taiwan) , Macedonian , Hungarian , Spanish(Mexico) , Azerbaijan(Latin) , German , Albanian , Dutch (Netherlands) , French , sw-ke , Hwbre (Israel) , FFU ChipSectors : 15155200 FFU Header : 0x000E0000 FFU Payload : 0x6C740000 FFU FastVerify : Ok Waiting for phone... === Base Phone Info Sw Version : 02173.00000.15154.50006 IMEI : 356454060683488 ProductCode : 059W663 Battery Level : 60 % === Setting Flash Mode Device catched in BOOT mode! Collect Info... === Nokia Flash App info : Protocol Version : 2.37 Protocol Implementation : 2.60 === Phone Initial info : Phone Model ID : Nokia.MSM8926.P6112.1.1 === eMMC info : eMMC Vendor : Toshiba eMMC CID : 0011 eMMC Size : 7456 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : B2F6BECAAED8735388C21591177EDEBE44E5D762 === Other info : SD present : False Full Check skipped , will be checked by ImageSignature Battery Level : 64% RPMB Provision Status Code : 0x0101 Device RAM size : 512 MiB Device have ATRP (AntiTheft) system! Backup to RAM Ok! FFU : RM975_02173.00000.15154.50006_RETAIL_prod_signed_1 050_025C52_AIO-US.ffu Flashing FFU Sending FFU Header CertData Header sent , accepted Perform Data Partition Erase Erase done Sending FFU Payload Data... Finishing flashing Flashing done! Green Light Image Sent, processing PostFlash FinalConfig : abnormal status, error code : 0xFF7B0000 Make Factory Set : Ok Restore RAMBkp : Ok Update NVI from Image Ok , NVI will be updated on first boot! PostFlash Finished Total flash time : 00:05:25 Rebooting Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok === Main info === NCSD Version : 5.1 Sw Version : 02173.00000.15154.50006 IMEI : 356454060683488 ProductCode : 059W663 ProductSN : 44DC82FAU Module Code : 0205734 === HW info === Public ID : B1C339A6D3F5273F0668E3B0699D4C28ADD790CB HW Version : 3210 BT Addr. : 8463D6159EE8 Wlan Mac : 8463D61EE440 Battery Level : 54 % === Branding and security info === Operator : AIO-US SimLock : Locked! SimLock : 3101500112987 Country : United States of America Operator : AT&T Branding : RM-975_1050 Sec. Mode : Restricted Done! ------------------------------------------------------------------ WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Need SDAuth to finish ... Started Connecting to SX4 server... Connected SX4 enter .. SDAuth Ok! SX4 Disconnected Unknown result , something wrong with SDauth or Data #2 , try "Unlock" again Error! Check previous error message for more info! |
06-29-2017, 16:00 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Error not same. I have no idea which ENO you had used ( because you had cut complete logs ) , so can advise you try another one ENO. BEST by default download all available ENO's for selected RM ( if they available ). If you not want use search ( it just 2 minutes of check , where you can find similar problem and solving steps for it ) - ask support for refund. |
06-29-2017, 17:00 | #7 (permalink) |
Member: 1392507 Status: Offline Thanks Meter: 38 | yes sorry its different the error, I use this eno file: RM975_2040.0019.9651.14219.207.204_enosw-wim-signed_701557.secwim This is the only that works, cause the other in support is RM975_1061.0074.9651.12400.207.2415_enosw-wim-signed_604673.secwim and didnt work any idea? -------------------------------------------------------- Here is the full log. __________________________________________________ Phone found! WP10/WP8x Lumia Phone detected Read info... Ok [WP8x] : Init TesMode [TSTM] : Use File : RM975_2040.0019.9651.14219.207.204_enosw-wim-signed_701557.secwim === Base Phone Info Sw Version : 02173.00000.15154.50006 IMEI : 356454060683488 ProductCode : 059W663 Device catched in BOOT mode! Collect Info... === Nokia Flash App info : Protocol Version : 2.37 Protocol Implementation : 2.60 === Phone Initial info : Phone Model ID : Nokia.MSM8926.P6112.1.1 === eMMC info : eMMC Vendor : Toshiba eMMC CID : 0011 eMMC Size : 7456 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : B2F6BECAAED8735388C21591177EDEBE44E5D762 === Other info : SD present : False SECWIM : RM975_2040.0019.9651.14219.207.204_enosw-wim-signed_701557.secwim Sending WIM ... WIM Image sent! Trying init TestMode now... Connect phone on selected interface... Card serial: xxxxxxxx Card type: BEST Dongle Card password: xxxxxxxx Link to my account: http://user.infinity-box.com Login: xxxxxxxxxxx Connecting to server... Credits: 3566 Phone found! WP10/WP8x Lumia Phone detected Read info... Ok WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Need SDAuth to finish ... Started Connecting to SX4 server... Connected SX4 enter .. SDAuth Ok! SX4 Disconnected Unknown result , something wrong with SDauth or Data #2 , try "Unlock" again Error! Check previous error message for more info! |
06-29-2017, 17:51 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Seems as that happen due different ( much ) versions change between Main SW and ENOSW. 1. Reflash to another sw version with 2040 As Ex : 059W4X2 Selected Variant : RM-975 VAR NAM 4R CV WinPh OS Version : 8.10.14234.375 Firmware Version : 02040.00021.15235.50001 2. Downgrade to any 10xx version ( any PC with SWAP ENGINE GLOBAL ) |
06-29-2017, 18:59 | #10 (permalink) | |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Quote:
Then follow the procedure according to JayDi.. | |
07-01-2017, 20:31 | #13 (permalink) |
Member: 1392507 Status: Offline Thanks Meter: 38 | when I try the 1st way I get the fallowing error, any idea please? -------------------------------------------------------------------- Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Core : v2.29 , WP10x FlashEngine : v3.2 FFU : RM975_02040.00021.15235.50001_RETAIL_prod_signed_1 043_026D7D_000-US_MV.ffu Checking FFU file, wait... FFU Revision ID : 2.0 FFU Model ID : Nokia.MSM8926.P6112 FFU RootKeyHash : 0000000000000000000000000000000000000000 FFU Languages : Portuguese(Brazil) , Russian , Belorusian , fr-ca , Indonesian , Korean , Polish , Ukrainian , Uzbekistan(Latin) , Catalan , Swedish , Bulgarian , Japanese , Spanish , English (UK) , Czech , Latvian , Slovak , Chinese , sr-latn-rs , af-za , Hindi (India) , gl-es , Turkish , Thai , Italian , Danish (Denmark) , ha-latn-ng , Slovenian , Malay (Malaysia) , Lithuanian , Persian (Iran) , Kazakh , Romanian , English , eu-es , Estonian , Filipino (Philippines) , Greek , Norwegian (Bokmal , Norway) , Finnish , Vietnamese , Arabic , Croatian , Portuguese(Portugal) , Chinese(Taiwan) , Macedonian , Hungarian , Spanish(Mexico) , Azerbaijan(Latin) , German , Albanian , Dutch (Netherlands) , French , Hwbre (Israel) , FFU ChipSectors : 15155200 FFU Header : 0x000E0000 FFU Payload : 0x73C80000 FFU FastVerify : Ok Waiting for phone... === Base Phone Info Sw Version : 02173.00000.15154.50006 IMEI : 356454060683488 ProductCode : 059W663 Battery Level : 75 % === Setting Flash Mode Device catched in BOOT mode! Collect Info... === Nokia Flash App info : Protocol Version : 2.37 Protocol Implementation : 2.60 === Phone Initial info : Phone Model ID : Nokia.MSM8926.P6112.1.1 === eMMC info : eMMC Vendor : Toshiba eMMC CID : 0011 eMMC Size : 7456 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : B2F6BECAAED8735388C21591177EDEBE44E5D762 === Other info : SD present : False Full Check skipped , will be checked by ImageSignature Battery Level : 76% RPMB Provision Status Code : 0x0101 Device RAM size : 512 MiB Device have ATRP (AntiTheft) system! Backup to RAM Ok! FFU : RM975_02040.00021.15235.50001_RETAIL_prod_signed_1 043_026D7D_000-US_MV.ffu Flashing FFU Sending FFU Header CertData FFU header NOT ACCEPTED by target! FFUImage Can't be flashed Possible reasons : Wrong RM-xxx/ProductID selected or eMMC faulty! Red Light Error during flashing! LastErr : 0B00000062746E4163746976 |
07-03-2017, 00:26 | #15 (permalink) |
Member: 1392507 Status: Offline Thanks Meter: 38 | I try the second solution(Downgrade to any 10xx version) here is the log and nothing also any idea or firmware that you suggest me please ------------------------------------------------------------- Phone found! WP10/WP8x Lumia Phone detected Read info... Ok === Main info === NCSD Version : 5.1 Sw Version : 02173.00000.15154.50006 IMEI : 356454060683488 ProductCode : 059W663 ProductSN : 44DC82FAU Module Code : 0205734 === HW info === Public ID : B1C339A6D3F5273F0668E3B0699D4C28ADD790CB HW Version : 3210 BT Addr. : 8463D6159EE8 Wlan Mac : 8463D61EE440 Battery Level : 99 % === Branding and security info === Operator : AIO-US SimLock : Locked! SimLock : 3101500112987 Country : United States of America Operator : AT&T Branding : RM-975_1050 Sec. Mode : Restricted Done! Core : v2.29 , WP10x FlashEngine : v3.2 FFU : RM975_01061.00064.14233.25001_RETAIL_prod_signed_1 010_007D93_TIM-BR.ffu Checking FFU file, wait... FFU Revision ID : 2.0 FFU Model ID : Nokia.MSM8926.P6112 FFU RootKeyHash : 0000000000000000000000000000000000000000 FFU Languages : Portuguese(Brazil) , Russian , Belorusian , fr-ca , Indonesian , Korean , Polish , Ukrainian , Uzbekistan(Latin) , Catalan , Swedish , Bulgarian , Japanese , Spanish , English (UK) , Czech , Latvian , Slovak , Chinese , sr-latn-rs , af-za , Hindi (India) , gl-es , Turkish , Thai , Italian , Danish (Denmark) , ha-latn-ng , Slovenian , Malay (Malaysia) , Lithuanian , Persian (Iran) , Kazakh , Romanian , English , eu-es , Estonian , Filipino (Philippines) , Greek , Norwegian (Bokmal , Norway) , Finnish , Vietnamese , Arabic , Croatian , Portuguese(Portugal) , Chinese(Taiwan) , Macedonian , Hungarian , Spanish(Mexico) , Azerbaijan(Latin) , German , Albanian , Dutch (Netherlands) , French , Hwbre (Israel) , FFU ChipSectors : 15155200 FFU Header : 0x000E0000 FFU Payload : 0x643E0000 FFU FastVerify : Ok Waiting for phone... === Base Phone Info Sw Version : 02173.00000.15154.50006 IMEI : 356454060683488 ProductCode : 059W663 Battery Level : 99 % === Setting Flash Mode Device catched in BOOT mode! Collect Info... === Nokia Flash App info : Protocol Version : 2.37 Protocol Implementation : 2.60 === Phone Initial info : Phone Model ID : Nokia.MSM8926.P6112.1.1 === eMMC info : eMMC Vendor : Toshiba eMMC CID : 0011 eMMC Size : 7456 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : B2F6BECAAED8735388C21591177EDEBE44E5D762 === Other info : SD present : False Full Check skipped , will be checked by ImageSignature Battery Level : 99% RPMB Provision Status Code : 0x0101 Device RAM size : 512 MiB Device have ATRP (AntiTheft) system! Backup to RAM Ok! FFU : RM975_01061.00064.14233.25001_RETAIL_prod_signed_1 010_007D93_TIM-BR.ffu Flashing FFU Sending FFU Header CertData FFU header NOT ACCEPTED by target! FFUImage Can't be flashed Possible reasons : Wrong RM-xxx/ProductID selected or eMMC faulty! Red Light Error during flashing! LastErr : D8FE61060100000004000000 |
