04-22-2013, 16:01 | #1 (permalink) |
No Life Poster Join Date: Sep 2007
Member: 591084 Status: Offline Thanks Meter: 41 | n9 problem with flashing RFS mode init Ok Device : RM-696 HW build : 1601 Bat.level : 15 SW release : (empty) Protocol : 108 UPDAPP ver : 1.7.2 Upd/Dev PT : 3 , 3 FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mm c,tar,cmt-2nd,cmt-algo,cmt-mcusw Last errors : bb5_rdc_cert_read failed Code Match Ok HW match Ok RFS Set : Host Protocol set to 108 RFS Set : CMT Verify On RFS Set : Perform RFS On RFS Set : eMMC preserve On ---Processing MCU image--- Processing File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin RFS : Sending config for [cert-sw] -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 RFS : Init pipe 00 RFS : Flashing... RFS : Finalizing... cert-sw Flash done RFS : Sending config for [kernel] -> Ver I : 2.6.32-20121301+0m8 RFS : Init pipe 01 RFS : Flashing... RFS : Finalizing... kernel Flash done RFS : Sending config for [rootfs] -> Ver I : DFL61_HARMATTAN_40.2012.21-3_PR_006 RFS : Init pipe 02 RFS : Flashing... RFS : Finalizing... rootfs Flash done RFS : Sending config for [cmt-2nd] -> Ver T : RM-696 RFS : Init pipe 03 RFS : Flashing... RFS : Finalizing... cmt-2nd Flash done RFS : Sending config for [cmt-algo] -> Ver T : RM-696 RFS : Init pipe 04 RFS : Flashing... RFS : Finalizing... RFS : ERROR_PIPE_FINAL_REQ FAILED Receiving error list... Last errors : Timeout while waiting for the HWBREAK Could not reboot into cold bootmode [Pipe 4] Finishing in error state with status 1 Flashing failed More info in Last Error Log Elapsed: 00:05:48 Connect phone on selected interface... and the phone was working before but too slow |
04-23-2013, 14:07 | #3 (permalink) |
Member: 591084 Status: Offline Thanks Meter: 41 | here is full log === SW version Check ==== Ok [Reflashing or Upgrade] === SW version Check ==== Processing APE Boot... File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin Processing : ape-algo APE Algorithm boot Ok Reopening the connection... RFS mode init Ok Device : RM-696 HW build : 1601 Bat.level : 11 SW release : (empty) Protocol : 108 UPDAPP ver : 1.7.2 Upd/Dev PT : 3 , 3 FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mm c,tar,cmt-2nd,cmt-algo,cmt-mcusw Last errors : bb5_rdc_cert_read failed Code Match Ok HW match Ok RFS Set : Host Protocol set to 108 RFS Set : CMT Verify On RFS Set : Perform RFS On RFS Set : eMMC preserve Off ---Processing MCU image--- Processing File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_006-OEM1-958_ARM.bin RFS : Sending config for [cert-sw] -> Ver T : RM-696 -> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805 RFS : Init pipe 00 RFS : Flashing... RFS : Finalizing... cert-sw Flash done RFS : Sending config for [kernel] -> Ver I : 2.6.32-20121301+0m8 RFS : Init pipe 01 RFS : Flashing... RFS : Finalizing... kernel Flash done RFS : Sending config for [rootfs] -> Ver I : DFL61_HARMATTAN_40.2012.21-3_PR_006 RFS : Init pipe 02 RFS : Flashing... RFS : Finalizing... rootfs Flash done RFS : Sending config for [cmt-2nd] -> Ver T : RM-696 RFS : Init pipe 03 RFS : Flashing... RFS : Finalizing... cmt-2nd Flash done RFS : Sending config for [cmt-algo] -> Ver T : RM-696 RFS : Init pipe 04 RFS : Flashing... RFS : Finalizing... RFS : ERROR_PIPE_FINAL_REQ FAILED Receiving error list... Last errors : Timeout while waiting for the HWBREAK Could not reboot into cold bootmode [Pipe 4] Finishing in error state with status 1 Flashing failed More info in Last Error Log Elapsed: 00:05:57 Connect phone on selected interface... |
