07-29-2020, 09:13 | #1 (permalink) |
Junior Member Join Date: Dec 2018
Member: 2884523 Status: Offline Thanks Meter: 1 | Nokia TA-1105 after flash only No Command How to solve this I use bellow file from infinity server. PDA-220G-0-00WW-B01 Card found : 40B49488 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.19 Load : F:\Flash File\Android\Nokia 5.1 Plus\PDA-220G-0-00WW-B01\PDA-220G-0-00WW-B01.nb0 Load Ok! Operation : Write FW [ v1.19 ] Setting : UserData preserve : False Setting : Flash Pre-Erase : True Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM10) MODE : PRELOADER PORT PORT : 10 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Write FW [ v1.19 ] Setting : UserData preserve : False Setting : Flash Pre-Erase : True Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM9) MODE : BOOTROM PORT : 9 Error : Failed to open port! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Write FW [ v1.19 ] Setting : UserData preserve : False Setting : Flash Pre-Erase : True Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM9) MODE : BOOTROM PORT : 9 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : CD276DC41C4266766A02D7FECA4F68EE7B6F097286542F406F 74FD126E52D35D AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6771 AGENT : BEST_Nokia_DA_v19_1711_06 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A68423861503E014D2176E775A5 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : AB8C70FBB1533C525022CAE11F03F0D0 DA : USB : HIGH-SPEED Boot done! DL_INFO : PMT present SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : HW verification passed! Erase : 0x0000000000000000 : 0x0000000000108000 Erase : 0x0000000000188000 : 0x0000000001500000 Erase : 0x0000000003688000 : 0x0000000006000000 Erase : 0x000000000E800000 : 0x0000000000800000 Erase : 0x0000000012580000 : 0x0000000000800000 Erase : 0x0000000013DA0000 : 0x0000000001800000 Erase : 0x00000000156A0000 : 0x0000000002000000 Erase : 0x0000000018000000 : 0x00000000CE800000 Erase : 0x00000000E6900000 : 0x0000000002000000 Erase : 0x00000000E9800000 : 0x000000018E000000 PMT Update : OK Flashing now ... PROCESS : PRELOADER Unpack : PDA-0-220G-0001-preloader_fih_mt6771_64.bin Flash : PDA-0-220G-0001-preloader_fih_mt6771_64.bin Update bootloader backup copy ... Update bootloader backup copy Ok! PROCESS : LOGO_A Unpack : PDA-0-220G-00WW-logo.bin Flash : PDA-0-220G-00WW-logo.bin PROCESS : MD1IMG_A Unpack : PDA-0-220G-md1img.img Flash : PDA-0-220G-md1img.img PROCESS : SPMFW_A Unpack : PDA-0-220G-spmfw.img Flash : PDA-0-220G-spmfw.img PROCESS : SCP_A Unpack : PDA-0-220G-scp.img Flash : PDA-0-220G-scp.img PROCESS : SSPM_A Unpack : PDA-0-220G-sspm.img Flash : PDA-0-220G-sspm.img PROCESS : CAM_VPU1_A Unpack : PDA-0-220G-cam_vpu1.img Flash : PDA-0-220G-cam_vpu1.img PROCESS : CAM_VPU2_A Unpack : PDA-0-220G-cam_vpu2.img Flash : PDA-0-220G-cam_vpu2.img PROCESS : CAM_VPU3_A Unpack : PDA-0-220G-cam_vpu3.img Flash : PDA-0-220G-cam_vpu3.img PROCESS : LK_A Unpack : PDA-0-220G-0001-lk_service.img Flash : PDA-0-220G-0001-lk_service.img PROCESS : BOOT_A Unpack : PDA-0-220G-00WW-boot.img Flash : PDA-0-220G-00WW-boot.img PROCESS : ODMDTBO_A Unpack : PDA-0-220G-odmdtbo.img Flash : PDA-0-220G-odmdtbo.img PROCESS : TEE_A Unpack : PDA-0-220G-tee.img Flash : PDA-0-220G-tee.img PROCESS : VENDOR_A Unpack : PDA-0-220G-00WW-vendor.img Flash : PDA-0-220G-00WW-vendor.img PROCESS : SYSTEM_A Unpack : PDA-0-220G-00WW-system.img Flash : PDA-0-220G-00WW-system.img PROCESS : USERDATA Unpack : PDA-0-220G-0001-userdata.img Flash : PDA-0-220G-0001-userdata.img PMT Update : OK SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 Flashing finished! Done! Elapsed: 00:07:20 Reconnect Power/Cable! |
