03-06-2016, 06:50 | #1 (permalink) |
Junior Member Join Date: Mar 2016
Member: 2541765 Status: Offline Thanks Meter: 0 | Card with specified AID not found Dongle can't be found: Card with specified AID not found Card type selected: inf Dongle can't be found: Card with specified AID not found |
03-06-2016, 11:29 | #2 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,536 | Quote:
- Download "DongleManager" - http://server1.infinity-box.com/down...ngleManager.7z - Run DongleManager.exe - Read Box/Dongle serial number (S/N) DO NOT send screenshot/pictures - just copy/paste text from software window to your message | |
08-31-2020, 10:06 | #3 (permalink) |
No Life Poster Join Date: Jun 2009 Location: Live pakistan Age: 46
Member: 1054358 Status: Offline Sonork: 100.1626312 Thanks Meter: 269 | Card type selected: inf Dongle can't be found: Card with specified AID not found Card type selected: inf Dongle can't be found: Card with specified AID not found Report Post Reply With Quote same probam sir |
12-12-2020, 11:13 | #5 (permalink) | |
- Connect dongle/box to PC - Run CardID.exe - https://www.infinity-box.com/support/?r=7 - Select Card-Reader - Click to "Read" button DO NOT send screenshot/video but copy/paste text from software window ! | |
12-12-2020, 11:13 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | Hello, - Connect dongle/box to PC - Run CardID.exe - https://www.infinity-box.com/support/?r=7 - Select Card-Reader - Click to "Read" button DO NOT send screenshot/video but copy/paste text from software window ! |
06-15-2021, 18:46 | #7 (permalink) |
Freak Poster Join Date: Feb 2014
Member: 2125922 Status: Offline Sonork: 1601402 Thanks Meter: 112 | hi infinity team card Aid error Infinity-Box CardID v1.09 Error when connecting Card in: FT SCR2000 0 SmartCard API error #2148532325 The reader cannot communicate with the smart card, due to ATR configuration conflicts. |
06-15-2021, 22:27 | #8 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,968 | Quote:
Do you have any other card reader or dongle? Insert Infinity smart-card into anothr card-reader and try. Also you can try with other PC | |
06-17-2021, 16:17 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | This card is from year 2008, it's about 13 years old so it may be a hardware fault. Try to connect Dongle to another PC Try to insert Smart-Card into another Card-Reader or Box If problem still exist: - Remove Smart-Card from Card-Reader - Clean Smart-Card contacts - Try to use hot air gun and heat Smart-Card - Insert Smart-Card back to Card-reader If it will be no luck the only way - get new dongle. After that we can move the rest support time from damaged card to new one. |
06-23-2021, 09:35 | #13 (permalink) | |
Member: 2125922 Status: Offline Sonork: 1601402 Thanks Meter: 112 | Quote:
hare is Serial No (S/N): 11986080 | |
06-23-2021, 15:07 | #15 (permalink) | |
Searching... Card-Reader: FT SCR2000 0 HWID: 0004608001171292 Box/Dongle found: Infinity [BEST] Serial No (S/N): 11986080 Firmware version: 0122.02 "UK Edition" status: On Last launched Application: 0031 v.0122 => Activations: - 03: Infinity [BEST] v0122 => Options: - Infinity [BEST] - Infinity [BEST2] === DongleManager [Infinity] v1.81 [6/23/2021 19:06:23] === Box/Dongle type selected: Infinity [BEST] Card-Reader: FT SCR2000 0 HWID: 0004608001171292 Box/Dongle found: Infinity [BEST] Reading... Serial No (S/N): 11986080 Firmware version: 0122.02 === Process started: 6/23/2021 19:06:25 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. Smart-Card has latest firmware version or probably support period is expired. How to check - https://www.infinity-box.com/doc/?r=17 If it's expired contact to your seller and renew support - https://www.infinity-box.com/buy/ best software is working but cm2 software are error dongle not found. | |
