09-21-2018, 10:48 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Infinity-Box [BEST] NK2 v1.05 - Nokia 3310(2G), Nokia 5.1 and other models support Nokia 3310(2G), Nokia 5.1 and other models support activated ! - Nokia MTK Feature line support activated - Nokia 3310(2G) line support activated ! Next revision of 3310 (2G) are supported: Nokia 3310 : RETRO : TA-1008/TA-1030 For now the next features are supported: > Firmware flashing ( Factory/BEST firmware packages ) > Firmware reading > Format FS / Reset Settings > Identify ( read complete device info & check/verify security area ) Other models support enabled ( supported in BEST v1.xx line ) : Nokia 108: RM-944, RM-945, RM-1124 Nokia 220: RM-969, RM-970, RM-971, RM-1125 Nokia 225: RM-1011, RM-1012, RM-1043 Nokia 130: RM-1035, RM-1036, RM-1037, RM-1122 Nokia 215: RM-1110, RM-1111, RM-1112 Nokia 105: RM-1133, RM-1134, RM-1135 Nokia 222: RM-1136, RM-1137 Nokia 230: RM-1172, RM-1173 Nokia 216: RM-1187, RM-1188 Nokia 150: RM-1189, RM-1190 For now the next features are supported: > Firmware flashing ( Factory/BEST firmware packages ) > Firmware reading > Format FS / Reset Settings > Identify ( read complete device info & check/verify security area ) Changes from v1.xx line: Complete protocol rebuild - faster, safer, more stable FW read/make now direct, do not need additional read/convert operations FW read now more faster Devices not stuck in flash mode after some operations - Nokia 5.1 : CO2 : TA-1061/TA-1075/TA-1076/TA-1081/TA-1088 > Flashing ( Factory/BEST NB0 files ) > Reset Settings / FileSystem > Reset FRP > Identify > Repair Security > SP Unlock Support is standalone, no server and/or credits required ! - Changes/Fixes > MTK SP line Nokia 1: FRT : FRONTIER : TA-1047/TA-1060/TA-1056/TA-1079/TA-1066 Fixed BROM mode support Fixed dead mode flashing Fixed SP unlock Nokia 3.1: ES2 : ESSENTIAL2 : TA-1049/TA-1057/TA-1063/TA-1070/TA-1074 Improved flashing in MTK mode Fixed issues with FOTA after flashing > QLM SP line Removed legacy servicing methods Flashing engine updated - Other Settings Tab activated > Setup FeaturePhones DataPackage path > Setup SmartPhones DataPackage path > Setup IOS user credentials ( for use server-based operations ) Lot of fixes and global changes at all - Support Hundreds of firmwares for Nokia 3310 (2G) are in support area > Check out for need region packages or language packages on support area first! Or read from any well working device which you have. Nokia 230: RM-1172, RM-1173 - HMD and MS LEGACY different firmwares are in support area Nokia 216: RM-1187, RM-1188 - HMD and MS LEGACY different firmwares are in support area Nokia 150: RM-1189, RM-1190 - HMD and MS LEGACY different firmwares are in support area Download link Subscribe to Telegram channel and get news faster ! How to upload files to support Infinity-Box 13 years (2005 - 2018) updates and support as nobody else - News Twitter - Facebook - Telegram Last edited by InfinityHelp; 09-21-2018 at 20:40. Reason: download link updated |
The Following 81 Users Say Thank You to YellowBoss For This Useful Post: |
09-21-2018, 10:58 | #2 (permalink) | |
No Life Poster Join Date: Aug 2015 Location: Bangladesh Age: 30
Member: 2443283 Status: Offline Thanks Meter: 518 | Nokia 3310 TA-1030 Format Done Quote:
The Following 11 Users Say Thank You to nahidroman For This Useful Post: |
09-21-2018, 11:18 | #4 (permalink) |
Member: 2443283 Status: Offline Thanks Meter: 518 | |
The Following 9 Users Say Thank You to nahidroman For This Useful Post: |
09-21-2018, 11:30 | #5 (permalink) |
No Life Poster Join Date: Jul 2010 Location: chennai, india
Member: 1354113 Status: Offline Thanks Meter: 669 | plz add frmware download tab firmware download tab next up date for easy downloading |
The Following 3 Users Say Thank You to kumar008 For This Useful Post: |
09-21-2018, 11:43 | #6 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,421 | Hello, Support download area via IOS Login here https://user.infinity-box.com/ RESET PASSWORD Here https://user.infinity-box.com/?do=passwordreset |
The Following User Says Thank You to Kirumira For This Useful Post: |
09-21-2018, 11:54 | #7 (permalink) | |
Member: 1354113 Status: Offline Thanks Meter: 669 | Quote:
09-21-2018, 13:27 | #11 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | Code: > QLM SP line Removed legacy servicing methods Dear Coder please elaborate Now which way connect this type of phone fastboot or old edl mode ? |
09-21-2018, 14:34 | #12 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Please put BEST download link U have put CM2 link Br - srinibas | |
The Following 2 Users Say Thank You to srinibas For This Useful Post: |
09-21-2018, 15:04 | #13 (permalink) |
Freak Poster Join Date: Jul 2003 Location: RS;Bosnia&Herzegovina Age: 50
Member: 33472 Status: Offline Thanks Meter: 17 | change lang pack nok 3310 ta-1030 Operation : Write FirmWare [ v1.05 ] Setting : UserData erase : True 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM32) MODE : NOKIA USB SERIAL PORT : 32 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : A5CD1FD27FF056DDEB2BB13C0BAC52AB BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.11.02.11.p1 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6260 AGENT : RETRO.11.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8B NOR: 00C2 : 0025 : 0038 : 0000 NOR: [MXIC] MX25U12835FZNI_10G NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! Load FlashSet : MROM : TA-1030_ROM_eMP_11.02.11 LANG : TA-1030_LANG_PACK_ROM_ED_eMP_11.02.11_001 CUST : TA-1030_CUSTPACK_ROM_ED_EURO_HR_eMP_11.02.11_001 JUMP : TA-1030_JUMP_TABLE_ED_EURO_HR_eMP_11.02.11_001 VIVA : TA-1030_VIVA_eMP_11.02.11 Prepare FlashSet : DCR : TA-1030_ROM_eMP_11.02.11 DCR : TA-1030_LANG_PACK_ROM_ED_eMP_11.02.11_001 DCR : TA-1030_CUSTPACK_ROM_ED_EURO_HR_eMP_11.02.11_001 DCR : TA-1030_JUMP_TABLE_ED_EURO_HR_eMP_11.02.11_001 DCR : TA-1030_VIVA_eMP_11.02.11 Prepare Target SDS : OK : 0x00FF4000 : 0x0000C000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1030_ROM_eMP_11.02.11 Write : TA-1030_LANG_PACK_ROM_ED_eMP_11.02.11_001 Write : TA-1030_CUSTPACK_ROM_ED_EURO_HR_eMP_11.02.11_001 Write : TA-1030_JUMP_TABLE_ED_EURO_HR_eMP_11.02.11_001 Write : TA-1030_VIVA_eMP_11.02.11 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1030_ROM_eMP_11.02.11 Verify : TA-1030_LANG_PACK_ROM_ED_eMP_11.02.11_001 Verify : TA-1030_CUSTPACK_ROM_ED_EURO_HR_eMP_11.02.11_001 Verify : TA-1030_JUMP_TABLE_ED_EURO_HR_eMP_11.02.11_001 Verify : TA-1030_VIVA_eMP_11.02.11 Done! Elapsed: 00:03:03 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to kojote For This Useful Post: |
09-21-2018, 16:01 | #15 (permalink) | |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,421 | Quote:
If you understand what is IOS you will not ask again & again for download Link check & use my post #6 | |
