03-08-2021, 09:11 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: ( United States Of Islam ) Age: 35
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | how to slove this error Code: Card found : 8C73AEBC , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.20 Open VPLfile : TA-1017_059Z0X8_30.00.11.vpl Description : TA-1017 IC DeviceType : TA-1017 ProductCode : 059Z0X8 SoftwareVer : 30.00.11 PPM LangPack : [1] : Arabic (Saudi Arabia) [2] : Portuguese (Portugal) [3] : French (France) [4] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : False Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM4) MODE : NOKIA USB SERIAL PORT : 4 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : C12FD45CE1A2D3049A1B11444B0A0105 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : KESA61A.30.00.11.p1 BOOT : SWR : 30.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : KESA61A.30.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C2 : 0025 : 0037 : 0000 NOR: [MX] MX25U6435E NOR: TSIZE : 0x00800000 [ 8.00 MB ] PSIZE : 0x00800000 [ 8.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 30.00.11 [TA-1017] DEV SoftwareVersion : 30.00.11 SWInfo compare result : SAME Load FlashSet : MROM : TA-1017_ROM_eMP_30.00.11 LANG : TA-1017_LANG_PACK_ROM_IC_eMP_30.00.11_001 CUST : TA-1017_CUSTPACK_ROM_IC_eMP_30.00.11_001 JUMP : TA-1017_JUMP_TABLE_IC_eMP_30.00.11_001 VIVA : TA-1017_VIVA_eMP_30.00.11 Prepare FlashSet : DCR : TA-1017_ROM_eMP_30.00.11 DCR : TA-1017_LANG_PACK_ROM_IC_eMP_30.00.11_001 DCR : TA-1017_CUSTPACK_ROM_IC_eMP_30.00.11_001 DCR : TA-1017_JUMP_TABLE_IC_eMP_30.00.11_001 DCR : TA-1017_VIVA_eMP_30.00.11 Prepare Target SDS : OK : 0x007F8000 : 0x00008000 Erase Target Flash Erase done! Write Target Flash Write : TA-1017_ROM_eMP_30.00.11 Write : TA-1017_LANG_PACK_ROM_IC_eMP_30.00.11_001 Write : TA-1017_CUSTPACK_ROM_IC_eMP_30.00.11_001 Write : TA-1017_JUMP_TABLE_IC_eMP_30.00.11_001 Write : TA-1017_VIVA_eMP_30.00.11 Flash_Write ERROR : DA_CBR_NOT_FOUND Error : Flashing failed! Make sure device HW is in normal condition, check battery and cable! Reconnect Power/Cable! Open VPLfile : TA-1017_059Z1X7_11.02.11.vpl Description : TA-1017 IC DeviceType : TA-1017 ProductCode : 059Z1X7 SoftwareVer : 11.02.11 PPM LangPack : [1] : Arabic (Saudi Arabia) [2] : Portuguese (Portugal) [3] : French (France) [4] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM4) MODE : NOKIA USB SERIAL PORT : 4 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : C12FD45CE1A2D3049A1B11444B0A0105 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : KESA61A.30.00.11.p1 BOOT : SWR : 30.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : KESA61A.30.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C2 : 0025 : 0037 : 0000 NOR: [MX] MX25U6435E NOR: TSIZE : 0x00800000 [ 8.00 MB ] PSIZE : 0x00800000 [ 8.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 11.02.11 [TA-1017] DEV SoftwareVersion : 30.00.11 SWInfo compare result : VPL SW ( Major version ) is LOWER, than in DEVICE! Load FlashSet : MROM : TA-1017_ROM_eMP_11.02.11 LANG : TA-1017_LANG_PACK_ROM_IC_eMP_11.02.11_001 CUST : TA-1017_CUSTPACK_ROM_IC_eMP_11.02.11_001 JUMP : TA-1017_JUMP_TABLE_IC_eMP_11.02.11_001 VIVA : TA-1017_VIVA_eMP_11.02.11 Prepare FlashSet : DCR : TA-1017_ROM_eMP_11.02.11 DCR : TA-1017_LANG_PACK_ROM_IC_eMP_11.02.11_001 DCR : TA-1017_CUSTPACK_ROM_IC_eMP_11.02.11_001 DCR : TA-1017_JUMP_TABLE_IC_eMP_11.02.11_001 DCR : TA-1017_VIVA_eMP_11.02.11 Prepare Target SDS : OK : 0x007F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Flash_PreErase ERROR : DA_CBR_NOT_FOUND Error : Data erase failed! Connection or device problem? Make sure device HW is in normal condition, check battery and cable! Reconnect Power/Cable! Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM4) MODE : NOKIA USB SERIAL PORT : 4 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : C12FD45CE1A2D3049A1B11444B0A0105 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : NONE [ROM ERASED] AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : KESA61A BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C2 : 0025 : 0037 : 0000 NOR: [MX] MX25U6435E NOR: TSIZE : 0x00800000 [ 8.00 MB ] PSIZE : 0x00800000 [ 8.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 11.02.11 [TA-1017] DEV SoftwareVersion : SWInfo compare result : UNKNOWN ( Skipped ) Load FlashSet : MROM : TA-1017_ROM_eMP_11.02.11 LANG : TA-1017_LANG_PACK_ROM_IC_eMP_11.02.11_001 CUST : TA-1017_CUSTPACK_ROM_IC_eMP_11.02.11_001 JUMP : TA-1017_JUMP_TABLE_IC_eMP_11.02.11_001 VIVA : TA-1017_VIVA_eMP_11.02.11 Prepare FlashSet : DCR : TA-1017_ROM_eMP_11.02.11 DCR : TA-1017_LANG_PACK_ROM_IC_eMP_11.02.11_001 DCR : TA-1017_CUSTPACK_ROM_IC_eMP_11.02.11_001 DCR : TA-1017_JUMP_TABLE_IC_eMP_11.02.11_001 DCR : TA-1017_VIVA_eMP_11.02.11 Prepare Target SDS : FT_FILE_NOT_EXIST : 0x00000000 : 0x00000000 Erase Target Flash Erase done! Write Target Flash Write : TA-1017_ROM_eMP_11.02.11 Write : TA-1017_LANG_PACK_ROM_IC_eMP_11.02.11_001 Write : TA-1017_CUSTPACK_ROM_IC_eMP_11.02.11_001 Write : TA-1017_JUMP_TABLE_IC_eMP_11.02.11_001 Write : TA-1017_VIVA_eMP_11.02.11 Flash_Write ERROR : DA_CBR_NOT_FOUND Error : Flashing failed! Make sure device HW is in normal condition, check battery and cable! Reconnect Power/Cable! |
