03-01-2018, 13:21 | #35 (permalink) | ||
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,346 | Quote:
Have done this procedure: Quote:
03-04-2018, 02:35 | #39 (permalink) |
Freak Poster Join Date: Apr 2005 Location: kins Age: 53
Member: 139936 Status: Offline Thanks Meter: 14 | Card found: S/N : 07B6673C , v0136 Registered to: Mduncan1 Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Set Phone to Test mode Done Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok WP8 Unlock Started Connecting to server... Connection faled: Socket Error # 10060 Connection timed out. Disconnected Error! Check previous error message for more info! |
03-05-2018, 10:15 | #41 (permalink) |
No Life Poster Join Date: Mar 2008 Location: FOCSANI Age: 39
Member: 718470 Status: Offline Thanks Meter: 79 | best nk2 1.03 has killed nokia 8 unlock bootloader phone dead restore bootloader error not work write firmware not work xml fls I can not find only this format NB1-309A-0-00WW-B01Nokia 8 but best not suported this fls edl mode no exit ? firmware not found ? after unlock bootloader phone remains in edl mode restore bootloader error Operation : Restore BootLoader [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. Use BOOT JIG or EDL cable! 3. Insert USB cable, press "POWER_ON" button few times, if need Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 835 [MSM8998] ID_BLOCK_S : ABA30A68 ID_BLOCK_I : 0005E0E1 ID_BLOCK_L : CE54EE6C5C91B383B085B8C2D02DB3F2 ID_BLOCK_L : DB2E1BE0B083E56E75E44F350F91CC93 Use BEST Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1 ExtInfo : 0x0001C000/0001C000/00001000/00001000/00001000 UFS Device : SAMSUNG KLUCG4J1ED-B0C1 0200 UFS SectSize : 0x1000 UFS LU0 Size : 0x00000007602F0000 : 29.50 GiB --------------UFS Device Info-------------- UFS Total Active LU: 0x6 UFS wManufacturerID: 0x1ce UFS Boot Partition Enabled: 0x1 UFS LU Write Protect: 0x0 UFS Boot LUN ID: = 0x0 UFS Memory Type: 0x0 UFS LU Total Blocks: 0x0 UFS Supported Memory Types: 0x800f UFS LUN Enable Bitmask: 0x3f UFS bConfigDescrLock: 0x0 Boot Ok! cannot open file C/infintybox/best2/recover/nb1-2690-0-00WW-B01. the sistem cannot fiind the file specified |
03-06-2018, 05:13 | #44 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
http://forum.gsmhosting.com/vbb/13002651-post3.html | |
