08-24-2013, 12:38 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: india / Tamil nadu
Member: 773423 Status: Offline Thanks Meter: 82 | Nokia 205 flashing error Originally Posted by Dzirt View Post Hello! Thanks for test report! Need Help in this ... nokia 205 came for security unlock ... i try to flash with latest ver which is rm862__04.51 and the BEST Software is 1.69 manyu times tried .. i am getting error like this .. my cable ok and battery full now what to do ... ??? Quote: ===Flashing [MCU]=== File : rm862__04.51.mcusw Image : rm862__04.51.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x017C0000 Erasing, wait ... Erase done, time : 00:02:07 Write , Start : 0x40280000 , Len : 0x017C0000 Flashing , wait ... Region flash done, time : 00:00:35 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip Error... -> Check cable, flashfile, try again from this file Connect phone on selected interface... Elapsed: 00:03:02 Connect phone on selected interface... |
08-25-2013, 03:44 | #4 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | BEST was NOT ignore and WILL NOT ignore errors, which given by phone. In fact - they warn about some kind of damage. UFS ignore any kind of errors at all, as I know. And I will not change anything in BEST. |
08-28-2013, 13:49 | #5 (permalink) |
Member: 773423 Status: Offline Thanks Meter: 82 | i am agree with your point .... but after flash with other tool phone working fine ... (here i am not blame BEST ) need some alteration if anything have.... |
08-29-2013, 12:30 | #6 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | So, when I get such phone, and check exactly - will it work after and will it have bugs or not, and fix, if needed something inside. Now can't. |
The Following User Says Thank You to Dzirt For This Useful Post: |
08-13-2014, 14:57 | #8 (permalink) |
No Life Poster Join Date: Jul 2009 Location: pakistan
Member: 1083358 Status: Offline Thanks Meter: 199 | Core : v1.92 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm862__03.18.mcusw PPM : rm862__03.18.ppm_ma3 CNT : rm862__03.18.image_ma3_059Q046 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.55_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm862__03.18.mcusw Image : rm862__03.18.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 [ERR_hReqFlashEraseStart] : 8201410040000000 Error... -> Check cable, flashfile, try again from this file Connect phone on selected interface... Elapsed: 00:00:10 Connect phone on selected interface... |
08-20-2014, 11:05 | #15 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | It work for sure : 1. Read RPL from phone ( can be done in any phone condition , even fully dead ) 2. Change flash ic to new one ( from same phone or similar ) 3. Solder to that one, reflash, restore RPL. |
