How To Remove User Code Nokia 225 I am unable to remove security code from Nokia 225. Can you please tell me step by step or the exact procedure? Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 10.01.11 00-00-00 RM-1011 IMEI 1 : 352353063***** IMEI 2 : 352353063***** XappVer : 0000078A Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : IJ CNT : PEARL.10.01.11.p3 Product SN : 6148A25BH Product code : 059V6J5 Base Prd.code: 059V3X9 Module code : 0206023 Hardware info======= HWID : 1000 LCDVer: TPO Lock info =========== IMEI : 352353063***** IMEI spNet : 3A 25 53 03 36 50 02 20 Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; SimLock status : Ok Security status : Ok Done! Software Info: 10.01.11 00-00-00 RM-1011 IMEI: 352353063***** PPM version : IJ Product code: 059V6J5 Rebooting phone to FlashMode... Wait for phone... Device boot not done Check Drivers Try again |
Because you have no install "MTK Serial driver" from support area. |
connect power off nokia 225 press power install driver. Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 49 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : DBA96E07C079BDD209A67429BC0C2E3F BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! |
