12-29-2020, 09:40 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india Age: 37
Member: 1146038 Status: Offline Thanks Meter: 196 | Help....RM-1035 contact service problem... Flash with same product code but set show " contct service " possible to solve .... Code: Card found : 0 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.19 Operation : Identify [ v1.19 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM84) MODE : NOKIA USB SERIAL PORT : 84 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : C9F39CC4DDD4B9E8380D050FCADD5CA0 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : CRYSTAL.12.00.11.p1 BOOT : SWR : 12.00.11 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : CRYSTAL.12.00.11.p1 FLASH : 00C2 : 0025 : 0036 : 0000 BBSN : C9F39CC4DDD4B9E8380D050FCADD5CA0 PRDC : 059X5P9 IMEI[1] : 354869087325569 IMEI[2] : 354869087325577 NCK : 20 digits PROV : 24407000 Saved as : 354869087325569.mtsec Saved to : C:\InfinityBox\BEST2\Backup\ Done! Elapsed: 00:00:36 Reconnect Power/Cable! |
12-29-2020, 09:43 | #2 (permalink) |
Member: 1146038 Status: Offline Thanks Meter: 196 | flash with lower but same... Code: Open VPLfile : RM1035_059W057_10.01.11.vpl Description : RM-1035 NDT INDIA MH LATIN IN DeviceType : RM-1035 ProductCode : 059W057 SoftwareVer : 10.01.11 PPM LangPack : [1] : Gujarati (India) [2] : Kannada (India) [3] : Marathi (India) [4] : Telugu (India) [5] : Punjabi (India) [6] : Tamil (India) [7] : Hindi (India) [8] : Urdu (Islamic Republic of Pakistan) [9] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.19 ] Setting : UserData erase : False Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM84) MODE : NOKIA USB SERIAL PORT : 84 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : C9F39CC4DDD4B9E8380D050FCADD5CA0 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : CRYSTAL.12.00.11.p1 BOOT : SWR : 12.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : CRYSTAL.12.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0040 : 0016 : 0000 NOR: [WINBOND] W25Q32BV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 10.01.11 [RM-1035] DEV SoftwareVersion : 12.00.11 SWInfo compare result : VPL SW ( Minor version ) is LOWER, than in DEVICE! Load FlashSet : MROM : RM-1035_ROM_eMP_10.01.11 LANG : RM-1035_LANG_PACK_ROM_MH_eMP_10.01.11_001 CUST : RM-1035_CUSTPACK_ROM_MH_INDIA_IN_eMP_10.01.11_001 JUMP : RM-1035_JUMP_TABLE_MH_INDIA_IN_eMP_10.01.11_001 VIVA : RM-1035_VIVA_eMP_10.01.11 Prepare FlashSet : DCR : RM-1035_ROM_eMP_10.01.11 DCR : RM-1035_LANG_PACK_ROM_MH_eMP_10.01.11_001 DCR : RM-1035_CUSTPACK_ROM_MH_INDIA_IN_eMP_10.01.11_001 DCR : RM-1035_JUMP_TABLE_MH_INDIA_IN_eMP_10.01.11_001 DCR : RM-1035_VIVA_eMP_10.01.11 Prepare Target SDS : OK : 0x003F4000 : 0x0000C000 CBR : 0x0000001A:0x00000001:0x00000000:0x00000000:0x00000010:0x00000002:0x00000000 Erase Target Flash Erase done! Write Target Flash Write : RM-1035_ROM_eMP_10.01.11 Write : RM-1035_LANG_PACK_ROM_MH_eMP_10.01.11_001 Write : RM-1035_CUSTPACK_ROM_MH_INDIA_IN_eMP_10.01.11_001 Write : RM-1035_JUMP_TABLE_MH_INDIA_IN_eMP_10.01.11_001 Write : RM-1035_VIVA_eMP_10.01.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-1035_ROM_eMP_10.01.11 Verify : RM-1035_LANG_PACK_ROM_MH_eMP_10.01.11_001 Verify : RM-1035_CUSTPACK_ROM_MH_INDIA_IN_eMP_10.01.11_001 Verify : RM-1035_JUMP_TABLE_MH_INDIA_IN_eMP_10.01.11_001 Verify : RM-1035_VIVA_eMP_10.01.11 Done! Elapsed: 00:01:01 Reconnect Power/Cable! |
12-29-2020, 09:53 | #3 (permalink) |
Member: 1146038 Status: Offline Thanks Meter: 196 | Problem solve.... flash with this file .. https://firmware.gem-flash.com/index...older&id=39086 Code: Open VPLfile : RM-1035_059W034_14.00.11.vpl Description : RM-1035 059W034 IC 14.00.11 DeviceType : RM-1035 ProductCode : 059W034 SoftwareVer : 14.00.11 PPM LangPack : [1] : Arabic (Saudi Arabia) [2] : Portuguese (Portugal) [3] : French (France) [4] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.19 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM84) MODE : NOKIA USB SERIAL PORT : 84 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : C9F39CC4DDD4B9E8380D050FCADD5CA0 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : CRYSTAL.10.01.11.p2 BOOT : SWR : 10.01.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : CRYSTAL.10.01.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8B NOR: 00EF : 0040 : 0016 : 0000 NOR: [WINBOND] W25Q32BV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 14.00.11 [RM-1035] DEV SoftwareVersion : 10.01.11 SWInfo compare result : DEVICE SW ( Minor version ) is LOWER, than in VPL! Load FlashSet : MROM : RM-1035_CRYSTAL_ROM_eMP_14.00.11 LANG : RM-1035_CRYSTAL_LANG_PACK_ROM_IC_eMP_14.00.11 CUST : RM-1035_CRYSTAL_CUSTPACK_ROM_IC_eMP_14.00.11 JUMP : RM-1035_CRYSTAL_JUMP_TABLE_IC_eMP_14.00.11 VIVA : RM-1035_CRYSTAL_VIVA_eMP_14.00.11 Prepare FlashSet : DCR : RM-1035_CRYSTAL_ROM_eMP_14.00.11 DCR : RM-1035_CRYSTAL_LANG_PACK_ROM_IC_eMP_14.00.11 DCR : RM-1035_CRYSTAL_CUSTPACK_ROM_IC_eMP_14.00.11 DCR : RM-1035_CRYSTAL_JUMP_TABLE_IC_eMP_14.00.11 DCR : RM-1035_CRYSTAL_VIVA_eMP_14.00.11 Prepare Target SDS : OK : 0x003F4000 : 0x0000C000 FFS Format Ok! CBR : 0x0000001A:0x00000001:0x00000000:0x00000000:0x00000010:0x00000002:0x00000000 Erase Target Flash Erase done! Write Target Flash Write : RM-1035_CRYSTAL_ROM_eMP_14.00.11 Write : RM-1035_CRYSTAL_LANG_PACK_ROM_IC_eMP_14.00.11 Write : RM-1035_CRYSTAL_CUSTPACK_ROM_IC_eMP_14.00.11 Write : RM-1035_CRYSTAL_JUMP_TABLE_IC_eMP_14.00.11 Write : RM-1035_CRYSTAL_VIVA_eMP_14.00.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : RM-1035_CRYSTAL_ROM_eMP_14.00.11 Verify : RM-1035_CRYSTAL_LANG_PACK_ROM_IC_eMP_14.00.11 Verify : RM-1035_CRYSTAL_CUSTPACK_ROM_IC_eMP_14.00.11 Verify : RM-1035_CRYSTAL_JUMP_TABLE_IC_eMP_14.00.11 Verify : RM-1035_CRYSTAL_VIVA_eMP_14.00.11 Done! Elapsed: 00:01:14 Reconnect Power/Cable! |
The Following User Says Thank You to @@@___@@@ For This Useful Post: |
