10-17-2013, 14:21 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Ports***** UK Age: 44
Member: 126675 Status: Offline Thanks Meter: 13 | Can I downgrade Rapu Yama phones? Can I downgrade Nokia 6730c RM-547 on Rapu Yama CPU? Because I have problem on step 4 in this topic: http://forum.gsmhosting.com/vbb/f641...c-how-1363981/ |
10-21-2013, 10:32 | #3 (permalink) |
Member: 126675 Status: Offline Thanks Meter: 13 | After write RPL phone not power on properly - only shows Nokia logo and shut down. When i repeat procedure without downgrade firmware - phone works good. Code: Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 6730c-1 Software ver : V ICPR82_10w08 26-02-10 RM-547 (c) Nokia IMEI : 354217030143251 XappVer : 000006C2 Ape Ver : 031.022 APE Var : 031.022031.022.01.01031.022.202.07 APE ADSP: 256 DSP Ver : ICPR82_10w08 APE Test: 0.024 PPM : CNT : Product SN : CLF454814 Product code : 0583017 Base Prd.code: 0574520 Long Prod.SN : 0 Hardware info======= HWID : 0500 Retu : 34 Tahvo : 00 Batery: 4143 mV APE BT: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652. APE HW: 256 Lock info =========== IMEI : 354217030143251 IMEI spNet : 3A 45 12 07 03 41 23 05 IMEI svNet : 33 45 12 07 03 41 23 35 F8 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Backup Certificates now... Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok Check communication with phone.... Reboot.... Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 275002141E2C03445C85D311D5C747C91B3C4D57 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : DA2DB2D32C1B2D9886A55B5D8A14F19ADDC53128 ADL: Reading certificates... Reading NPC certificate... IMEI : 354217030143251 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... ADL: Reading certificates done! :) ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... Swap data collected to 0583017.pc RPL saved : C:\InfinityBox\BEST\Backup\Cert\354217030143251.rpl All done, Disconnecting Elapsed: 00:00:31 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Reading PM from field 0 to 400 Field [1] 27 Record(s) Record 0: 114 byte(s) readed - Ok Record 2: 10 byte(s) readed - Ok Record 4: 110 byte(s) readed - Ok Record 6: 10 byte(s) readed - Ok Record 7: 214 byte(s) readed - Ok Record 8: 110 byte(s) readed - Ok Record 13: 10 byte(s) readed - Ok Record 16: 208 byte(s) readed - Ok Record 18: 208 byte(s) readed - Ok Record 20: 208 byte(s) readed - Ok Record 22: 16 byte(s) readed - Ok Record 23: 4 byte(s) readed - Ok Record 24: 84 byte(s) readed - Ok Record 26: 110 byte(s) readed - Ok Record 28: 10 byte(s) readed - Ok Record 29: 10 byte(s) readed - Ok Record 31: 208 byte(s) readed - Ok Record 33: 36 byte(s) readed - Ok Record 34: 376 byte(s) readed - Ok Record 35: 16 byte(s) readed - Ok Record 39: 36 byte(s) readed - Ok Record 40: 16 byte(s) readed - Ok Record 41: 182 byte(s) readed - Ok Record 42: 4 byte(s) readed - Ok Record 43: 36 byte(s) readed - Ok Record 44: 182 byte(s) readed - Ok Record 45: 182 byte(s) readed - Ok Field [2] 1 Record(s) Record 0: 2080 byte(s) readed - Ok Field [4] 6 Record(s) Record 1: 1020 byte(s) readed - Ok Record 3: 10 byte(s) readed - Ok Record 4: 8 byte(s) readed - Ok Record 5: 8 byte(s) readed - Ok Record 9: 5 byte(s) readed - Ok Record 28: 2 byte(s) readed - Ok Field [6] 1 Record(s) Record 0: 32 byte(s) readed - Ok Field [8] 10 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 16 byte(s) readed - Ok Record 2: 16 byte(s) readed - Ok Record 3: 128 byte(s) readed - Ok Record 4: 128 byte(s) readed - Ok Record 5: 8 byte(s) readed - Ok Record 7: 4 byte(s) readed - Ok Record 8: 8 byte(s) readed - Ok Record 9: 8 byte(s) readed - Ok Record 10: 32 byte(s) readed - Ok Field [11] 5 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Record 2: 4 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 1058 byte(s) readed - Ok Field [12] 1 Record(s) Record 0: 102 byte(s) readed - Ok Field [26] 2 Record(s) Record 0: 16 byte(s) readed - Ok Record 1: 68 byte(s) readed - Ok Field [31] 1 Record(s) Record 4: 14 byte(s) readed - Ok Field [44] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [50] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [54] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 2: 24 byte(s) readed - Ok Field [88] 1 Record(s) Record 0: 36 byte(s) readed - Ok Field [96] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 20 byte(s) readed - Ok Field [107] 6 Record(s) Record 0: 41 byte(s) readed - Ok Record 1: 89 byte(s) readed - Ok Record 2: 89 byte(s) readed - Ok Record 3: 70 byte(s) readed - Ok Record 25: 236 byte(s) readed - Ok Record 26: 12 byte(s) readed - Ok Field [117] 10 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 3 byte(s) readed - Ok Record 2: 6 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 5: 10 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 8: 36 byte(s) readed - Ok Record 13: 3 byte(s) readed - Ok Record 14: 3 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [120] 4 Record(s) Record 0: 944 byte(s) readed - Ok Record 1: 160 byte(s) readed - Ok Record 2: 130 byte(s) readed - Ok Record 3: 112 byte(s) readed - Ok Field [153] 7 Record(s) Record 0: 68 byte(s) readed - Ok Record 1: 68 byte(s) readed - Ok Record 2: 68 byte(s) readed - Ok Record 3: 68 byte(s) readed - Ok Record 4: 68 byte(s) readed - Ok Record 5: 68 byte(s) readed - Ok Record 6: 68 byte(s) readed - Ok Field [193] 4 Record(s) Record 2: 8 byte(s) readed - Ok Record 3: 32 byte(s) readed - Ok Record 4: 32 byte(s) readed - Ok Record 9: 64 byte(s) readed - Ok Field [217] 1 Record(s) Record 0: 32 byte(s) readed - Ok Field [239] 7 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 3284 byte(s) readed - Ok Record 2: 3284 byte(s) readed - Ok Record 3: 3284 byte(s) readed - Ok Record 4: 3284 byte(s) readed - Ok Record 5: 3284 byte(s) readed - Ok Record 6: 218 byte(s) readed - Ok Field [291] 1 Record(s) Record 0: 92 byte(s) readed - Ok Field [308] 7 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 8192 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 6: 1 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Field [309] 7 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Record 2: 12 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 12 byte(s) readed - Ok Record 7: 12 byte(s) readed - Ok Record 17: 12 byte(s) readed - Ok Field [322] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [329] 1 Record(s) Record 0: 8392 byte(s) readed - Ok Field [334] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [341] 3 Record(s) Record 0: 1 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 4394 byte(s) readed - Ok Field [354] 1 Record(s) Record 0: 13 byte(s) readed - Ok Field [356] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 8 byte(s) readed - Ok Field [360] 3 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Record 2: 3 byte(s) readed - Ok Field [369] 1 Record(s) Record 0: 40 byte(s) readed - Ok Saved as C:\InfinityBox\BEST\Backup\RM-547 Nokia 6730c-1_354217030143251_0_400.pm Done! Elapsed: 00:00:01 RM-547.pp not exist Select file, please No any file found for this RM-identifier, break operation Check phone mode... Phone in RfInactive mode Seting Test mode... wait... Test mode set Reading Product Profile sets... 0 - 127 1 - 0 4 - 0 7 - 1 9 - 0 34 - 0 35 - 0 48 - 1 56 - 0 61 - 0 65 - 0 66 - 0 69 - 1 70 - 0 71 - 1 73 - 2 78 - 0 79 - 1 100 - 1 130 - 5 131 - 7 135 - 0 138 - 0 139 - 1 141 - 0 145 - 0 146 - 0 147 - 0 156 - 0 157 - 1 158 - 1 164 - 0 165 - 0 166 - 0 168 - 0 177 - 0 183 - 0 184 - 0 185 - 0 192 - 0 202 - 4 205 - 0 206 - 0 211 - 0 212 - 0 214 - 0 217 - 0 219 - 1 220 - 0 228 - 1 SETS 1 Readed 50 element(s) Saved as C:\InfinityBox\BEST\RM-547 Nokia 6730c-1_354217030143251.pp Done! Elapsed: 00:00:15 User ACCEPTED FULL ERASE Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 275002141E2C03445C85D311D5C747C91B3C4D57 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Seek file for this phone.... - > Backup for phone found and it is Ok :) Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : DA2DB2D32C1B2D9886A55B5D8A14F19ADDC53128 Reading NPC certificate... IMEI : 354217030143251 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\354217030143251_CRT.rpl ADL: Preparing for erase... Full Erase started... Asic : CMT , Sub : NAND Erase Area 0x00000000-0x0FFFFFFF Erasing Ok , [0F] Erase done , time : 00:00:01 ADL: Erase done ADL: Close_Session Content: 000205000000000000FFFF00000000 ADL: Reboot Phone disconected! Connect phone on selected interface... Core : v1.73 , BB5XG FlashEngine : v5.9 Selected FlashSettings : Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm547_021.009_prd.core.fpsx PPM : rm547_021.009_06.01_Euro3_prd.rofs2.fpsx PPM2 : rm547_021.009_211.03_VF_CZ_prd.rofs3.fpsx CNT : rm547_021.009_211.03_UDA_VF_CZ_prd.uda.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 275002141E2C03445C85D311D5C747C91B3C4D57 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : blank (Erased or HW failure) ADL: phone is in flash mode === SW Version Check === - > Can not collect initial info, continue flashing... - > Hope, this version will be ok === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm547_021.009_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm547_021.009_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 367 blocks TIME : Write time : 00:00:19 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM]=== Erase : Processing rm547_021.009_06.01_Euro3_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm547_021.009_06.01_Euro3_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 142 blocks TIME : Write time : 00:00:08 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM2]=== Erase : Processing rm547_021.009_211.03_VF_CZ_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm547_021.009_211.03_VF_CZ_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 54 blocks TIME : Write time : 00:00:03 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [CNT]=== Erase : Processing rm547_021.009_211.03_UDA_VF_CZ_prd.uda.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm547_021.009_211.03_UDA_VF_CZ_prd.uda.fpsx Total writen 19 blocks TIME : Write time : 00:00:01 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:00:34 Reboot phone now... Afterflash not selected, skip Done! Phone disconected! Connect phone on selected interface... Elapsed: 00:00:43 Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 275002141E2C03445C85D311D5C747C91B3C4D57 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Seek file for this phone.... XG223 RPL file IMEI : 354217030143251.rpl Write this file as RPL from dead mode!!! Connect phone on selected interface... Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SIMLOCK Data found! SIMLOCK KEY found! WMDRM KEY found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : Verify Error :( -> Error answer from BootRom Will Write RPL keys now... Check RPL file... NPC Data found! (CMT) CCC Data found! (CMT) HWC Data found! (CMT) SIMLOCK Data found! SIMLOCK KEY found! WMDRM KEY found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007600C192102011104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 275002141E2C03445C85D311D5C747C91B3C4D57 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : DA2DB2D32C1B2D9886A55B5D8A14F19ADDC53128 ADL: Preparing for write certificates... Erase NPC... Ok Writing NPC... Ok Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! :) ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Wait, reconneting... Phone not found... :( CertWrite failed : phone was not bootup Connection/SW/HW problem, try bootup manually If phone bootup Ok - write only flex keys |
