09-22-2013, 13:24 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: karachi
Member: 643460 Status: Offline Thanks Meter: 93 | not read hash sl3 c2-05 y Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Resetting selected items... Check phone mode... Phone in Normal mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Elapsed: 00:00:19 Phone Imei: 351674059091568 Checking locks... Sl Conf : 204-04-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : F5B3DD4E3A98080E Country : Netherlands Operator : vodafone NL Lock info: Block 1 L1:Close; L2:Close; Check communication with phone.... Communication verify done... Preparing... Reboot.... -> If Phone start charge - just reinsert battery fast Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF -> Boot failed... Error read secure data! Error...! Connect phone on selected interface... how to read sl3 file |
09-24-2013, 11:09 | #4 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | I just get c2-05 phone and : Code: Phone found! Series 40 Device detected! read info... - Ok Phone Imei: 358266043395081 Checking locks... Sl Conf : 001-01-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : DDB568963E82B913 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Check communication with phone.... Communication verify done... Preparing... Reboot.... -> If Phone start charge - just reinsert battery fast Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF EBL Loader : Custom EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL EBL : Custom EBL sent Ok EBL : Quantum_Bootloader_2.5_M1S1 Boot done! Check RSA started... Check RSA ok Create Log file for local calculation... File C:\InfinityBox\BEST\Local_calc\358266043395081.bcl created - Ok File C:\InfinityBox\BEST\Local_calc\oclHashcat_358266043395081_32.bat created - Ok File C:\InfinityBox\BEST\Local_calc\oclHashcat_358266043395081_64.bat created - Ok Done! Connect phone on selected interface... All will work as should. |
