02-01-2021, 17:59 | #1 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,802 | First in world nokia 150 rm-1190 059z0x8 60.04.11 arabic english french firmware LOG Code: Operation : Identify [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM465) MODE : NOKIA USB SERIAL PORT : 465 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM465) MODE : NOKIA USB SERIAL PORT : 465 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 2EA63B67BBCE117A31085304EC596683 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DUBAI61D.60.04.11.p1 BOOT : SWR : 60.04.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : DUBAI61D.60.04.11.p1 FLASH : 00C2 : 0025 : 0036 : 0000 PRDC : 059Z0X8 NCK : 20 digits PROV : 24407000 Saved as : 3.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:01:01 Reconnect Power/Cable! Card found : EBD16960 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Operation : Read FirmWare [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM465) MODE : NOKIA USB SERIAL PORT : 465 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 2EA63B67BBCE117A31085304EC596683 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : DUBAI61D.60.04.11.p1 BOOT : SWR : 60.04.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : DUBAI61D.60.04.11.p1 FLASH : 00C2 : 0025 : 0036 : 0000 CODE : 0x003A0000 Reading Flash ... TDSN : RM-1190 PRDC : 059Z0X8 PPM : IC LANG : [1] : Arabic (Saudi Arabia) [2] : French (France) [3] : English (United Kingdom) BUILD : RM-1190_ROM_eMP_60.04.11 BUILD : RM-1190_LANG_PACK_ROM_IC_eMP_60.04.11_001 BUILD : RM-1190_CUSTPACK_ROM_IC_eMP_60.04.11_001 BUILD : RM-1190_JUMP_TABLE_IC_eMP_60.04.11_001 BUILD : RM-1190_VIVA_eMP_60.04.11 Make VPL definition Save Path : D:\BST\RM-1190\ Save Name : RM-1190_059Z0X8_60.04.11.vpl Build Finished! Done! Elapsed: 00:06:51 Reconnect Power/Cable! DOWNLOAD FROM HERE ****************************/file/d0w25...04.11.rar/file |
The Following 5 Users Say Thank You to profkefah For This Useful Post: |
