10-24-2014, 16:55 | #1 (permalink) |
No Life Poster Join Date: Dec 2008 Location: Apple pocket Age: 32
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | nokia c2-03 after flash local local mode/contact service problem was :slow work on galary so i flashed it work for 1 day again slow work so next day do again flash but after flash just come local mode when change the mode to normal by software show contact service i seen rpl damage Phone found! Series 40 Device detected! read info... - Ok Checking StartUp data ... ----------------------- IMEI Validation : IMEI Damaged!!!! - > SIMLOCK , SECURITY Info can be wrong! - > Need restore NPC backup or RPL CMLA Key status : CMLA key Not exist SimLock status : SimLock is Ok Security status : Security Damaged!!!!! - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! i have rpl backup so try to write but failed Will Write RPL keys now... Check RPL file... XGOLDxxx RPL detected NPC Data found! (XGold) CCC Data found! (XGold) HWC Data found! (XGold) SIMLOCK Data found! (XGold) WMDRM KEY found! (XGold) Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF EBL Loader : Custom Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL : Custom EBL sent Ok EBL : Quantum_Bootloader_2.5_M1S1 Boot done! Writing Flash Certificates... Writing NPC certificate Error on CERT_WRITE_REQ -> Failed to write NPC Writing CCC certificate Error on CERT_WRITE_REQ -> Failed to write CCC Writing HWC certificate Error on CERT_WRITE_REQ -> Failed to write HWC Writing Flash certs done! Wait, reconneting... Writing SimLock Key... Ok! Writing SimLock Data... Ok! Wait to accept changes for XGold... SimLock status : SimLock is Ok Security status : Security Damaged!!!!! WMDRM key sent... Ok Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok set was rpl full ok before flash any idea to fix it? |
The Following User Says Thank You to ..::Gsmideazone::.. For This Useful Post: |
