Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 09-22-2018, 09:38   #31 (permalink)
aydin.gsm1's Avatar
Member: 1333047
Sonork: 100.1618775
Thanks Meter: 278
IMEI option disabled.
uk off option in dongle manager selected and uk.off file copied already, but problem not solved.
Old 09-22-2018, 10:09   #32 (permalink)
akhtar.abbas's Avatar
Member: 1190193
Sonork: 1619687
Thanks Meter: 406
need stop button in new nokia madule
Old 09-22-2018, 10:21   #33 (permalink)
aydin.gsm1's Avatar
Member: 1333047
Sonork: 100.1618775
Thanks Meter: 278
Stop button is placed under File tab.
Old 09-22-2018, 10:55   #34 (permalink)
saydajan's Avatar
Member: 1318893
Sonork: 100.1640487
Thanks Meter: 279
very cool update waiting from long time for it tnk u team. best team.
Old 09-22-2018, 11:12   #35 (permalink)
Member: 1677653
Thanks Meter: 2,769
There is username and password box but no login box.
In next update enable automatic fill username and password on startup.
Old 09-22-2018, 11:13   #36 (permalink)
NKhan_Gsm's Avatar
Member: 1646177
Sonork: 100.1604654
Thanks Meter: 369
Originally Posted by ..::AtifGsm::.. View Post
Card found : B34D6861 , v0122
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.05
Operation : Read FirmWare [ v1.05 ]
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : Nokia USB Serial Port (COM27)
MODE : NOKIA USB SERIAL
PORT : 27
BROM : Init BROM
BROM init passed!
CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000
BROM : SECCFG : 0x00000007
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : 93ED2CE2BC9EC67290726D30A32963F9
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : RETRO.11.02.11.p1
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
SWVer : RETRO.11.02.11.p1
FLASH : 00EF : 0060 : 0018 : 0000
CODE : 0x00CD0000
Reading Flash ...
Error : Failed to read data! Unexpected end of data!
Check cable, connection and drivers!
Reconnect Power/Cable!
Same problem here in reading 3310 TA-1030 firmware
WBR
Old 09-22-2018, 11:13   #37 (permalink)
Member: 1677653
Thanks Meter: 2,769
I think for now only NOKIA MTK [SP] has IMEI option.
Old 09-22-2018, 11:27   #38 (permalink)
NKhan_Gsm's Avatar
Member: 1646177
Sonork: 100.1604654
Thanks Meter: 369
PTFN : Nokia USB Serial Port (COM7)
PORT : 7
BROM : Init BROM
BROM init passed!
BROM : MEID : 786876FD59B0552A466ABA830CA6D69F
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
BBSN : 786876FD59B0552A466ABA830CA6D69F
PRDC : 059X9S4
IMEI[1] : 355810094370916
IMEI[2] : 355810095370915
Done!
Elapsed: 00:00:38
PORT : 7
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
CODE : 0x00CD0000
Reading Flash ...
Old 09-22-2018, 12:13   #39 (permalink)
Nasir Mobiles's Avatar
Member: 355782
Thanks Meter: 1,265
Waiting for COM (Rx , Tx) integration for FP phones. will be very helpful if team add the feature.
Old 09-22-2018, 14:04   #40 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
In card in 99% cases stored DEFAULT password, which changed already.
Some users use different name and pwd and etc. There will be no such option.
Login option not need also.
The Following User Says Thank You to JayDi For This Useful Post:
Old 09-22-2018, 14:07   #41 (permalink)
JayDi's Avatar
Member: 462970
UART mode require authentification and complete FW packages and it almost useless. 1 device per 200+ is a normal possible fault percent.
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 09-22-2018, 14:08   #42 (permalink)
JayDi's Avatar
Member: 462970
In QLM part will be activated new mode in near SW releases.
Old 09-22-2018, 14:09   #43 (permalink)
JayDi's Avatar
Member: 462970
Originally Posted by UMeR3 View Post
please added coolsand/spd cpu :_)
There is no Nokia on Coolsand/RDA CPU.
3310 3G just one device from a line.
8810/3310 4G is on QLM also.
Old 09-22-2018, 14:10   #44 (permalink)
JayDi's Avatar
Member: 462970
Originally Posted by vishnudatt View Post
Read firmware (DUMP READ) not work in mtk fp mode
You should select RM/TA model from a list first to activate reading feature.
Old 09-22-2018, 14:12   #45 (permalink)
JayDi's Avatar
Member: 462970
Originally Posted by zebafridi View Post
Plz support New model TA1-034 TA-1035 and much more Mtk small Hand set
Originally Posted by Mubashir999 View Post
Good Update Team
Team Please Add 105 2017 and 130 2017 Model for flashing feature
Originally Posted by maero2014 View Post
Please add ta-1006 thanks
New models support on way, stay tuned.
We uploading firmwares for them on support right now. When all will be ready - we will make new update and announce it.
The Following 4 Users Say Thank You to JayDi For This Useful Post:
Page generated in 0.24550 seconds with 9 queries
